Page 40 of 330 FirstFirst ... 303637383940414243445090140 ... LastLast
Results 781 to 800 of 6591
    Jul 2005
    #781
    mga bros,
    mine is a gen 2.5 fieldmaster '00.
    nasira driver side seatbelt ko. naputol yata ang spring sa loob. does anyone here know where i can buy good surplus ones? out of stock kase sa planta according to el dorado 8500 daw!
    3rd row seats??? i need them too. i'll get rid of the bench type ones. where can i get a set with complete seatbelt for the 3rd row? can we get them from portillo's?
    shocks...tumagas na yung set of four na stock shocks ko. m still contemplating on what to get. pamatay sa mahal yung oem with controls (S-M-H). may nagooffer sakin surplus na set of 4 for 10T. para magamit ko pa rin yung controls. nakakadalawang isip. any suggestions?
    thanks in advance.
    pajero is really a classic. gagawin ko nang vintage ito.
    #782
    i suggest you go with the oem shocks. corny kasi kung may incab controls ka di naman gumagana.
    Apr 2004
    #783
    SOS paj peep, notice my Fuel gauge reserved light on (sometimes off) its still on the half (kakarga ko lng ng P1k).. any advise where and what to check....thx
    #784
    Boss Pajoz, you can have your fuel tank float checked. I think dun din yung sensor ng warning light.
    Apr 2004
    #785
    Quote Originally Posted by pajerokid
    Thnks Sir PK.....any idea where exactly the sensor is..
    #786
    pk: nice! makikita na namin in person the batmobile and da man behind da car! :D
    toadstool: hmmm. di kaya pwede yung belt mechanisms from other cars? yung problem ko naman is with the passenger side, ayaw magretract unless you pull it all out muna. lagi kasi naiipit dati sa pinto pag sinasara, di kasi nila binabalik sa dati, relying on the retracting mechanism to pull the whole belt back in.
    as for the 3rd row front facing seats with seatbelts, baka donor option na lang from a JDM pajero...
    portillos ata only does the leather on the seats, so they might not have the seats themselves, lalo na the forward facing 3rd row ones.
    #787
    boss pajoz, access to the float is via a portal in the middle of the trunk. Just lift the capet and you'll find a plate with seven or so screws, aalisin nyo lang yun and whapak! you'll see the fuel sending unit. Yung gen2 ko na-replace ko na. DIY operation lang. Yun lang nga, the sending unit will set you back mga 1.4k last time i checked.
    toadstoll, nugundam: i humbly suggest that you go with the oem part for the seatbelts. We had the exact problem with our Gen1 RAV4 dati. I repaired the spring and did all sorts of crazy stuff, pero hindi kaya yung force ng biglang hila. You dont really have an option na kumuha sa parts bin ng banawe boys kasi proprietary yung korte ng seatbelt mounts. Hehe. Pag nag-eb tayo papakita ko sa inyo factory defect nung passenger seatbelt ko! BALIKTAD! hehehe. Anyways gumagana naman.
    Jul 2005
    #788
    pk,
    yes ganda talaga pag OEM. but i'd like to see my other options din, like rancho, oldman, etc. might give me better ride than the OEM. since mahal yung OEM, might as well spend it on aftermarket upgrade. may kilala kayo nagkabit ng mga to?
    same lang ba ang 3rd row front facing seats ng pang 4g56 sa fieldmaster?
    anyone selling them, PM me your prices pls. thanks!
    #789
    The GEN II used JDM seatbelts. The FieldMasters used seatbelts from Autoliv (locally made yata). Iba ang mounting nito and since may local office ang Autoliv, baka mas makamura ka sa kanila. Don't compromise on things like these. Buhay ang pinag-uusapan diyan
    Third row seats (and all the accessories) are available from from Seatmate Mandaluyong. All Pajeros from 1992 to Field Master used the same 3rd row. Naiiba lang ng konti (headrests, upholstery, etc.).
    Suggest ko is just to go for good aftermarket shocks esp. considering how expensive the OEM's are. I've been using the Field Master this week and I find the ride a bit wallowy.
    Jul 2005
    #790
    otep,
    what's the number at seatmate? thanks.
    Jun 2004
    #791
    I would not suggest buying surplus dampers. It may look good externally but internally it may be another story...busted seals, etc.
    The OEM dampers are really quite expensive. I use Rancho 9000's on my Gen 1. On the Gen 2 di pa nasisira yung OEM's. But once they do I'll go with aftermarket dampers - Rancho or OME. Yes you won't be able to use the controls but you'll probably end up with a better, firmer ride.
    #792
    pk: ahhhh. ibang klase pala sa passenger seatbelt mo :D
    anyway, mine works pa naman in case kasi when you suddenly pull on it, kakagat kagad. yun lang, halimbawa ginamit and na-unbuckle na, 99% of the time hindi na siya babalik ng kusa unless you pull all the belt out and assist it in going back. oh well. +1 sa mga kelangan mapaayos.
    regarding the rancho 9000s, pwede kaya imodify yung OEM shock controls para at least ma-adjust pa rin at the very least, to 3 settings ng 9000s since 9-way naman siya? i know kasi sa may ibaba ata ng 9000 yung adjustment knob, not sure saan yung sa OEM one, so napaisip lang ako maybe it's possible.
    eb na later 3pm sa gonuts donuts/fitness first parking area sa Fort. seeya guys!
    #793
    Iba yung principle of adjustment ng Rancho sa OEM shock. You cannot use the OEM controls on a Rancho. Mas simple ang adjustment ng Rancho. Very mechanical.
    #794
    ohhhh okay. thanks!
    update lang on the pajero EB kanina...saya!
    we finally got to see the batmobile in person. :D
    Apr 2004
    #795
    NICE MEETING THE GUYS BEHIND THEIR PAJEROS...
    It was fun, buti na lang umulan after na...hehe
    #796
    onga. nakisama kahit papano yung weather.
    ganda ng stickers sir pajoz :D
    Aug 2003
    #797
    saya nung eb! daming pajero! sana next time may gen3 na.
    #798
    mas masaya nung gabi na jayvee. si phery kasi late nilabas niya yung mga optimus prime cannon.
    dami nasindak dun sa cannon when i subconsciously pressed the trigger on the one i got, akala ko wala nang karga. meron pa pala and BOOM! hehehe. buti na lang it was pointed down towards the gravel and not at someone. :lol:
    #799
    Nice meeting our fellow Pajeropeeps from Mymitsu!!!
    Sayang james di ko napakita yung seatbelt ko hehe. gumagana naman kaya lang talaga baliktad yung anchor.
    Lufet talaga yung particle cannon este sound setup ni Phery!
    PS: I still havent received the confirmation email from mymitsu
    Favor naman, pakisabi na lang po kay mike na nagemail na ako nung proposed pajero silhouette for the Pajero Clan sticker.
    #800
    pk: onga, sayang. next time siguro para makita natin yang baliktad na anchor. :D
    i asked the mods/admins na rin ng mymitsu, hopefully they can reply asap. i notified mark na rin about your suggestion.
    grabe, di ko mabitawan yung alcohol cannon na i got from phery. our neighbors were looking funny at me. :lol:
