Page 317 of 330 FirstFirst ... 217267307313314315316317318319320321327 ... LastLast
Results 6,321 to 6,340 of 6591
    #6321
    rols yan lang yung problem sure lang yun sir? nangyari na sa inyo yun?
    Aug 2006
    #6322
    Good day po mga sirs! Im new to this thread. patulong lang sana ako kung Saan po ba makakabili brand new nung OEM ralliart mag wheels ng fieldmaster? or even 2nd hand ok lang din. And may idea po kayo how much??? Made by rota ba yun? By the way im from the visayas. Ipapabili ko lang sa bro in law ko if ever. Maraming salamat po.
    #6323
    Quote Originally Posted by rols View Post
    palitan mo lang yong bulb nyan sir
    +1 ako sa solution na yan. ganyan din sa kin dati
    Mar 2003
    #6324
    just repaired my power seat. nagloko yung reverse ko, pag switch ko click click ng relay lang naririnig but walang galaw. forward is working. baka meron diyan same symptoms.
    ito yung problem
    stuck up yung isang roller switch. ito yung switch na nagpapatay ng motor pag sagad na ang atras. kalas then wd40 lang.
    nasa seat rail siya. with the 4 colored wires. para matest kung ito nga problem, just unplug the switch socket (sundan lang yung blue tape) going to power seat module. this will bypass the switch. pag umandar ito na problema.
    buti nakuha sa DIY, hirap ng sirang power seat.
    #6325
    Lupet mo talaga Idol!!
    ito yung problem
    #6326
    Quote Originally Posted by badaboom View Post
    to all pajero 4m40 users automatic tranny
    i have this problem.
    yung transmission indicator ko
    [P]
    [R]
    [N]
    [D] - walang ilaw (green)
    [2]
    [L]
    what could be the problem? meron bang same problem?
    bulb lang yan... nangyari na sa akin yan... palitan mo na kaagad yan asap nakakailang na walang D dun sa panel gauge.hehe. mahal pa ata yung service fee kaysa dun sa bulb nyan sa reys electrical. dun ko pinagawa yung akin, tinamad ako mag DIY.
    #6327
    i love the idea of DIY. paano naman tangalin kaya dash nun? as far as i know it's either a peanut bulb or a crystal bulb/light yun.
    #6328
    Yung instrument cover lang tangalin mo sir Badaboom, tatlong screw ata. tapos yung cluster na. sa likod makita mo na yung mga bulbs ng cluster, change mo na lang.
    #6329
    ito yung problem
    ung akin naman stuck sya sa pinakadulo, ayaw na magforward
    same kaya ng prob??
    Aug 2005
    #6330
    *Pau,
    See my related post at page 400. Baka makatulong ang na-share ko kasi same experience halos natin
    Good Luck!
    Mar 2003
    #6331
    pau, isa siya sa possiblity, yun 2 rollers kasi isa for forward and reverse. just disconnect yung socket, and try. pag naging adventurous ka, ingat ka pala sa pag kalas ng internals ng power seat controls, grabe hirap ibalik. nung una kasi kala ko sa controls na mismo, yun pala yung roller lang. sarap ng feeling pag nakita mo umandar uli.
    badaboom, its T1.5 bulb, mas maliit sa peanut bulb. no need to buy. may ibang slots doon na di applicable sa pajero natin, pwede mo kunin lang yung bulb.
    Jun 2008
    #6332
    hello mga kapatid!
    tanong ko naman kung saan kaya ako pwede magpaayos ng dalawang nagging noises na naririnig ko sa sasakyan ko.
    1. there's this noise near the driver's door. sabi ng isang mekaniko sa may amin maaaring kung isa sa mga hinges ng pinto ay kailangang tingnan baka aluwag daw. kaso hindi sila gumagawa nun.
    2. i have this nasty kalampag sound in front whenever i turn left or right. sabi sa akin nung same mekaniko, maaaring kulang ng greasing yung isang nipple ng pangilalim ko. they also said they can't help me with that kasi kailangan daw mahaba ang pang grease nito.
    maraming salamat!!
    Mar 2003
    #6333
    kalimbahari. kapatid nakapagpalit na ako ng hinge, nakasetup karin ba kaya bumigay? bigat kasi ng deadening. buksan mo lang door then buhatin mo mula sa ilalim ng door, makikita mo na kung may alog or tunog hinges. 300 lang pa machine shop yan, or pwede rin buy brand new parang 1.5k lang yata. bumili ako bago then tinabi ko nalang as spare yung luma.
    problema sa bago hindi siya painted.
    Sep 2009
    #6334
    [P]
    [R]
    [N]
    [2]
    [L]
    sir bulb po yan sure ako kasi nangyari na sa kin yan
    Sep 2009
    #6335
    pb buong hinge assembly ba pinalitan mo?sa tingin ko pwede yung pin at bushing lang ang papalitan ganyan din kasi yung sa escapade pag may alog na pin at bushing pero kung wala pang leeg yung pin bushing lang ang papalitan pero kung 300 lang nagasta mo ok na nakamura ka na dun
    May 2008
    #6336
    Quick question: Ilang liters of oil ang kailangan ng Subic Pajero 2.5 4d56 Intercooler Turbo? 5.5 liters pa lang so far nailagay ko.
    #6337
    double post
    #6338
    Quote Originally Posted by Reepicheep View Post
    Check the dip stick when the engine is cold. Nag vary cguro din sa classe ng oil filter. Mas sure ball ang dip stick
    May 2008
    #6339
    Thanks for the advice sir. Tomorrow morning ko na lang check para sure.
    Jun 2004
    #6340
    just changed all of my GP to HKT * 430 pesos each. patay na kasi 2 out of 4 ko.
    simple math:
    orig 2,800 x 4 = 11,200; SAY 2 years minimum use
    equivalent (HKT) 430 x 4 = 1,720; SAY 6 months use, in 2 years (4x ako magpapalit) OR 6,880 lang
    nasa 16% puhunan lang ung HKT against OEM
    bnew naman battery ko and bagong service alt ko plus grounding kit kya kampante ako sa charging system ko
    so far so good...thanks PB! (4 years and counting ung HKT nyan kakaiba!)
