Page 297 of 330 FirstFirst ... 197247287293294295296297298299300301307 ... LastLast
Results 5,921 to 5,940 of 6591
    Jun 2004
    #5921
    Quote Originally Posted by strike freedom View Post
    guys saan kaya merong carbon brush for power windows ng pajero? I assume that gen 2 and gen 2.5 have the same power window mechanism... kasi may topak na yung windows sa driver's side ko. diba pag push mo ng switch sa power window ng driver's side at bumaba na yung window fully mag o-automatic click yung switch? away na yung sakin e.. then i have to wait for a minute or two para magsara uli yung window. need help guys.. thanks!
    I suggest dalin mo rig mo either sa Rey's Electrical (15th Ave Cubao) or sa Wizzard (Morato QC) to have your power window swtch checked/repaired.
    Oct 2009
    #5922
    yong royal purple po b mga sir magandang gamitin sa engine natin?
    Jun 2004
    #5923
    Quote Originally Posted by rols View Post
    definitely. i'm using RP 15w-40 fully synthetic. tahimik makina mo
    Oct 2009
    #5924
    Ok salamat sir archijardy yon na gagamitin ko sa next change oil ko no need na b maglagay ng additives?
    #5925
    +1 ako dito
    Quote Originally Posted by paj4x4 View Post
    Ako Mobil Delvac 15w-40. I change oil and oil filter every 4k km.
    Dec 2009
    #5926
    +1 ako dito
    castrol crb turbo
    Feb 2009
    #5927
    Hi mga Tsikoteers! My ride is not actually a FM but a JDM 1994 paj with 4m40 engine so medyo pareho rin ang mga mechanicals. My question is about the small motor for the intercooler. The brushes are almost spent. Where can I buy these carbon brushes. Thanks in advance guys!
    Jun 2004
    #5928
    wag kasi masisira ung efficiency nung RP fullsyn
    Oct 2009
    #5929
    Ok po kailan po ulit tayo magkakaroon ng EB mga kapaj hehehe
    Feb 2009
    #5930
    Question lang po. Yung ho bang transfer case has its own oil or does it share oil with the transmission? My engine is 4m40 and automatic po yung tranny. Nag pa change oil for engine, tranny, front and rear diff but I don't know if the tranfer case ay na change oil? Thanks in advance
    Jun 2004
    #5931
    tatoski - yes the TCase has its own lubricant. On my Paj ('99 M/T 4x4) the TCase requires Hyphoid gear oil (API GL4 or higher) SAE 75/90w.
    #5932
    BG at PB thanks nag palit na ame ng froent wheel bearing nawala na yung tunog.... koyo yung brand inner and outer both sides coast me 3500 pati labor na hehehe. ok na yun diba?
    Then dun sa shocks yung lights nahugot lang pala yung cable sa swicth nya
    Thanks ulit laki tulong talag dito
    #5933
    No problem bro, glad to be of help...
    Quote Originally Posted by johnedwinf View Post
    #5934
    Quote Originally Posted by junerski View Post
    good day
    ano ginagamit ninyo engine oil for our 4m40 engine... ever since kasi turbo xp lang ginagamit ko. gusto ko naman sumubok ng ibang brands. thanks
    Ako actually gamit ko REV-X All terrain Fully synthetic for 10k km
    May 2008
    #5935
    Came across this FM over the net. May provision ba talaga yung PHDM bumper natin for fog lamps? Magkano kaya yung whole set? Plan to set up DRL (day running lights) through the assembly just in case.
    Mar 2003
    #5936
    reep, yups pwede lagyan, orig is 20k. pag taiwan mga 3.5 to 4k dati. di nga lang oem switch pag taiwan. taiwan lang yung akin.
    #5937
    kamusta na mga kapwa ko pajero users! matagal-tagal na ko hindi nakakapag-post gawa nang server downtime ng tsikot
    RP user din ako dito and 2nd time ko na gumamit nito. ok na ok ang langis na ito. di ka magsisisi sa pag-invest sa langis na ito. at tama si sir archi, wag mo lalagyan ng additives. kaso ang ginawa ko nung 1st time ko gumamit ng rp, nagpa-flushing muna ako para matanggal ang dati niyang langis.
    pb, may bad news ako dun sa k&n filter ko. mas matangkad ang k&n kesa sa oem filter. nagkasya naman sa air filter box ko pero yun nga lang, may konting siwang sa takip. tuloy napapaisip akong i-convert sa open type ang intake system ko
    May 2008
    #5938
    With 4k kumpleto na ba yun sir pb - fogs assembly, socket (HB3/4?), harness, switch? Hanap na lang siguro ako ng OEM switch if ever.
    Jun 2008
    #5939
    magandang araw mga tol,
    tanong ko lang kung meron nakakaalam kung saan makakabili ng foglamps para sa fieldmaster? basag ang lens nung nasa kanan ko. i replaced the bulb once. palagay ko nagsi-seep-in ang tubig dahil napundi lang.
    thanks much!
    Mar 2003
    #5940
    testy, yung bumili ng knn ko dati fit naman, I wonder why di pumasok sayo.
    reep, yes complete na yun, oem switch is 1.5k dati. same sa experience ni kalimbahari, taiwan fogs are prone to moisture pag maulan, i dunno about oem.
    kalimbahari, sa procars and jaffas sa banawe meron, dun ako nagpakabit. pag nababasag lens usually na overtighten yung screws, pag binabalik.
