Based on my experience, even after you have set it based on the instructions on the manual, once you turned on the AC using the AUTO, there are times that the RECIRC automatically turns off, I only start noticing it when I am beginning to smell fumes from inside the cabin. Anyways, that's good to hear that the newer models doesn't turn off anymore when you use AUTO, mine is 2016 model.
2018 GT variants has only alarm system.
Only 1 back up fog lights on left side.
Sent from my iPhone X using Tapatalk
If it's in full auto mode, I think the system will adjust based on inside ambient temp. If it deems it doesn't need to turn aircon to achieve target temp, it will just use fan. True in the case when you initially start your vehicle early in the morning. (malamig na yung loob ng kotse beforehand)
Imagine kung nasa Baguio ka and ang ambient temp is already at 20 deg Celsius tapos ang nilagay mo na target temp ay 24 deg Celsius. Then the system will sense that it's already cold inside the cabin and will just turn on the fan instead of the AC.
Ang problema na lang ay yung recirc mode. Sa ibang bansa kasi, default mode off yun to introduce fresh air sa loob ng sasakyan. Eh dito sa atin, usok lang papasok.
Sent from my ONEPLUS A3000 using Tapatalk
For peace of mind..
Manual setting lang ang A/C...
Since dual climate control ang 3rd Gen. maliban lang kung M/T..
self adjustment talaga yan..
sa 2nd gen. namin, ginagamit ko lang ang auto-climate pag summer..
pero kung tag-ulan, mas mainam na manual control ko ang A/C for desired temp at hindi mag auto-disable ang recirculated air from inside..
kung sobrang lamig talaga or heavy rain, pwedeng gamitin ang Heater mode, just simply turning off the snowflake, and adjust yung temp.
hindi magkakaroon ng fog/moisture ang loob ng windshield/windows..
^thats a bad idea, eschew auto setting
Sent from my GT-P3110 using Tsikot Forums mobile app
Sa malayong probinsya ko lang na off ang recirc mode ng auto ko. Kung saan sariwang hangin ang papasok sa loob. Sa syudad, puro usok ng tambutso pasok.
Okay lang ba sa first timer na montero ang unang ida drive na sasakyan?
