Results 2,781 to 2,790 of 5870
November 26th, 2012 10:00 PM #2781
November 26th, 2012 10:22 PM #2783
one thing i noticed when i inspected my unit for the first time is the battery. its not maintenance free & only the + terminal is covered with red rubber. the negative terminal doesnt have a black rubber cover
- Aug 2012
- 23
November 26th, 2012 10:28 PM #2784ganyan din po yung isa naming car when we got it a few years back, not maintenance free and only the + terminal is covered w/ red rubber.. sabi nila ganyan daw talaga un, though i didnt ask na kung bakit.hehe :D
re: the clutch, kahit po diin na ung clutch, di parin smooth.. yung sanyo ba di ganeto? swabe ba?
- Oct 2012
- 49
November 26th, 2012 10:30 PM #2785hindi talaga maintenance free ang battery nakiata ko na sa factory picture sa thailand on topgear ph. ang brand pa yata is HITACHI AT GS GANYAN NAKA KABIT SA MONTERO SPORT. BUTI PA PAG LOCAL ASSEMBOLED MAINTENANCE FREE NA ANG STOCK BATTERY. AT DOON SA TERMINAL NA NEGATIVE WALA TALAGA RUBBER COVER KAHIT SA IBANG BRAND KAHIT IYONG XWIND NG TATAY KO WALA DIN RUBBER COVER ANG NEGATIVE TERMINAL
November 26th, 2012 10:31 PM #2786
BANNED BANNED BANNED
- Oct 2012
- 236
November 26th, 2012 11:13 PM #2787
November 26th, 2012 11:55 PM #2788
November 27th, 2012 12:12 AM #2789
Upgrade to an Amaron battery? Hehe.
Only the positive terminal is covered since the vehicle uses a negative body ground system and it wouldnt matter if the hood actually made contact with the negative terminal od the battery.
November 27th, 2012 12:21 AM #2790
^the hood will never get into contact with the battery terminal because there is a heat insulation covering attached underneath the hood itself
tsaka hindi kasi motolite baka hindi tumagal
high idle RPM at engine start
