Page 140 of 294 FirstFirst ... 4090130136137138139140141142143144150190240 ... LastLast
Results 2,781 to 2,800 of 5877
    #2781
    Quote Originally Posted by ratchet23 View Post
    Got the Savanna White GLS CVT last friday. already encountered four problems.
    - off from the dealership, I filled the tank full at a station, then the mirage won't start.
    - the driver door panel is not properly screwed/clipped. may lagatok pag hinihila.
    - the airbag malfunction indicator is lit up from day 1. had it fixed through the dealerships diagnostic software.
    - there is a high pitch noise while running with handbrake and the brake not pressed.
    the FC as well is not promising as of the moment.
    Ayaw magstart? Bat kaya?
    Sent from my GT-P7310 using Tapatalk 2
    Dec 2009
    #2782
    Quote Originally Posted by a329 View Post
    Im not experiencing any "tok" sound po. Yung engine noise, same as mine, 3 cylinder kasi e.
    ang puna ko lang po talaga is the shifting of gears sa M/T. di smooth, parang sumasabit somewhere ang feeling... bakit po kaya ganon, ung mga naka M/T ganeto rin po bang ang experience nyo?
    diin mo ng husto tapak sa clutch
    Dec 2009
    #2783
    one thing i noticed when i inspected my unit for the first time is the battery. its not maintenance free & only the + terminal is covered with red rubber. the negative terminal doesnt have a black rubber cover
    Aug 2012
    #2784
    ganyan din po yung isa naming car when we got it a few years back, not maintenance free and only the + terminal is covered w/ red rubber.. sabi nila ganyan daw talaga un, though i didnt ask na kung bakit.hehe :D
    re: the clutch, kahit po diin na ung clutch, di parin smooth.. yung sanyo ba di ganeto? swabe ba?
    #2785
    hindi talaga maintenance free ang battery nakiata ko na sa factory picture sa thailand on topgear ph. ang brand pa yata is HITACHI AT GS GANYAN NAKA KABIT SA MONTERO SPORT. BUTI PA PAG LOCAL ASSEMBOLED MAINTENANCE FREE NA ANG STOCK BATTERY. AT DOON SA TERMINAL NA NEGATIVE WALA TALAGA RUBBER COVER KAHIT SA IBANG BRAND KAHIT IYONG XWIND NG TATAY KO WALA DIN RUBBER COVER ANG NEGATIVE TERMINAL
    Mar 2012
    #2786
    Quote Originally Posted by nrthstr View Post
    Valle Verde Group din here, still a negativ kay SA, Bad Trip alis na ko bukas, and balik ako 2nd week ng Dec na, pitikin ko putotoy SA ko pag ilabas nya yan ng wala ako......
    may inooffer na black GLS MT saken SA ko wala pa daw talaga yung preferred color ko. I refused intay ko na lang yung color of my choice, baka sa inyo may gusto ng black its up for grabs...
    #2787
    GLS ba yung sayo? Kaya daw natatagalan release ng GLS models ng planta kasi iniinstall and configure pa daw yung GPS. Puro GLX daw dumadating sa kanila eh.
    Dec 2009
    #2788
    takaw tagas kasi yan ganyan, acidic pa naman ang battery fluid, malakas makakalawang yun
    GLX-CVT yun kinuha ko
    #2789
    Upgrade to an Amaron battery? Hehe.
    Only the positive terminal is covered since the vehicle uses a negative body ground system and it wouldnt matter if the hood actually made contact with the negative terminal od the battery.
    Dec 2009
    #2790
    ^the hood will never get into contact with the battery terminal because there is a heat insulation covering attached underneath the hood itself
    tsaka hindi kasi motolite baka hindi tumagal
    #2791
    That insulating thing is just about worn down on my 95 Toyota. But the terminal cover seems to be holding up well.
    The terminal cover also averted a possible disaster when a pal set some tools down on the battery during routine maintenance. One end of the long wrench landed on the cover, the other landed on the terminal cover. Hehe
    Nov 2012
    #2792
    Wow atras ka agad sir hehehe
    Di naman. Mahabang kwento pero may isa pa akong reservsion..
    Aug 2008
    #2793
    I suspect yung Alarm na locally installed lalo na kung meron tong immobilizer function. kasi dinemo sakin kung pano i disable yung alarm once na nagloko yung Smart Key. then yun nung pinatay ko ayaw magstart. pinress ko yung unlock then push start, gumana na.
    In case pala yung Key nawalan ng battery, open the car with the physical key at the passenger side door, this will trigger the alarm. so kailangan i disable yung alarm by using the override/valet switch located under the dash on the drivers side.
    mejo dissapointing yung mga problems na lumabas since kalalabas palang. pero kayang kaya pa naman ayusin ng CASA.
    Dec 2009
    #2794
    ^pag natagalan nilang ayusin yang new ride mo, request for a service unit, para may nagagamit ka
    hassle yan eh
    Dec 2009
    #2795
    its safer to have both terminals covered with insulation lalo na pag kailangang tangalin yun battery to replenish the batt fluid
    pero kung nagtitipid pwede na nga yung isa lang, extra ingat na lang ng hindi mashort ng wrench yun 2 terminals ng batt
    Sep 2012
    #2796
    Quote Originally Posted by machogwapito_02 View Post
    Goy my glx cvt today. Nakasabay ko pa ng release si benjtot (d ko sure kung tama spelling). Pareho kme nagaaccess ng tsikot forum dun. =) So far so good, kya lang wla man lang light yung sa tranny (P, FFd,R, D, B). Mine has 18kms pag la bas ng casa, drove for a 10kms palang and MID shows 17.6 km/l. Mine has EWD and car care kit
    Sir machogwapito nice meeting you, see u soon pagnasama sama na mirage owners. Same as mine 18kms paglabas ng casa. Siguro by tom ko pa masimulang bantayan fc.
    Blue cvt pala sakin mga bro.
    Nov 2012
    #2797
    Sir, yun ba yung red button sa ilalim ng drivers side paraaoverride yung alarm. Thanks
    Aug 2012
    #2798
    Quote Originally Posted by babam31 View Post
    Pano kaya paganahin yung tv, or i just have no signal.
    bibilhan nyo pa po ng tv tuner.
    after change oil tune-up, magkakaroon po ng pagbabago yan sa fc.
    Sep 2012
    #2799
    sa mga nakakuha na ng unit nila, wala ba talagang kasamang Early Warning Device?
    inspected my unit earlier, the only thing i saw was the jack & some tools
    Meron yung sa akin kasamang EWD.
    Sep 2012
    #2800
    Quote Originally Posted by Deobulakenyo View Post
    Wow.
    Nobody will beat this
    Galing ng 27km/l ni chewcandy. Yung highest ko is 23km/l lang, pure highway pa. hehe
    Yan ang mas reliable kase long drives * 268km trip.
    Yan ang sinasabi ko na kaya ibeat ni CVT ang M/T. Depends on driving habit, magaan ang paa.
2013 Mitsubishi Mirage
