mga master/guru/sir pb!
tanong lang pwede ba i-rechrome ung headlam??kasi nasira ung akin nung ondoy,pinasok ng tubig tas nagflake na!
reep, pag gusto mo tipid lalo, pwede naman siguro linisin lang yung AT filter, parang strainer lang naman siya,
pau, imho ko lang bro.get new oem na kung kaya, kasi pag pa chrome mo baka hindi rin ganun kakinis. and baka hindi kayanin yung init. may nakita kasi akong sidemirror na pina chrome plated hindi ganun kaclear yung reflection. , baka di rin maganda ang buga pag sa headlight na. pag nasa lower part ng lens yung nag flake off ok lang yan, kasi low beam usually ginagamit yung upper part naman ng lens, pag hi beams lang umaabot sa lower part. im not sure kung tama alala ko na 12k or 9k isa yung oem, depo brand 5k lang siguro but some say sablay daw buga., or pwede mo rin palagyan ng china made projector na HID 12k yata to, gagamitin parin stock housing mo but projector na, output may be better.
hows your ride after ondoy? can you share which parts ang nasira..
hi guys,
baka puwede po akong magpatulong baka mayroon pong may alam ng shop na gumagaw ang upuan ng pajero 1996 model..at kng san nakakabili ng mga parts nito..maraming salamat po...
twistan
seatmate sa mandaluyong near cityhall look for rocky tel#5322104
sino po may used a/c compressor (na di ginagamit/pinagpalitan na) 4M40 po. please donate nalang po mga sir's.
bg, saw this while reading sa australian forums, naalala kita
nasa likod ng speaker yung relay, yung yellow socket sa pic try mo check using multimeter, baka sira relay or loose connection lang.
Pin 1 goes to a 10A fused connection to the ignition switch power.
:dapat may 12 volts pag ON position, kung wala check fuse sa hood.
Pin 2 goes to the switch on the headlight stalk, the other side of which goes to ground.
: dapat may ground (-) kapag pindot mo stalk while nasa ON position
Pin 3 comes from the parklights
:12volts pag naka park lights
Pin 4 goes to earth
:test for ground lang
Pin 5 is not connected
Pin 6 goes to the headlight washer motor - the other side of which comes from the lighting circuit main 10A fuse under the bonnet.
:dapat mag ka power (+) a few seconds pag pindot stalk while on
disclaimer, nabasa ko lang to, havent really done it yet, ok pa washer ko, but medyo simple lang naman, who knows baka isa lang diyan ang walang connection kaya ayaw gumana, dapat nasa ON position and naka parklights para gumana washer.
ayokong tignan
nabalahaw ako sa soft sand sa isang beach sa bolinao. oh well, 4x2 lang ako.
7 tao nagtulak
now i'm thinking of getting either:
1. 4x4 gas FM (mura kasi bentahan)
2. 4x4 LC90 (para matic pa din)
3. patrol safari PSG type (mura kasi pero manual and malakas sa krudo)
hmmm...which is which![]()
Thanks PB, I always wondered saan located yang relay na naririnig ko when I tested the washer motor. But sadly my motor is barado, I dimanteled the fender liner. ka tetest ko mainit yung motor body nya, meaning me kuryente. barado siguro or something. masikip yung mount kaya di ko na tinuloy. di naman essential eh. hehehe
Nga pala, if me mag baklas sa inyo ng fernder liner at masira yung plastic screw, its P25 ea. siguro 20 lang yun sa banaue.![]()
Hi Archi,
Mine is 4x4 local FM 99 M/T.. This the last of the Mohicans na M/T. I remember last time nasa Zambales ako hinabol ako ng dalawang caretaker to stop my FM sa beach kasi bago ako may Starex dumerecho nabalahaw din, tulak na may kasamang hatak pa ng trcuk para lang maalis s buhangin. But after na nalamn 4x4 eh hinayaan na ako. Also kahit 9 adults kami paakyat sa Kennon sisiw sa 4x4.
So maybe you can consider lookiing for a 4x4 M/T na FM pa rin. Ito lang eh suggestion lang naman. Kasi pag nagpalit ka na ng ibang model, ma-miss ka namin next time sa Pan de Pugon. Wala na pati magaling mag-Kodak
haha! i still love my 4x2 a/t actually. matipid, dami ko na din nagastos to keep it in tip top shape.
naiisip ko nga kung meron makikipag swap to 4x4 then why not
pogi kasi FM body, naiisip ko gen 2 m/t pero at its price, halos dikit sila ng 2.5 4x4 a/t gas.
sarap kasi ng a/t hehe![]()
blue,
still thinking kung bebenta ko, happy naman din kasi ako. kung meron makikipag swap why not hehe
1.fm gas - minsan ko lang gagamitin pag alam kong mababalahaw ako hehe. afaik nasa 5km/city ata consumption nya? same sa LC90 gas
2. lc90 - gas 4x4 (5vzfe ata) lang budget ko hehe. ang mahal ng 1kzte
3. patrol - haha kung sa bagay, para kang nasa nissan sentra series 1 hehe. mura kasi bentahan although nasa 5km/city din sya afaik
hayyyy....
sir pb
wala nmn major damage sakin ung ondoy,palit head unit lng tas nagmoist lng ung comp box blower lng katapat.,ayun gumana na!tas binaklas ko ung carpet paralinisin
problem ko nalang ung nangangalawang ung ilalim ng upuan ko then ung headlamp
ganda naman ng ralliart mo archi, san ka nakakuha? magkano matagal na ako naghahanap. e
and by the way gusto ko mag change color ng paj FM. 4m40 san magandang shop pagdating sa paint?. and ano magandang kulay?
i changed bearing napo sir pb.. hehe but dahil umingay na.. mga 15tkms ago.. hehe
trans and diff oil.. pinapareplace ko last yr... pero sabi ng gumagawa ng sasakyan samin ok padaw eh.. hehe
tama kaya? kasi nasa 85tkms na pajero ko eh.. naalala ko tinangal niya plug.. then.. may konting metal shavings nasa plug magnet.. tapos... nung tumulu.. sobrang transparent pa.. kaya sabi niya.. wag na palitan maganda pa..
sir archi.. sayang naman paj niyo if palit niyo.. ganda condition..
4x4 is nice to have but.. personally di ko nagagamit.. hehe (nagagamit ko lang pag papark ako bangketa na mataas)
btw... if gusto niyo po power.. iwas po kayo gen2.. really lacking power po gen2..
