Page 191 of 210 FirstFirst ... 91141181187188189190191192193194195201 ... LastLast
Results 3,801 to 3,820 of 7539
    good observation. shock end was probably hit by the steering linkage/arm. driver probably hit a big rock in an off-road adventure. this wouldnt have happened along edsa unless it really did lol.
    Luma na yung tama sa shocks. Hindi lang siguro aware yung owner na me tama na yung pang ilalim niya sa previous na nang yari sa kanya.
    Nov 2007
    Baka kasama yan sa Kobe steel scandal.
    The Kobe Steel scandal: What we know so far
    But looking closely, mukhang may lumang tama sa tie rod end, malapit sa naputol. Nag offroad siguro or tumama sa bangketa?
    Aug 2017
    Aksidente yan, may marks sa tires and mags. Pwede nahulog tapos naiahon but nagkatama na pati shock prior sa pagkakaputol sa ESDA.
    Looks like accident nga ang culprit prior ng pagkaputol with a clear marks on tire and mags as evidence.
    Quote Originally Posted by JJB View Post
    Yes half cut lang ang malinis ang putol and yung half portion ng tire rod end iba ang shape.
    Sent from my iPhone X using Tapatalk
    Nov 2017
    Buti sa edsa inabot kung sa expressway yan aksidente yan.
    Anong yr daw ng montero? At isolated case lang kaya ito?
    Feb 2011
    Also napansin ko sa picture na naka-counter flow yung white montero. baka tinamaan then he spun around. so im assuming accident yan
    May 2018
    Please pa help naman. yung monty ko nadamage yung front chrome grill yung upper part kasama yung mitsubishi logo, saan kaya makakabili ng replacement na mura?, sa banawe ba meron nun?, at kung magkano..? thanks in advance.
    Quote Originally Posted by max04 View Post
    try the cathay centers in banawe QC and evangelista makati.
    be prepared to pay thru the nose, as these guys know how desperate we are, looking for these items in the cathay centers.
    perhaps you should also inquire how much it costs, brand new. baka kaunti lang ang pagkaka-iba.
    baka nga mas mura pa ang brand new.
    plastic, right? plastic is cheaper than metal.
    Jan 2018
    I just got my monty gls premium for less than a month now. I notice na ung bypass switch ng kambyo eh parang walang takip. Ganun ba talaga yun? Yung parang maliit rectangular shape sa may bandang taas above the parking ‘P’ symbol. I’ll try to take a picture once i get back home, coding lang kasi.
    Jan 2018
    Mga sirs ganyan po ba talaga yan walang takip?
    Apr 2012
    Quote Originally Posted by ayingyang View Post
    I think it is. Mines like that too.
    Aug 2017
    Thats normal po.
    how is it activated?
    it looks empty!
    Dec 2017
    it looks empty!
    If this is similar to what I have, that thing is a kind of switch. When the engine is off, you cannot put the transmission in neutral. You need to use a screwdriver to remove that and push something beneath so that you can depress the button on your gear shifter to put it in neutral.
    Jan 2018
    +1 to this. May takip kasi yung ibang automatic na sasakyan na nagmit ko, i’m not sure lang sa monty.
    Aug 2017
    it looks empty!
    Just depressed it with your key on the hole to change the shift if necessary when engine is not running or cannot be started.
    Mar 2003
    Hello guys... has anyone experience this message: IMMOBILIZER SYSTEM SERVICE REQUIRED,
    my car (GLS, Automatic, 2017) wont start, but I can lock and unlock the doors, I have all original keys. The car is used daily, so it never stuck up.
    1. I have inserted the key Fob in its dock (side console driver side) - didnt work
    2. I have lock and unlock the car 5 times (got it from internet but Australia site) - didnt work
    3. I called Citimotors, (where i normally do my service)... their recommendation is have my car towed, Really?!
    Is there a simple alternative... I feel its a simple problem, but solution is way too complicated... to have it towed will already set me back 2K.... Actually its the hassle that annoys me... bottom line, my car is stranded?!
    Please point me to any leads... Thanks
    Nov 2007
    Quote Originally Posted by cta2 View Post
    Check your insurance if they have free towing
    Apr 2016
    This happened to me sir, pero yung sakin na solve ko by replacing the Battery. Pag push start mo at nag biblink minsan tapos lumalabas yung "IMMOBILIZER SYSTEM SERVICE REQUIRED" warning, try to check Battery Status syempre off ang engine mo nito. Pag wala pang 12v Dead na ang battery mo nyan, need mo na palitan ng bago.
2016 Mitsubishi Montero
