ilang years ba warranty ng a/c? hindi ba 3 yrs din same ng ibang parts ng car?Our car is already 2 yrs na po. model 2016 po siya.
paano po ba iset yung average fuel consumption na di nagrereset?everytime kasi pinatay ko engine ay nagiging zero ulit yung average consumption.
Already tried sa settings- avg then M pero bumabalik parin sa A once na chineck ko sa settings ulit
Good looking na compare sa previous version mataas yung likod, mas maganda na tail lights. [emoji106]
strada followed montys design, monty might follow expander's
sakop pa kaya ng warranty yung wheel alignment? after my 10k pms may kabig sa right. but before PMS wala naman kabig.
Sent from my heart using Tapatalk
Check tire pressure first ... Never adjust factory alignment unless necessary ... New vehicles rarely need alignment ... Even older vehicles don't need it ... What happens to older vehicles is that the suspension parts wear out ... First thing some owners do is have alignment ... Then the suspension symptoms appear, then they replace suspension parts and what do you know ... After replacing suspension part(s), they need another alignment to return it back to the original settings ...
it is good practice, to check and adjust alignment, whenever suspension parts are replaced.
Usually better to have the alignment and rotation done outside. Pag casa kasi hndi na mapagkakatiwalaan at hndi mo nakikita at nakakausap mechanic.
Mga SA scripted na sinasabi, madalas wlang alam. Sinasabi lang nila pero hndi naman tlga ginagawa. So nagbabayad ka ng mahal na labor for nothing.
Hi, anyone experienced a random chirp sound (only a single chirp) in the engine. Sometimes it happens during at the first rev or when it is up / down shifting. But you can not really replicate the sound consistently, it is very random.
I am thinking is it the turbo noise chirp, is this normal? maybe the drive (accesory) belt. I am not sure if it was present when it was new. I just started to notice it maybe after a year.
Montero Model is 2017 GLS AT
Complain ko lang ngayon is ramdam ko yung upshift and downshift ng tyranny, especially cruising at low speed. Maybe am not observant before.
Sent from my SM-A600G using Tapatalk
Ok lang ba mineral oil lang muna sa 1k PMS? Then mineral ulet sa 5k, tapos sa 10k na lang ako mag fully synthetic? Mas mura kasi sya kesa fully syn sa 1k then top up sa 5k.
Tanong ko lang kung may nakaexperience na nito. Biglang humina hatak ni monty GLX2017. Dati pag naka2nd gear at rpm mo lagpas bg 2000 kakagat ung turbo agad at ramdam mong bibilis ka. Ngaun 3k rpm na 40kph pa rin takbo ko * 2nd gear. Ano kaya problem nito? Nilabas ko na kasi sa casa 35k na mileage ko ngaun
