Page 21 of 251 FirstFirst ... 111718192021222324253171121 ... LastLast
Results 401 to 420 of 5006
    Jul 2006
    #401
    Picked up my GTV this afternoon from Garyq at Antipolo near Sta. Lucia Mall.
    It took almost an hour to commute from Santolan LRT2 station to Burger King on Marcos Highway. Terrible traffic!
    The workmanship was superb. I am super O.C. when it comes to anything and everything. So I was extremely happy to see very clean wiring.
    Driving home I could immediately distinguish the vast difference in terms of output of the OEM Plastic Projector and Aluminum quad setup.
    Here is a video showing the cheap Plastic projector that Mitsubishi put into our GTV.
    http://youtu.be/US-xiy89ZtA?hd=1
    Apr 2011
    #402
    Finally, had the time post pics of the OEM back-up camera installed by CASA
    009 by bjreyesmd, on Flickr
    007 by bjreyesmd, on Flickr
    008 by bjreyesmd, on Flickr
    Jul 2006
    #403
    Cool your backup camera even tells you were to stop. I haven't seen that before.
    Jul 2004
    #404
    Quote Originally Posted by bjreyesmd View Post
    this is the camera i like. according to UMC Paco, this costs P6,000. with this camera, there is no need to make holes in the bumper
    it is similar in location to the rear camera of the tahoe
    how much did this cost you?
    Jan 2010
    #405
    Mga Sir
    anu po ba ang ibig sbhn ng "VALET MODE"?
    I own an 4x2 gls-V and planning to install HID and super yellow Fog lights? will the warranty be void by this?
    Jan 2011
    #406
    I have no experience in using back-up cameras. Does it turn on automatically when you shift reverse or do have to switch it on?
    Jul 2006
    #407
    Quote Originally Posted by agoonys View Post
    Mga Sir
    Valet mode means your car alarm is deactivated.
    If you have your HID and Fog lights installed by Winterpine they will assume the warranty.
    Winterpine is the exclusive accessories provider of Mitsubishi.
    There is two types of HID the Plug and Play which causes glare and Retrofit HID which produces maximum intensity and distance.
    Jan 2010
    #408
    Quote Originally Posted by Slick50 View Post
    boss slick
    panu kung binili ko sa ibang place at pinakabit ko sa iba? void na ba agad ang warranty? which particular part of the warranty?
    #409
    Most rear cams are automatic. Mine, similar to that posted by bjreyesmd, activates when in reverse gear and the video feed replaces anything showing on the MID. But I also read somewhere that someone connected a switch so that you can activate it even while not in reverse gear.
    Jan 2011
    #410
    Quote Originally Posted by NY2006 View Post
    Thats nice. Thanks for the reply sir.
    Jun 2003
    #411
    Ma-void ang warranty if makita ng casa, pwede naman tanggalin before mo ipasok sa casa. Yun plug and play won't cause a glare since naka-projector naman
    Apr 2006
    #412
    Me & Ian of Strada club test drove the Montero GTV & Strada GLS Sport VGT.. We both had the same observation that the acceleration of the Strada was faster & the power of the VGT was more felt on the Strada.. As an owner of a 3.2 monty with some minor engine mods i felt that the accleration of the Monty with VGT was just quite similar with my 3.2 monty..
    May 2011
    #413
    night vision din ba? I didn't get the 8.5K casa offered, they said it has night vision.
    Apr 2006
    #414
    Jul 2006
    #415
    boss slick
    Electrical warranty.
    Things that will void your warranty if you don't have it done by winterpine.
    Horn Upgrade
    HID Upgrade
    Foglight Upgrade
    I will upgrade my horn to a PIAA 500/600 mhz 116db
    I remove/replaced the Plastic Junk Projector and remove/replaced the 9005 High beam with Retrofit HID.
    Mar 2011
    #416
    Mga Sir, I am new in this forum,, pano po ba mag reset ng Fuel Tank level / Km., un meter ko says 300 Kms pa ang pwede takbuhin kahit malapit ng mag empty ang tank. mine is GLS-V , thanks in advance
    Apr 2011
    #417
    Quote Originally Posted by vin81 View Post
    Yes, it has night vision, cost is 6K at Union Motors Paco
    Apr 2011
    #418
    Yes, I would think there would only be a slight difference considering the HP difference is only about 10-15HP. IMO, the main factor between the 3.2 monty and the new 2.5 VGT lies in the fuel consumption. You get slightly more power and acceleration, but lesser fuel consumption.
    Apr 2011
    #419
    Quote Originally Posted by noventay_cinco View Post
    Tap the fuel tank meter on the MID, and then tap reset. You will see this in the Car Info display of the MID
    Jan 2010
    #420
    mga Sir,
    please help. If the blue LED is not blinking valet mode ba yun? and if its blinking naka alarm mode? am i right or baliktad?
2011 Mitsubishi Montero Sport [continued]
