nice talaga sir zix yun mga diy mo. madali lang bang tanggalin yun window control panel kung sakaling maglagay din ako ng LED and do you provide any electronics part/or any circuit (ex. resistor ) para ma control yun supply ng voltage sa LED, which normally 12V output supply ng monty natin? TIA
dear fellow monty owners... meron ba sa inyo experiencing knocking sound sa engine? I just noticed this while going up sa parking lot ng MOA... it suddenly sounded with loud knocking sound "tak tak takatak" sound. I also noticed that madalas umusok ng makapal white to dark smoke everytime arangkada, but wala pag rekta na. could this be due to bad diesel or anything? Pls. share your thoughts. Tnx!
I normally use caltex but when I noticed the thick smoke and reading from the different forums here I decided to try Seaoil since I can't find Unioil near my area.
Un EGR had it cleaned just 2 months ago nun naka 40kkm na ako
I just heard again the loud knocking, clanking sound when Im traversing going up the bridge and still hear it pag umaarangkada. I noticed na at times pag nag knocking sound sobrang Kapal din ng usok minsan puti Tapos nagiging black smoke
Nabasa ko sa iba forum Baka Hindi pa complete ang air compression nag I-inject na agad ng diesel kaya premature combustion at nag cause ng malakas na knocking sound.
What should I do kaya? Kanila checked and listened sa engine while idling Tapos rev ko everything seems normal naman at wala yung loud knocking sound. Pls advise
why not bring to your casa for check-up and analysis, under warranty pa naman yata sasakyan mo...
just finished customizing my rear fog lamp into dual mode bulbs, 35watter incandescent bulb for rear fog and Hid on reverse. para dalawa na Hid pag-reverse, coz gtv oem set only one reverse lamp
