Page 305 of 660 FirstFirst ... 205255295301302303304305306307308309315355405 ... LastLast
Results 3,041 to 3,050 of 6591
    #3041
    Quote Originally Posted by larshell View Post
    Nagpunta ako keyser radiator repair shop sa west avenue QC
    They overhauled my radiator. Almost the same as orig yong top plastic portion ng radiator ko and palit narin ng rubber gasket. They flush out the whole cooling system including the heater. Ang daming kalwang! Cost is P5,880, pwede na (IMHO) kasi the whole radiator cost is 15K not orig, Orig cost is 34K Parang orig din yong ginawa nila. I also discover that my Aux fan was malfunctioning intermittently, so I decided to replace the motor. Cost is 7K Denso Orig. Ang laki ng nilakas ng Aux Fan ko. I'm now observing my Pajero if the engine still overheats most probably Cylinder head is the cause of the problem. I hope my Pajero will be fine.
    Ganun na ba yung presyuhan ng pag overhaul ng radiator? Yung auxillary fan ang tanong ko last Nov dyan sa Rae Aircon shop sa Marikina ay 3.5K yung Denso Japan. Mas mura yung Taiwan na Denso kaya lang madaling masira. Bibili na sana ako ng auxilliary fan during that time ng sabihan ako nung gagawa ng aircon na pagawa nalang daw yung orig na auxilliary fan ko kasi hindi naman daw sunog. Charge me 500 pesos sa repair at mukhang bago ba uli. Naka tipid ako ng malaki. 300 yung labor ng pag baklas at kabit pati yung pag karga ng freon. Freon charge ay 500 pesos.
    #3042
    larshell, sana yan na nga yung problem, napansin ko din sa radiator ko yan na ang daming kalawang, mga 3 months ago I flushed my radiator 3 times, pag uwi ko sa gabi I flush with a cleaner and replace with new water. 3 consecutive nights yun, medyo malaki nagastos ko sa coolant and coolant flush. kasi napansin ko nga na parang di natatanggal yung kalawang. but ganun parin after a few days yung kulay ng coolant parang brownish green agad. a friend advised me to mix turco and water sa radaitor sabi niya for sure tanggal lahat ng kalawang. kaso natakot ako. hehe. how did the shop flush your system? any chemicals or procedure na pwede mo ituro saakin para DIY ko. parang gusto ko nga iwan na yung flushing chemical for one day sa radiator para talagang maflush. kaso hindi ko alam kung may bad effect.
    sa aux fan normal talagang sirain yan, magakano mo nabili aux fan mo?
    PB, yung Crosswind ko ng binaklas yung radiator kasi nabutas ay wala akong nakitang kalawang ng tinangal nila yung radiator. Labas lahat yung coolant sa radiator pati na sa makina pero walang kalawang. Puro green color ng coolant lang. More six years na yung radiator ko (3X na palit ng coolant) at nung lang nasira. When I put coolant sa radiator ko I use distilled water. Anong ba coolant at tubig ba ginagamit mo?
    Mar 2003
    #3043
    nelany, yung LC 80 ng erpats ko wala ding kalawang 96 model pa yun. pag sinilip mo yung loob makiita mo na yung internals na bakal parin. pati yung 99 revo ng friend ko ganun din. linaw pa ng tubig kaya kita mo loob, . but sa pajero mukhang kalawangin radiator. nakikita ko yung corrosion nakabalot sa internals. di na matanggal sa regular flushing, green parin yung coolant but corroded na internaly. kaya common narin na magbara radiator. kaya dapat talaga every 20k flush tayo ng radiator lalo na pag luma na engine natin. gamit ko absolute distilled water, prestone coolant flush, prestone coolant and prestone anti rust additive. bumili na ako ng flush kanina plano ko iflush uli kahit kakaflush ko palang. nabili ko cyclo coolant flush brand mukhang di kasi ganun katapang yung prestone flush.
    Mar 2003
    #3044
    pajman, try mo bounce yung front suspension, patulong ka sa dalawang mga malalakas para talagang maalog. and listen for the tok sound, madaming pwede magcause ng tok sound. shocks pwede rin, madali lang check yan, hawakan mo lang yung body ng shocks then alog alogin mo. kung may movement sa lower part ng shock, yan na siguro yun. shock bushing lang yan.
    Aug 2005
    #3045
    Share ko lang po ang experience ko just this weekend.. Napansin ko di na umiikot ang Aux fan, pero di naman ang-ooverheat. Dinala ko sa Evangelista and they replaced the motor with a Denso (not sure kung japan or Taiwan) and they only charge me only P1300 including installation.
    Tahimik ang motor at mas malamig na lalo aircon ko ngayon. Malamang matagal ng sira Aux fan pero lately ko lang napansin.
    Aug 2005
    #3046
    Quote Originally Posted by dahc View Post
    mga sir, may marerecomend po ba kayong radiator repair shop sa east? thanks
    dahc,
    Saan ka sa East? may i-refer ako though hindi ko pa nasubukan for this work. Sa pasig ang shop nag-overhaul ng radiator and they will charge only P900. Nag-inquire ako one time na ginawan nila ng paraan ang water pump ko kasi may leak. Auto Medics (?) they specialize sa European cars restoration and they also do mechanical repair. Malapit sa palce ng mga motels.
    Also, in one of the threads somewhere, I got this info nasave ko lang for future reference. Below is the info I captured sa post:
    o. Radiator cleaning machine sa Paranaque >> JP Wheels
    o. Blk 9 Lot 26 President Ave Teoville 2
    o. Tel # 8263039 / 82670965
    So far wala pa akong naexperience na lost of water sa radiator (knock on wood). For the past 27 months since I acquired my FM (am the 3rd owner), 3 or 4x pa lang ako nag dagdag ng tubig and laging sa reserve lang. Sa service manual ng previous owner walang info kung nag replace radiator. I believe orig pa rin ito.
    Hope this may help sa mga tiga East o may similar problems.
    Aug 2005
    #3047
    Bro nelany, saan yung shop ng roadstar?
    Any telephone number?
    Malamang ito next project ko considering the inputs sa mga meron na. Mataas ang initial investment pero kung makakatipid talaga sa FC eh this is one of the investment na di dapat palampasin. For me secondary na lang ang bilis at ako naman eh pang Nayong Piliino lang mag drive (parang nag-tour sa bagal)
    #3048
    Quote Originally Posted by jcdc View Post
    Hi pr462, sir do you have contacts of carland? San din located yung Malugay? Wala kasi talaga ako mahanap sa banaue ng mga leds for dash eh, hirap daw maghanap nun kasi rice bulbs daw yun.. TIA sir
    jcdc sir, apologies for the delay,hectic xmas,i am llloking for the calling card but can't find it, if you are along sshiway going towards buendia, kaliwa ka sa ilalim ng flyover, tawid ka ng riles ng tren and they should be on your left. look for the owner si koy or si peng. they should be able to help you. may mobile ako nila kaya lang bumagsak telepono ko kahapon at gumulong gulong pababa ng kalye, ayun blackout. pag napaanda ko forward ko mobile nila so you can inquire before going.
    flicker if ur reading this tks for ur recommendation on knn, it helps.
    boss pb, read in another forum may expy ka,kamusta na siya?
    to all of you out there maligayang pasko and may you have a spectacular 2009.
    #3049
    Quote Originally Posted by dcarin14 View Post
    Bro sa Makati, address ay 8838 Estrella St., Barangay San Antonio, Makati. Tel # 8962913, 8962974, 8961211.
    Look for Cathy. They need to order pa ito so it will take at least 1 day bago mo makuha yung filter.
    #3050
    Kapapalit ko lang din ng coolant last month ng nagpa change oil ako. Since hindi tinangal yung hose sa makina at yung ilalim lang ng radiator plug ang tinangal ang lumabas lang ay yung coolant. Wala akong nakitang ibang kulay except yung green na coolant. I'm using Motocraft na coolant at Absolute na DI water also.
    Share mo kung ok yung Cyclo flush pag natapos mo. Yung Turko gamit ko yan pang tangal ng kalawang sa mga metal. I don't think na pwede yan pang flush ng radiator.
    Baka pati yung makina i flush out niya for a new one.
    MERRY CHRISTMAS AND PROPEROUS NEW YEAR TO ALL!!:santas:
