Page 205 of 345 FirstFirst ... 105155195201202203204205206207208209215255305 ... LastLast
Results 4,081 to 4,100 of 6900
    Mar 2011
    #4081
    Naging general monty na.
    Zix paano mo drain yung excess atf? Ilan bawas mo. Any difference in performance. Baka yan din problem ko.
    Pero factory filled yan. Maybe there is a reason kaya overfillled.
    Pasensya pala di ko na reply pm. Things na ganito makes me think thrice or even more sa pag install tuning box. A happy revving engine will get me nowhere if its stucked in 2nd if you drive it hard.. Uphill lang naman!
    Saka maybe its too late na for me. Youre disposing while im about to upgrade pa lang. Hahaha
    Mar 2011
    #4082
    Alin monty/triton/strada pala ang may oil cooler?. Yung bracket is still there.
    #4083
    Quote Originally Posted by gundam View Post
    thru drain plug sir, sa ilalim ng front passenger side banda yon located. factory filled din yung sakin, sobra. cold temp kasi nila yan i-fill up, syempre alangan naman painitin nila yan eh Brandnew nga, so more or less ang palo niyan sa hot temp. we should base our atf level on hot temp
    Dec 2012
    #4084
    Mga sirs, what do you think will be a good tire thread to buy for a size 18 mags? My preference is 80% comfort and 20% porma since the mags itself will largely contribute sa porma. Thanks in advance for any input.
    Jun 2012
    #4085
    Quote Originally Posted by benjie413 View Post
    Normal naman na tranny ko sa NLEX. Nagloko lang naman uphill climb to Baguio only, a few kilometers before reaching the top. Upon reaching the top, normal na shifting ng tranny ko.
    Nangyari narin sakin to sir, 1 time same Marcos Highway. Tranny stuck sa 2nd gear. nung nasa Town Proper na ok na ung tranny tapos di na ulit bumalik kasi hindi na steep ung mga uphill climb. Pa inform nalang sir kung ano ang feedback ng casa pag nag pacheck ka. TIA!
    Apr 2012
    #4086
    Upgrade for my monty
    Original stanley rear fog
    Sent from my GT-N7100 using Tapatalk 2
    Aug 2012
    #4087
    hi sirs. done traveling my glsv from manila to iloilo. may nakasabay ako glx na black sa roro from roxas mindoro to caticlan. black glx monty kaya lang wala ako chance makausap may dala. just wandering if forumer din dito.hehe jabez yung nasa plate nya e.
    #4088
    Quote Originally Posted by jns888 View Post
    suggestion, get the connection from the front foglamps. mostly kasi ng kakilala ko na naglagay niyan, sa parklights nakakabit. medyo close to oem kung sa front foglamp mo i-connect
    Apr 2012
    #4089
    Thanks zix.
    Meron na ba nakapagactivate using the separate switch same functionality sa mga gtv units? Meron din ba indicator sa panel?
    Mar 2011
    #4090
    Salamat zix.
    #4091
    Thanks zix.
    i think you have to solder a separate led for the panel kasi walang abang. so far wala pa yata nakagawa nung same functionality as the gtv(afaik). kaya para may on/off switch ka, isabay mo sa foglamps
    Jan 2011
    #4092
    Thanks zix.
    sir, you can change your rear bumper harness para OEM pa din yun wiring mo for the rear fog. then get the relay as well, ikabit mo sa slot ng rear fog relay sa ETACS/Fuse Box. Need mo nga lang mag tap ng trigger from the front fog to the rear fog relay para ma activate mo sila ng sabay. For the combi meter indicator, need mo to install/solder a high power LED kasi walang naka-abang...ako, did not go thru the full GTV functionality na kasi need to get the GTV ETACS for that and personally think na hindi na worth pa sya...
    Rear fog lamp with OEM wiring/circuit:
    Rear Bumper Harness - 8518A076
    Rear Fog Relay - MR588567
    #4093
    share lang mga paps..installed platebase
    Mar 2011
    #4094
    Quote Originally Posted by glaks View Post
    Sir same ba yan sa strada?
    #4095
    Mag kaiba sir
    Apr 2011
    #4096
    Mag kaiba sir
    is the platebase OEM? were did you get it and how much?
    Apr 2012
    #4097
    This is really helpful sir. Thanks!
    #4098
    Quote Originally Posted by enigma2036 View Post
    sir hinde sya oem, pero mukha syang oem. PM na lang kita boss
    Oct 2008
    #4099
    sir pa pm din po me kung saan nabili at how much po, thanks po
    Aug 2003
    #4100
    Thanks zix.
    My rear fog is tapped sa parklight but has a separate switch so i can turn it off. It is also wired to light up the rear fog indicator sa panel. I just don't know the details kung saan nag tap yung electrician to make it work.
    My ride is a 2010 GLS 4x4 M/T. Sorry for the blurry pics.
2012 Montero Sport Owners
