Page 274 of 294 FirstFirst ... 174224264270271272273274275276277278284 ... LastLast
Results 5,461 to 5,480 of 5877
    May 2011
    #5461
    Map update Version 2.7 now available for download.
    Aug 2011
    #5462
    Quote Originally Posted by jayteecie View Post
    Sir, pardon for my ignorance, san ba pede mag download?
    Posted via Tsikot Mobile App
    Feb 2014
    #5463
    Quote Originally Posted by prettygrace View Post
    I'd like to recommend my very generous SA of citimotors makati. If you want very good deals txt him at +639174635633 Paul Enriquez. im not related or anything to him sobra natuwa lang ako sa kanya kase he's super honest and nice. bank p.o. ako btw pero sa dame ng nakausap ko dealers at ni-haggle sya na the best!
    Sa kanya din namin nakuha yung Mirage G4 namin. Mabait kausap at honest din. Naka kuha pa ako ng free rain visor aside dun sa mga regular freebies.
    #5464
    Quote Originally Posted by Tj_abs View Post
    Log on to Inav.ph and choose the new updates...the instructions are quite easy to follow.. HTH :D
    Aug 2011
    #5465
    Quote Originally Posted by BoyBawang View Post
    Hehe thank you sir. Iba na talaga bumabata
    #5466
    ok ba yung shell nitro plus sa mirage?
    Aug 2004
    #5467
    Quote Originally Posted by bosbik View Post
    No reason to use it if you don't have a high compression or turbocharged engine.
    Stick to FuelSave.
    #5468
    Stick to FuelSave.
    Mas mura Coke if you get V-Power. 1,500 lang, may free Coke na. Sa FuelSave 2k pa hehehe.
    #5469
    ahh....so no benefit yung nitro plus on the mirage?
    #5470
    Nitro+ uses higher-quality base fuel (which also has higher RON). However, as previously mentioned, higher RON itself is not beneficial for ordinary cars.
    The other difference of Nitro+ from FuelSave (and same with XCS from Xtra) are the additives used. Usually, premium gasoline has more detergents that help keep your engine lubricated and clean.
    Of course, the actual effect of this on your driving varies per car and driver. So it's best to try and compare full tanks of regular and premium gasoline.
    #5471
    hey..thanks..i will definitely try and see if there is a noticeable difference when using fuelsave
    Aug 2004
    #5472
    Our Mirage uses Fuelsave most the time. Sometime when I feel generous I fill it up with Nitro+ or Caltex Gold to clean the fuel system.
    Aug 2011
    #5473
    Stick to FuelSave.
    Sir niky correct me if im wrong, ito ba yung 91 octane level ng shell with 10% ethanol? Base on my experience na try ko ilagay sa mirage 91 octane rating ( caltex )hindi maganda ang takbo ng engine medyo sluggish but nag switch ako sa 95 octane ( gold ) medyo gumanda ang takbo at less noise sa engine. Question, Is it worth paying high octane rating sa engine ng mirage? How about using ethanol combine with premium gasoline? Is it compatible sa engine ng mirage?TIA
    Aug 2004
    #5474
    IIRC all gasolines (except for Blaze 100) are 10% ethanol by law. I also experience sluggishness and more engine noise on 91 octane fuels that's why I mix it with higher octane variants every now and then
    #5475
    91 RON is actually 88 RON base fuel with ethanol (increases RON).
    95 RON is actually 92 RON base fuel with ethanol.
    However, when you read in your manual that the car needs 91 RON, it doesn't matter if it's pure 91 RON or if it's 88 RON enhanced with ethanol.
    #5476
    Sir bosbik,
    Kung about po sa fuel, about sa difference ng regular at premium (generalized)
    Regular --- medyo mataas ang flash point.. (matagal i-burn up ng spark-plug)
    Premium ---- mababa ang flash piont (mas mabilis i-burn up ng spark-plug)
    Although na hindi sila nagkakalayo po ng flash point, at pareho silang "gasoline".
    Kung sa regular,
    Advantage: mas mura at mas maraming karga sa fuel tank,
    Disadvantage po: , slow peak acceleration, lalo sa paakyat, or in a certain overtake situation,
    pansinin nyo po yung mga sasakyan parang humihilik (knocking sound [valves]) during uphill, or overtaking.
    kung MT ang transmission po, to compensate yung lack power, change to a certain gear, and medyo madiin sa gas para ma-compensate yung power, para iwas stall or hindi mabitin sa overtaking,
    kung sa AT naman, need to step up the accelerator quite hard, or shift it in a lower gear..
    (in short po, downshift lagi ang gagawin)
    Sa Premium,
    Advantage: Mas mabilis mag burn up yung gasoline sa spark plug, yung FC, will improve better + yung peak performance, will be always ready to max. performance
    kahit sa uphill situation or overtaking situation, instead of downshift, pag kaya na mag accelerate sa low gear, pwede na i-upshift,
    and yung stepping up sa acceleration pedal, hindi kailangan ng heavy application...
    Disadvantage: Pricey,
    In short po Sir bosbik, kahit ano po na fuel na ikarga, as long as po na gasoline
    kahit 91, 93, 95, 97, or 100 ang octane rating. no problem po yan,
    Kahit ano po na displacement less than 1.0 or above,
    as long as na "gasoline engine"
    walang problem po yan..
    Safe driving po Sir! (Y)
    Apr 2012
    #5477
    sino po sa inyo nagpakabit ng bosch europa horns? saan po ninyo nilagay yung horns mismo? tia!
    Aug 2004
    #5478
    Actually matters if you leave the gasoline in the tank too long. While gasoline naturally goes bad... the easy evaporation of ethanol means it loses its efficiency as an octane booster much faster. If you don't drive a lot, it is sometimes a good idea to go for a higher octane fuel or even go for Blaze (no ethanol)
    Mar 2004
    #5479
    ^^^ Or you can fill up with just a week's worth of lower octane fuel.
    Aug 2011
    #5480
    Thank you sir
2013 Mitsubishi Mirage
