Medyo shallow question, kamusta yung speakers nito? Medyo deal breaker kasi sakin pag pangit yung speakers.
Medyo bitin lalo na sa bass side kahit adjust mo pa eq. Lalo na if your coming from a sedan kahit stock speakers, nakaka tulong rin kasi ung trunk to enchance bass kahit 6" or 6x9 na speaker lang sa likod ng sedans.
Everest ang may pinakamagandang SQ sa big 3 since may center speaker and rear subwoofer and built in amplifier na sya in stock form.
Upgrade na lang speaker and add ka na lang sub and amp sa likod if you dont like eve naman.
Try this setting. Enough bass on most songs. Use wired connection for your mobile phones. Hindi maganda kung bluetooth connection
Sir hindi kita masagot dyan kasi un nga po halos 1 week ko lang sia nagamit, pero AFAIK.hindi naman mapress ang electronic parking break unless naka press ka sa break pad. thought I am not 100% about this..madami po guro’s dito mas mkakasagot at makakapagconfirm nito
What Happens If You Pull The Electronic Parking Brake WHILE driving ? - YouTube
^^not dead sure if same sa monty. Ang mas concern ko sa ebrake if nagleak brake lines mo. Total tirik ka, unlike may emergency brake ka. I was able to limp home gamit ko is hand brake lang ng masira seal ng brake ko and naubos lahat brake fluid.
Regarding cable, design yan ng engrs. not to make putol unless di nammaintain oto or worn out na talaga ung cable. I do AutoX racing and circuit racing, laging bugbog sarado ebrake sa akin pero never pa ako naputulan cable.
Regarding sa brake locking up using hand brake, depende sa adjustment ng hand brake and sa layout ng power. If frontwheel drive. Madali malock up rear wheel using e-brake. If RWD or 4wd mahirap ilock kahit sagad hand brake since labanan ng engine ung e-brake unless you put it in nuetral or do clutch kick...
Maganda ang sounds at that levels, but You can also press loudness then lower the settings even more sa 64 125 250 and 500 range mga 2 notches down pa and check kung saan ka comfortable. This reply refers to the eq settings posted by Sir JJB
5 days straight na to... sa morning yung 1st time ko bubuksan ung oto lagi matigas yung brake. Dinidiinan ko na lang maigi ung brake para mastart ko lang si monty... after nun OK na yung brake.
Nareport ko na sa CASA, sabi itatawag sa sta rosa... wala namang feedback...
im planning to get a montero this march . Which color is the most in demand. Easily to
maintain as well as repair
Ung sa kin, namomoblema ako sa gawa ng labas. di pantay kulay at dinikitan ng alikabok ang paint... Pinababalik ako bukas for repaint, sana pumantay na ang kulay. savannah white nga pala...[/QUOTE]
'fuel system service required'
encountered it this morning...ibig sabihin ba papalitin na fuel filter?
thanks
Sent from my SM-G925F using Tapatalk
