Page 208 of 212 FirstFirst ... 108158198204205206207208209210211212 LastLast
Results 4,141 to 4,160 of 6900
    Mar 2018
    Quote Originally Posted by Darkfire View Post
    San po kayu nagpa linis and nagpatightened ng battery terminals niyo?
    Yun ako po, DIY lang hehe.
    You can go to the nearest car battery center to have your car battery checked. They do have tools for that.
    Dec 2018
    Thanks po sir.
    ^ wala bang check engine light?
    pa check mo egr ng monty nyo. Baka madumi na sya masyado o faulty na.
    Better yet puntahan mo si zix or contact him kung hindi ka resident ng manila.
    Bro walang check engine, egr blank na rin ni zix done two years ago, layo kc ng area ko baguio pa, then na try ko na rin naka manual mode so naka "1" or 1st gear sya but very slow moving pa rin saka bibilis pag naka bwelo na, same din pag kahit na D drive kahit pitikin ko yung minus sign ng paddle shift mag (1) sya then pag arangkada very slow pa rin saka bibibilis pag naka bwelo na
    Aug 2017
    Quote Originally Posted by spiderjon96 View Post
    Check your fuel filter po baka need to replace na.
    Sent from my iPhone Xs Max using Tapatalk
    Try removing the mass air flow (MAF) connector, tapos gamitin mo lang siya na unplugged. Balitaan mo kami. Take note , mag CEL yan, hayaan mo lang.
    [QUOTETttyyyyy
    Quote Originally Posted by zix888 View Post
    Bro zix, remove ko na MAF sensor connector, nag CEL sya, lumakas ang hatak "D" drive & manual mode even incline, swabe takbo ng engine then before ko connect ang MAF sensor connector, nilinis ko MAF sensor using MAF sensor cleaner, result same tulad ng dati hirap umarangkada pag incline moving slowly pag naka bwelo saka bibilis ang takbo, note wala na syang CEL
    Dec 2018
    sir zix, inbox full po. please check
    thanks
    Palitan mo lang ang MAF sensor. Ok na yan. Or if ok sayo na may CEL, tanggalin mo na lang ang plug, ok lang yan
    Jan 2019
    Sir napalitan mo na ba MAF sensor mo. Hm ang bili mo?
    Sent from my MI MAX 2 using Tapatalk
    I have gtv version and when i used it yesterday i heard a series of beeps but no indicator are lighting up in the panel/dashboard. it beeps 10 times then stops for around 2 mins then it will beep again then stops again for 2 mins. after doing this cycle 4 or five times, the beeping increased to 20 timres but on a faster rate, then it stops for 2 minutes again and so on.
    Does anyone here experienced this or knows what’s the cause/problem?
    Quote Originally Posted by jakz View Post
    hula lang? handbrakes is still engaged but only by 1 click?
    Jan 2025
    ...same issue po ung sakin...pano po naayos ung beeping sound?...salamat po sa pagtugon...
    May 2017
    Quote Originally Posted by unclepeputs View Post
    dalawang beses ko na lang pinipress ang lock kapag iniiwan ko para turn-off ang alarm.
    Kapag sisindihin mo na ang Montero, wag mo munang sarado ang pintuan para hindi ka uunahan sa pagactivate ng alarm before turning the keys. Kasi kapag naunang nactivate ang alarm mapapansin mo ayaw nang magstart ng Montero
    Check Tpms
    Check Tpms
    I have already disabled the TPMS about 6 mos. ago. Parang sira na kasi sensors na nakakabit sa gulong. I thought at first na baka bigla na-enable ang TPMS, pero wala siya indicator on the head unit display.
    Sent from my CLT-L29 using Tapatalk
    Make sure yung 2 sockets niya na unplug mo sa tpms module para completely disabled siya
    Thank you sir. By the way saan ko makikita itong 2 sockets?
    Jan 2025
    ive got a montero gtv 2012 as i used it yesterday i heard a series of beeps but no indicator lights up in the panel or dashboard. it beeps 10 times then it stops and comes back on after a couple of minutes. It does a couple of cycles then beep becomes faster for around 20 beeps again after a couple of minutes and so on.
    Has anyone experienced this issue before? what may be the probable cause of the issue?.
2012 Montero Sport Owners
