Results 5,491 to 5,500 of 5870
June 26th, 2014 10:29 PM #5491
Sir niky correct me if im wrong, ito ba yung 91 octane level ng shell with 10% ethanol? Base on my experience na try ko ilagay sa mirage 91 octane rating ( caltex )hindi maganda ang takbo ng engine medyo sluggish but nag switch ako sa 95 octane ( gold ) medyo gumanda ang takbo at less noise sa engine. Question, Is it worth paying high octane rating sa engine ng mirage? How about using ethanol combine with premium gasoline? Is it compatible sa engine ng mirage?TIA
Posted via Tsikot Mobile App
June 26th, 2014 10:31 PM #5492
IIRC all gasolines (except for Blaze 100) are 10% ethanol by law. I also experience sluggishness and more engine noise on 91 octane fuels that's why I mix it with higher octane variants every now and then
June 27th, 2014 12:55 AM #5493
91 RON is actually 88 RON base fuel with ethanol (increases RON).
95 RON is actually 92 RON base fuel with ethanol.
However, when you read in your manual that the car needs 91 RON, it doesn't matter if it's pure 91 RON or if it's 88 RON enhanced with ethanol.
June 27th, 2014 02:04 AM #5494
Sir bosbik,
Kung about po sa fuel, about sa difference ng regular at premium (generalized)
Regular --- medyo mataas ang flash point.. (matagal i-burn up ng spark-plug)
Premium ---- mababa ang flash piont (mas mabilis i-burn up ng spark-plug)
Although na hindi sila nagkakalayo po ng flash point, at pareho silang "gasoline".
Kung sa regular,
Advantage: mas mura at mas maraming karga sa fuel tank,
Disadvantage po: , slow peak acceleration, lalo sa paakyat, or in a certain overtake situation,
pansinin nyo po yung mga sasakyan parang humihilik (knocking sound [valves]) during uphill, or overtaking.
kung MT ang transmission po, to compensate yung lack power, change to a certain gear, and medyo madiin sa gas para ma-compensate yung power, para iwas stall or hindi mabitin sa overtaking,
kung sa AT naman, need to step up the accelerator quite hard, or shift it in a lower gear..
(in short po, downshift lagi ang gagawin)
Sa Premium,
Advantage: Mas mabilis mag burn up yung gasoline sa spark plug, yung FC, will improve better + yung peak performance, will be always ready to max. performance
kahit sa uphill situation or overtaking situation, instead of downshift, pag kaya na mag accelerate sa low gear, pwede na i-upshift,
and yung stepping up sa acceleration pedal, hindi kailangan ng heavy application...
Disadvantage: Pricey,
In short po Sir bosbik, kahit ano po na fuel na ikarga, as long as po na gasoline
kahit 91, 93, 95, 97, or 100 ang octane rating. no problem po yan,
Kahit ano po na displacement less than 1.0 or above,
as long as na "gasoline engine"
walang problem po yan..
Safe driving po Sir! (Y)
- Apr 2012
- 134
June 27th, 2014 12:04 PM #5495sino po sa inyo nagpakabit ng bosch europa horns? saan po ninyo nilagay yung horns mismo? tia!
June 27th, 2014 09:32 PM #5496
Actually matters if you leave the gasoline in the tank too long. While gasoline naturally goes bad... the easy evaporation of ethanol means it loses its efficiency as an octane booster much faster. If you don't drive a lot, it is sometimes a good idea to go for a higher octane fuel or even go for Blaze (no ethanol)
June 27th, 2014 10:19 PM #5497
^^^ Or you can fill up with just a week's worth of lower octane fuel.
June 28th, 2014 08:13 PM #5498
June 28th, 2014 10:52 PM #5499
91 is the minimum required, considering what is available in the market (ethanol mix) & the scruples of other entrepreneurs (selling below rated gasoline)
We are better off with octane rating higher than the minimum recommended.
A 95 octane dissipated value could be pegged at 92 octane which still meets the minimum requirement while a 91 dissipating at 88 is below minimum required
Posted via Tsikot Mobile AppLast edited by kisshmet; June 28th, 2014 at 11:05 PM.
- Feb 2011
- 129
July 22nd, 2014 09:41 PM #5500hi guys
I am gonna inspect this coming a weekend a repo Mirage GLX CVT model. There is limited info on the net like it has clocked in a 19km already so I need to check it onsite. What are the things to check?
high idle RPM at engine start
