Page 23 of 251 FirstFirst ... 131920212223242526273373123 ... LastLast
Results 441 to 460 of 5006
    Sep 2010
    #441
    the slider works fine for me.
    Feb 2011
    #442
    Quote Originally Posted by zix888 View Post
    Mayroon pa po talaga, kaso exit na ako marilao coming from meycauayan. Try ko next time when i get a chance to pass by sctex
    nice one sir sakin kasi hindi ko pa napapalagpas kahit 140kph tsaka na pag my 5k na~ gamit mo sir ung 28 na mags mo djan?
    May 2004
    #443
    Quote Originally Posted by bjreyesmd View Post
    Tap the fuel tank meter on the MID, and then tap reset. You will see this in the Car Info display of the MID
    this doesnt work for me ayaw mareset
    Apr 2011
    #444
    Quote Originally Posted by Slick50 View Post
    Hi Metslgx,
    The price depends on several components.
    A. Type of Ballast (China, Japan, OEM)
    B. Type of Projector (OEM, FXR, Mini D2s, Mini H1 and etc)
    C. Type of Bulb (Philips +82122, OSRAM, and etc.)
    So the price will vary like ordering set menus at restaurant. I recommend you do your research first at theretrofitsource.com and hidplanet.com Figure out what you want then message Garyq. He will send you a quotation.
    Noted Slick and thanks/
    Apr 2011
    #445
    Me & Ian of Strada club test drove the Montero GTV & Strada GLS Sport VGT.. We both had the same observation that the acceleration of the Strada was faster & the power of the VGT was more felt on the Strada.. As an owner of a 3.2 monty with some minor engine mods i felt that the accleration of the Monty with VGT was just quite similar with my 3.2 monty..
    Hi JPG,
    I would like to think that the reason for the above is that the strada is lighter than the gtv. Does the strada comes with 6 speed auto tranny?
    Feb 2009
    #446
    Sirs, ano ba ok na diesel? Petron or shell? Mas ok ba shell v-power diesel? Will be getting our GLS V on thurs
    #447
    Quote Originally Posted by pogy_uy View Post
    zix888: stock engine yung GTV monty mo running at 185kph? nice one sir! and still the rpm is around 3,000 rpm.
    Yup still stock, end of may pa daw dadating yung tdc commonrail box ko eh. Tama lang din para maicompare talaga difference in power since medyo matagal ko na gamit na stock. Sabay ko na din knfilter para maramdaman pa ang hatak
    #448
    Quote Originally Posted by elisher0210 View Post
    Yup on 28s kaya kailangan talaga open bago makahataw eh, laki ng rotating mass nito kaya hirap ang brakes. Gusto ko nga sana itest ng stock, kaso nakakatamad magpalit ng wheels to oems
    May 2004
    #449
    sir anung brand kinuha nyo at magkano?
    sobrang laki kasi ng price difference nung Racechip pagdating dito sa atin
    Jul 2004
    #450
    Montero Sport GTV does not have Auto Leveling. Please see my video of the cheap plastic Hid Projector they used.
    tama si zix888, the GTV has automatic headlamp levelling
    its that headlamp indicator light beside the controls for the power mirrors
    i just checked page 3-61 of the manual and here is what it says:
    "Automatic headlamp levelling
    Vehicles with discharge headlamps
    this function automatically adjusts the illumination distance of the headlamps according to the number of people and the load in the vehicle
    when the ignition switch is in the "ON" position ad the lamp switch is in the [graphic symbol] position, the illumination distance of the headlamps is automatically adjusted when the vehicle is stopped. xxx"
    ito ang importante at page 3-62:
    "CAUTION
    If the warning lamp stays on or does not illuminate when the ignition switch is turned "ON", it indicates that the automatic headlamp levelling device is not functioning
    Have your vehicle inspected by an authorized MISTUBISHI MOTORS dealer."
    Jul 2010
    #451
    got my montero gls V last april 26. so far no smoke issues until now. i just can't compare it to crosswind on how it consumes diesel. but it outweighs comfort in driving and riding. am still due for first 1K PMS. by the way, ilang weeks po inabot before release ng plate number nyo? i opted for regular plate...
    #452
    Quote Originally Posted by don View Post
    Tdc tech sir. Pero mas mura yun kay tsikot eh, meron nga lang on/off switch and gain control yung nakuha ko
    Apr 2011
    #453
    Quote Originally Posted by romelmd View Post
    march un samin pero till now wala parin akong plate.
    Apr 2011
    #454
    un sakin din...ayos na ayos talaga.
    Feb 2011
    #455
    Got mine Feb and got the plates in 3 weeks. I guess mas mabilis pag special plates. I know on average mga 2 months before you get your plates
    May 2011
    #456
    ALARM QUESTION:
    i've done the steps on switching to valet mode and armed mode. the steps seems to be working (dash lights up, turn indicator lights up)
    BUT there are no changes on the alarm setting aside from the blue bulbs behavior. valet and armed mode are the same, i cant trigger the alarm to sound, i tried to shake the unit, attempt to open locked doors, kick the tires.
    is the anything wrong with my alarm system? i've consulted the manual and the instructions are way different from what has been discussed here. (also tried the manual book instructions)
    Jul 2004
    #457
    Quote Originally Posted by mckoyboni View Post
    ALARM QUESTION:
    the alarm installed is not the same one as in the manual. its an aftermarket alarm installed, perhaps, by winterpine. i am still trying to get a copy of the manual for the alarm
    #458
    Quote Originally Posted by MSviolet901 View Post
    Thank you sir Sinoda for the feedback. Same din po ba yun sa UM, Caloocan?
    My dealer was UMC (SE Lowell). Ok sila kausap.
    May 2011
    #459
    Quote Originally Posted by kutangbato View Post
    Yup! Slider for navigational bar works fine for me as well.
    May 2011
    #460
    Finally, had the time post pics of the OEM back-up camera installed by CASA
    009 by bjreyesmd, on Flickr
    007 by bjreyesmd, on Flickr
    008 by bjreyesmd, on Flickr
    I asked citimotors alabang over the phone if they had this type of camera but they quoted me 8k! Just wondering how is the camera attached to the underside of the door handle - is it bolted on? Winterpine also had cameras but these were either mounted on the bumper or behind the rear window below the 3rd brakelight (adhesive tape) at 8-9k depending on the brand.
    Also, will my warranty be voided if i don't get it from the casa / winterpine?
    Thanks!
2011 Mitsubishi Montero Sport [continued]
