Page 311 of 660 FirstFirst ... 211261301307308309310311312313314315321361411 ... LastLast
Results 3,101 to 3,110 of 6591
    Apr 2008
    #3101
    mga sir help naman po. yesterday i had my 150,000 done in caltex. i had my fuel filter and gas float replace. when i start the engine, the low fuel indicator lights up even im full tank.
    also, i had my gear oil changed. on my way home i tried 4x4, biglang namatay ung 4x4 light(the green one) pati ung 4x2 nawala din pero ung centerl lock (the yellow one) meron nman.
    ano po kaya problema dun?
    Mar 2003
    #3102
    dahc, bro nung nagpalit ako ng fuel filter ang umilaw saakin yung fuel filter warning light. nabasa ng diesel yung socket kaya naging grounded. maybe same din sa low fuel warning light mo. connected sa float yung wiring niyan pag dumikit yung float sa any part ng gas tank iilaw yan (body gorund) check rin connections baka nabasa or nabalatan. .
    try to check your fuses parang may nakita akong fuse ng 4x4 sa dash or sa engine bay ba yun. cant remember exactly saan ko nakita.
    Apr 2008
    #3103
    dahc, yes bro iba iba,
    AT and power steering = ATF dexron 2, sa gas stations.
    diffs = gear oil sae 90 GL4 rating, sa gas station
    transfer case = gear oil sae 90 din but GL5 rating, I used castrol gear oil. 4x4 models only
    hindi ma drain lahat ng ATF pag palit filter, just drain and refill every 20k kms.
    sir, ask ko lng baka nagkabalikad lng? kase tiningnan ko ung manual before changing oil ng gear. ung transfer case GL4 ung diff oil ung GL5? tama ba un sir? un kase pnalagay ko.. thanks
    update lng mga sir, i change rear wiper blade, so i had to remove ung spare tire. nung tinangal ko, kalawang na ung kinakabitan nung spare tire. what i did is remove it and diy paint ko. baka may kalawang na din ung sa inyo..
    #3104
    Mga Bros, meron ba kayong balak na upgrade sa FM ninyo this year? Planning to upgrade yung stock sound system para mas maganda yung sound para SQ. Change sana yung HU na meron USB at Aux in at active sub para meron konting bayo.
    Share ninyo yung balak ninyo.
    Mar 2003
    #3105
    dahc, baka mali na pagkaka basa ko sa manual. pero ang nilagay ko sa TC ko is GL5. gl4 sa diffs.
    nelany, basta car audio magkakasundo tayo. nagsimula din ako sa ganyan, change HU, seps and active sub, mga 20k nagastos ko. kung HU features hanap mo silipin mo pioneer 6050ub nasa 9.5k, or kung mas lower model pioneer 4050ub kung lower model nasa 7.5k , both have aux in at usb. yung mas mahal motorized yung face. meron pa 3050ub for 6.5k kaso walang preouts para sa sub. gamit ko dati blaupunkt na active sub, pero sa katagalan nabitin din ako, maliit lang siya kasya siya sa gitna ng 3rd row seats
    Apr 2008
    #3106
    update: ung low fuel warning light problem ko. sabi sa rey electrical, hindi daw acurate ung replacement gas float. I will bring to them my old float, baka kaya pa daw i repair. dont buy replacement gas float, sayang lng.
    *nelany and promdiboy. may DIY sound set-up din ako. HU ko pioneer 2650, medyo luma na pero serve its purpose pa din. all the way targa ako. seps 6x9 at 2 pcs 12' sub. ung amp ko naman, V12 and a old school alpine from my previous car pa that i sold.
    #3107
    PB, yung nakita ko ay yung 3150UB na 2009 model. Pareho ata ng 3050UB ito. Dalawa lang yung RCA out. Pwede kaya lagyan ito ng sub? At yung active sub na pwede sa ilalim ng upuan ay yung MBQ na 10". Eto yung pic. Hindi ko alam kung ok eto kaya nag tatanong tanong.
    Mar 2003
    #3108
    dahc, wow 2 12 inch nilagay mo. boom boom pala setup mo. patingin naman ng pics paano mo ginawa. sa pajero ko single 8 inch lang (JL 8w7) and 2 JL amps for front stage (dls up6) and sub. DIY ko din yung woodworks,
    nelany, yes pwedeng pwede didnt know na narelease na pala yung 2009 model nasa 2008 pa ako about sa mbq 10 inch I think thats more than enough for sq, just dont expect it na bumayo talaga. yung blaupunkt ko dati 8 inch lang kaya nabitin ako agad, sold it after a months use lang. kaya lang parang hindi yata kakasya under the seat yan. under the 3rd row lang pwede ilagay. are you planning to buy amps for your front speakers? canvass karin kay jeff tan ng araneta car accesories or sun X. when it comes to budget setups sila daw ang pinakasulit. tell us your plans sa upgrade
    HU = 3150ub
    seps = ??
    amps = ??
    sub = mbq 10
    #3109
    Wow pala set up ni dahc. Pang street bass yung 2 12" na sub niya. Yung sa akin pang SQ ang hanap ko.
    Pb, wala pa akong balak sa amp at sep sa ngayon (wala pang budget ) pero tanong ko na rin kay Jeff kung ano recommend niya.
    Yung quote niya last month para sa sub at ampli ay 8K+ (12" + V12 + installation) kaya lang kailangan ko yung 3rd seat kaya hindi pwede yung passive sub sa akin.
    Update ako next week pag nakausap ko uli si Jeff.
    Jan 2008
    #3110
    Question again.
    My Pajero is still experiencing lumpy idling when cold. The hardstarting part is due I'm sure to faulty glowplugs which is easily replaced but once the Pajerso starts na, I have to keep the rpm somewhere in between 2 to 1.5k to prevent it from dying.
    Parang pumupugak then smokey on a good day and really really really smokey pag namatayan and you get to start it again. Parang nalulunod. There's also some kind of light knocking sound coming from the engine. But once the engine heats up everything's ok na. In fact there's no problem sa takbo at all once uminit na.
    It's really irritating. What can be the problem and how do I solve it without breaking the bank?
    Thanks sa lahat!
