Page 301 of 330 FirstFirst ... 201251291297298299300301302303304305311 ... LastLast
Results 6,001 to 6,020 of 6591
    Feb 2010
    #6001
    *sir rts, tarlac based po kami it would be better if we could see the unit kindly PM nyo lang po kami where's the unit located so i can schedule an appointment...we're not in a hurry naman po.
    any other referrals or offers is highly appreciated, thanks po sa mga replies
    May 2008
    #6002
    Quote Originally Posted by archijardy View Post
    i believe warped pa din yan, semi lang.
    pulsating din sa akin sa high speed, pina reface ko harap sabay new pads, ok, nawala.
    tapos before holy week ung likod naman reface and new pads sabay change fluid ulit. ayun ramdam mo na apat kumakapit
    Brought the rotors to a machine shop this morning. Nabawasan ang pulsating. 1k lang gastos with some help of dad's driver.
    #6003
    This forum is really helpful- for the practical tips as well as sa mga contacts from where to get supplies and services.
    Share ko lang din for those who will be similarly situated. Last week e bigla na lang umilaw yung A/T, fuel filter and battery indicators. Hindi nawawala pero umaandar pa naman ako. I was told it's definitely "alternator problem."
    So dinala ko Pajero sa Rey's Electrical Shop sa Marikina. After the testing, hindi nga daw nagkakarga yung alternator. Sira pala yung diode nya. P3600 din inabot. Ok na rin, at least gumagana na ulit sya. I inquired sa casa, 50k++ pala ang new alternator.
    Regards to everyone here.
    Oct 2009
    #6004
    good day po mga kapaj tanong ko lang po sana sa mga nakapagpalit na ng water pump sa fm nila kong san po kau nagpagawa na shop at kong magkano po inabot kc nakita ko kaninang umaga sa fm ko parang basa don sa may pump pero pagpinaandar na nawawala po yong basa kailangan na po ba kayang palitan or lilinisan lang po? salamat po
    Jun 2009
    #6005
    Hi,
    Anybody out there who knew what shop can repair the horn? I need to disconnect the orig horn layout in the wheel cover(4 spoke)naglagay na lang muna ako ng temporary botton sa left side panel(done by autoelect.) I went to mits casa, ang suggestion nila to replace the whole cover including yun air bag, which will cost P40k, sabi ko wala naman problema ang air bag iyun lang horn dahil grounded(continuous blowing). I hope someone out there can refer me sa talagang gumagawa o na nakapagpagawa na.
    Thank you-Artee
    Jun 2004
    #6006
    Quote Originally Posted by RTS View Post
    Hi,
    Thank you-Artee
    I suggest you take your rig to Wizard (along Morato) or Rey's Electrical (15th Ave Cubao). Kung ground lang problema kaya nila gawin yan don. Good luck.
    Jun 2004
    #6007
    Quote Originally Posted by rols View Post
    Had my rig's ('99 FM Local) water pump replaced in 2008. Got OEM from El Dorado. Sinabay ko na rin pati thermostat para isang gawa na lang. Had it replaced in Motorcraft - where I have all my rigs serviced post casa warranty. Mahal lang pag OEM pero so far no problems. Motorcraft is along Banawe. Maayos don. You just need to be there really early as the lines do get long.
    #6008
    ako naman had my 95 pajero's water pump replaced nung 2007 naman. bought the original water pump from motorix then had my suking home service mekaniko do the replacement of the water pump as well as the timing belt and seals para isang gawaan nalang....do try to getthe original para sure na tatagal at di ka malugi sa labor.
    Nov 2007
    #6009
    Paj Man saan Diamond motors ka nakabili? Pic naman.
    sa may makati pasong tamo extension
    #6010
    Quote Originally Posted by Paj-Man View Post
    Paj man wala bang pic?
    Jun 2004
    #6011
    just had my 2 front shocks replaced. since mahal orig, i opted for TOKICO gas. 1,100 isa.
    so far parang medium setting sya, kya meron slight nose dive. since orig pa likod ko, ginawa ko lang medium setting para medyo pumantay oto pag prumeno ako.
    ang galing ng orig kahit busted na, kahit dapa na ung shocks, ung ulo nya ang kumukontrol pa din sa shocks for S-M-H.
    try ko patsek likod ko, worst, palit din muna ako gas shocks, wala muna SMH settings. ang mahal kasi ng orig, wala ako pondo para sa apat ngek! but if i had the money, iba pa din orig.
    so far MEDYO nawala ung sway ng harap ko nung pinalitan ko new shocks. pero kainis, meron pa din maliliit sway depende sa kalye. mukhang normal na ata ito considering the tire overall size
    #6012
    how does smh work po ba? no way to refit the system on the new shox po ba?
    Jun 2004
    #6013
    Quote Originally Posted by AC View Post
    amazing how it works on the 2.5
    soft-medium-hard shocks settings depende sa type mong feel ng ride. i normally use hard, medyo matagtag pero walang body roll sa corners and di matalbog ung FM. pati sa lubak ok ung Hard, less bumps pero ok din SOFT minsan sa rough road. really depends on you. ok din pag puno ka, set to HARD para di masyado dapa ung FM.
    although with my aftermarket front shocks and orig rear, inakyat ko tire pressure to 35 para feeling HARD settings hehe. ang mahal ng orig shocks grabe
    i think there's no way to retro, iba talaga ung design ng orig shocks
    #6014
    ic.. hehe kala ko pa naman may mechanism lang na pwede ilipat..
    ako din.. pag gamit ko fm ng dad ko.. hehe hard palagi... sarap kumorner... sabay floor pedal.. feeling racer eh noh.. hehe
    anyways.. ot but.. napanood ko lang sa topgear.. new bmw series5... suspension niya.. malambot pag straight takbo mo.. and pag lumiliko ka titigas.. hehe
    Mar 2003
    #6015
    while checking my engine bay this morning may nakita akong white water marks sa baba ng water pump ko, though hindi nagbabawas ng tubig this is a sign na pasira na siya. nag order na ako ng water pump ko pati thermostat. baka nasira ko sa kakahigpit ko ng fanbelts. warning na yan sa mga maselan sa lumalangitngit na fanbelts sa umaga. dont over tighten, mahal ang oem water pump
    mag tinanongan ko ng prices baka may interested.
    casa - 12,398
    carline - banawe oem 7,500 (ito binili ko) thermostat is 800 oem
    gmb - replacement - 1,800
    labor daw 1,200
    sabi ng mechanic kung 114k kms lang nasira ko water pump ko, ok na raw gmb replacement mga 100k kms tsaka bumibigay, sabi din niya na yung gmb daw aluminum ang impeller unlike sa oem na metal kinakalawang. but still oem nalang kinuha ko.
    gastos nanaman.
    Apr 2010
    #6016
    pips, i have an '01 fieldmaster and i want to install an "over-rider", ung parang bullbar sa front bumper which is standard sa newer models. newer models also have the big "PAJERO" sticker on both of the side doors. the sticker is available sa casa.
    i'm not sure if the over-rider for the newer models will be an exact fit on the '01 fieldmaster, does any one know? magkano kaya un and is anyone here selling it?
    i'm from lucena and don't want to go to banawe, q.c. just to source this out there specially if not sure kung meron nga dun. tnx
    Oct 2009
    #6017
    napalitan ko na po yong water pump ko GMB 1300 kuha ko sa carline yong pump lang tapos 500 sa machine shop kc yong dating pulley ko pa rin pinalagay ko plus 800 sa labor so far ok naman cya katulad ng sinabi ni sir PB mga 100k na din daw itatagal ng GMB
    Mar 2003
    #6018
    rols, nagkamali daw alan sa waterpump price 8,200 na daw oem niya. mura kuha mo gmb dito province 1,800 siya.
    rosa, welcome to tsikot. i got my overider sa casa 9.5k. meron ako nakita sa banawe 4.5k lang but may konting difference. mas pantay pantay pagkakagawa ng oem and yung mga kanto mas hindi bilugan. yung sticker naman sa winterpine ko binili 4.5k. sa casa kasi 10k noon. 8 years ago ko na pala nabili yan baka iba na price.
    #6019
    bakit yung akin oem pero hindi pantay..hahaha magkano na kaya ngayon yun sticker.. mura yun ah..
    * rosa- try mo din kay sir sanny ng c3 4x4. check mo site nila.. dyan ako naorder pag may kailangan ako sa paj and nagdedeliver din sila since sa laguna pa ako..
    Apr 2010
    #6020
    * promdiboy & bigbrocx- salamat. will try your suggestions.
