Page 26 of 251 FirstFirst ... 162223242526272829303676126 ... LastLast
Results 501 to 520 of 5006
    Mar 2011
    #501
    Quote Originally Posted by jhnkvn View Post
    Deadening the doors would yield minimal effect in minimizing road noise. Talaga they're just to reflect back the vibrations caused by the midbass for better sound reproduction.
    If deadening: Floor and wheel wells have the best impact on road noise. The roof can also be deadened to reduce wind noise.
    All in all, if you deaden the whole car, it'll add around 100kg more so deaden carefully so not to affect fuel consumption drastically. The only people who really deaden their whole car are those who is in pursuit of better car audio.
    This is a very useful information... Thanks a lot sir...
    Apr 2011
    #502
    Quote Originally Posted by eccm View Post
    I recently upgraded my gtv's audio system at tsikot.com shop in taguig, wth the help of jedi and his installer jon. Iam satisfied with the outcome at a very reasonable price. thanks dude...
    Hi eccm, inquire ko lang if how reasonable is the price of the upgrade and if what was done on your unit. Winterpine (in amcar sta rosa, laguna) cannot install the avt subs with built in ampli in my unit due to some other items needed to install it that they still donot have, for almost two months now. Hope you can pm me on this. Thanks/
    Jan 2011
    #503
    wow! 100kgs? what are the mats made of, gold? how much would it cost to deaden a whole monty? doesn't sound too practical for a daily driver.
    Aug 2010
    #504
    Quote Originally Posted by arjay18 View Post
    Most deadeners are primarily composed of butyl. You wouldn't like asphalt since mangangamoy yan on a hot day (especially pag nasa Pinas ka pa). Madaming kinds, liquid deadeners, etc. but most of the deadeners you find in the market is of the butyl kind -- Dynamat, STP, Stinger Roadkill, etc. Technically speaking, these are called CLD (Constrained Layer Dampers) and traditionally used to control panel resonance (hence for car audio purposes sila normally). A cheaper but less effective alternative are those foam mats. Ito mga Acoustimats. They're roughly half the price of a STP Silver butyl lining.
    That 100kg is an approximate weight added on to a fully deadened sedan using those butyl mats. And that's not even overkill. Some car audio purists even use mass loaded vinyls (MLVs) on their vehicles just to isolate noise. More mass = less noise penetration.. very simple science. It's like using a thick door versus a thin door in isolating your room from outside noise. How heavy are MLVs? They're like a substitute for lead one of the most dense elements in our Table of Elements.. Bwahaha..
    If you're not planing on foray into car audio, just those foam mats from Acoustimats would suffice. These are often called OEM mats since pagbinaklas mo door mo, you'll probably see them slotted inside your doors.
    Acoustimats is around 800php per sheet ata.. you could get them 500php kung may kilala ka though (trading section of different forums). Most doors need 2 layers/sheets to cover the "front and back". Personally, got no idea how much whole car deadening using them would cost.
    EDIT: Is it practical for a daily driver? No.
    Apr 2011
    #505
    BTW, Mickeys autosound already has cables for the headrest monitors....plan to have my audio setup installed by them.
    Aug 2010
    #506
    Quote Originally Posted by bjreyesmd View Post
    Actually, madami nagpapagawa na Monty sa kanila Mickeys. Just this Wednesday merong lady nagpapakabit ng mga headrest monitors if I remember correctly. Coding pa siya
    Regular ako sa kanila eh. Bwahaha..
    Jan 2010
    #507
    sir 10K lang budget ko for separates and installation nya? may xplod na ako na ampli. pasok ba and 10k na budget ko kay mickeys? or mga high end lang sila?
    Jan 2010
    #508
    I changed all the speakers with A/D/S and also the seps ads, with lighting sab amps. Iam very satisfied with improvement on the quality of the sounds.
    how much sir inabot ng sound enhancements mo?
    Feb 2011
    #509
    Quote Originally Posted by agoonys View Post
    I think Mickey's has a variety of seps to fit your budget, but remember you still have to add wirings, the cable for the avt hu to install the sub and of course the seps. decent wiring kits would go for 4k minimum. May mga generic at 2.5k
    If the budget na 10k is only for the seps then you have a lot of choices like morel, focal, hertz, etc
    Aug 2010
    #510
    Personally, I would recommend Banawe for budget meal setups since most of them offer free installation and stuff. Not to mention alot of the shops there offer "packages" if you're off to a fresh start. But if you're after quality work, Mickeys are really worth the buck. Yun leatherette na ginagamit nila is soft.. it's the expensive one daw according to Rocky (yun owner ng Mach2Audio just a few blocks away) na pagmay shipment, agawan mga dealers sa material.
    For the seps, if you're budget is from 8,000-10,000php: I would recommend just two: Morel Tempo 6 and Focal's entry-level separates, 165A1 Access. But Mickeys have sort of "premium" pricing. Although you can haggle the price, masmababa parin sa Banawe (due to lots of competing shops). Problema with Banawe is that: pagwala ka alam, they would likely fool you.
    I'd suggest Candyshop sa Banawe. Look for Nogs, super mabait yun. In fact, wala sa mukha niya ang pagiging "boss" umpisa akala ko employee lang nga siya eh
    Mar 2011
    #511
    May I ask our more knowledgeable friends what video formats are playable in the GTV dvd player. I downloaded you tube files, converted them to MPEG4 avi but would not play. However, it plays dvd movies. Thanks in advance for any info.
    #512
    Quote Originally Posted by metslgx View Post
    Hi JPG,
    I would like to think that the reason for the above is that the strada is lighter than the gtv. Does the strada comes with 6 speed auto tranny?
    Yes, strada is lighter by 195kgs than gtv. para kang may 3 passengers on board sa gtv compared to strada. Same tranny strada vgt/ gtv, 5 lang.
    Feb 2007
    #513
    The camera replaced the plate lamps, and yes, it is bolted on. You have to remove the sidings of the whole trunk door in order for you to install it. Sa Union Motors UN Avenue, 6K ito. have mine installed by them.
    I have bought a camera from alibaba *56.7USD. Model was for grandis but they have the same size with the montero(mine is GLS-V). Doesn't have the chance to install though. Will ask the casa or wintepine if they can do the installation.
    Apr 2011
    #514
    Which is better in terms of sound quality? DLS RM6, Focal Access or Morel Tempo? I know the RM6 retails for 12K but if the entry level focals and the Morel are better, I'd go for them.
    Apr 2011
    #515
    About thirteen thousand
    Apr 2011
    #516
    Sir try to pm or contact jedi from tsikot.com
    Aug 2010
    #517
    First of all, I cannot stress this enough but sound preference is very subjective. Thus we cannot answer the question: "what's better?". All of them are good. Different sound signatures at the start though. If you have no experience in tuning, all of them are good for the money. If you're an experienced tuner, there are cheaper alternatives there that would sound better with the proper tuning versus Focal/DLS/Morel without tuning.
    In any case, off-topic na tayo try to visit Kotseaudioclub (KAC) for more car audio related questions or the forum's sound board.
    Jul 2004
    #518
    Quote Originally Posted by philhumanist View Post
    honestly, i have not tried playing any dvd movies using the dvd player. but if it is any help, i play movies directly from my usb
    if you are using the usb, try not to covert this to mpeg4 avi. if the extension file is still ".avi", it will not play. just convert it to mp4 ipod/apple tv. the extension file should be ".mp4"
    i do the same. i convert all video formats to mp4 ipod, copy it to my usb and i can play this on the screen already from the usb
    #519
    Hi guys, can anyone with a white GTV share a photo of the carbon fiber rear spoiler? I have a white GLS-V and I'm thinking of adding the new carbon fiber spoiler. Do you think it will look good on a white body? I also found out from casa that this new spoiler is clip type, so no need to drill holes on the rear door. Thanks!
    Apr 2011
    #520
    Quote Originally Posted by NY2006 View Post
    It looks good on white IMO, mine is gemstone gray mica and have installed the GTV spoiler already
2011 Mitsubishi Montero Sport [continued]
