Page 184 of 251 FirstFirst ... 84134174180181182183184185186187188194234 ... LastLast
Results 3,661 to 3,680 of 5006
    Sep 2010
    #3661
    Quote Originally Posted by sirhcacal View Post
    Hi Sir Zix, thanks po sa reply! akala ko maapektuhan pati ung comp box! oo sir ive heard pag naka sound setup kayo marereset ung configurations setup ng sounds. Ok lang at hindi pa naman ako naka setup ng sounds.. hehe.. Sir Zix anu ba ung MIS? un ba ung sa memory ng alarm?
    sir kung nag aalarm mag isa monti nyo may problema na shock sensor ng alarm nyo. kailangan papalit nyo sa casa or sa winterpine. para di maingay sir at magamit nyo pindutin nyo yung valley mode switch sa ilalim ng dashboard driver side kulay red. wait nyo mag beep tapos umilaw yung blue light.
    Feb 2007
    #3662
    MIS=MID=MMS : Multi-Information System; Multi-Information Display; Multi-Media System.
    #3663
    kulit nitong earth magnet ko, hehe
    Feb 2007
    #3664
    Sir Zix nagpalit uli kayo ng Filter?..saan kayo nakabili ng Baldwin? Thanks..
    #3665
    yes, naka 10k na ulit si monty ko eh.
    #3666
    sir paano po matanggal pms warning? thanks reply asap
    Feb 2007
    #3667
    First post...demanding? Tsk tsk..
    Apr 2012
    #3668
    Quote Originally Posted by zix888 View Post
    [IMG]http://i1085.photobucket.com/albums/j432/sss44ph/0ED4E7CE-708E-469B-94B1-276A05EF83BB-15199-00000552798AC37E.jpg
    sir zix, may i know ano yang earth magnet na ginagamit mo? ilang piraso nakadikit sa oil filter mo? TIA
    #3669
    eto sir yung nakalagay
    #3670
    ideas please(4wd). this grease nipple's position wont fit greaser head, tried almost all sizes. clearance on one side is really tight(marked red). i dont wanna remove the whole front propeller shaft just to grease this joint. i was thinking to change the nipple to bent/angled one
    Feb 2007
    #3671
    Di ba mas madali kung grease gun head na angled ang ipalit sir zix? Based nga sa position medyo mahirap din yata tanggalin yung gease nipple. Problem lang is kung meron grease gun accessory kit(mountain 2500AK) na available sa atin..
    Yung magnet sir is yun po ba yung galing sa computer hardrive? Pair na yata bawat isang HDD..
    #3672
    naisip ko na din yan, the problem is if you project the nipple's position, halos malaki lang ng konti sa nipple itself yung maacommodate niya na greaser head, kaya dead end dun sa idea na yun. replacing the nipple will be tricky also, pero a long socket will do the job, problema naman pag mount nung angled nipple. a long straight nipple na lang siguro. try ko muna maghanap ng high pressure hose na halos forced fit tapos tried to crimp it using a wire, para hindi nako magbaklas ng shaft.
    yup i think yung magnet is paired na. nung ibigay kasi sakin yan pair eh.
    Feb 2007
    #3673
    Tama sir yung mahaba nalang na nipple ipalit nyo, mas madali pa yata makahanap nun..
    *Sa front nga pala yung na propeller ...
    Apr 2012
    #3674
    bale sir nakadikit lang yan sa filter o nakatali? saan po kayo nakabili niyan? i read somewhere sa ibang thread eh yung mga magnet ng hard drive ginagamit? i have not seen one though...
    #3675
    yung 2 chrome colored thing, yun ang hard drive magnet.
    no need na itali, coz once you place them there, no way na matanggal siya kahit mag off road ka pa. kaya lang may duct tape, cover lang nung magnet , ayoko lang siya madumihan, hehe. 2 times na nga oil change ko nakalimutan ko na may magnet nga pala siya, nagugulat ako kasi bakit hindi ko maisentro yung pangremove ng filter eh, tsaka ko lang maaalala na may magnet nga pala
    Apr 2012
    #3676
    i see sir zix, malakas pala dikit niyan kung kahit offroad di matanggal. pero ok na rin i duct tape para mas sure di malaglag and hindi madumihan. ok din may ganyan para mas lalo makatulong sa filtration, didikit sigurado kung meron man metal chippings o shavings na nasasala ng oil filter. i need to find one para sa idikit din sa bd28 na galing sayo...
    #3677
    yung sakin sir nahingi ko lang sa ka-officemate ko. nabanggit ko sa kanya if may naitabi sya mga old pc na may busted hard drive, he asked for what, nung sinabi ko sa kanya yung use niya, pagpasok niya the next day dala na niya, siya din meron, 2 pala yung busted hard drive niya sa stock room niya.
    Sep 2009
    #3678
    share ko lang,
    i have been hearing light rattles in the cabin for some time now (2010 monty) and never really minded it, even after sound deadening was installed along with the sound system, the rattles was still there.
    i have zeroed in on some parts which have greatly reduced the rattles.
    first is the at the lower pillars between the front and rear doors. i removed the plastic cover (the one that covers the seat belt mech) to expose the edge of the metal and put a strip of 3/4 inch wide duct tape so that the fit of the plastic cover would be snug and not vibrate.
    second source, both rear door sidings. after lifting of the siding to expose the back side, you will see screws that attach the pocket ( bottleholder) to the sidings. i unscrewd the bottom 3 just enough to insert some foam tape and tightened again.
    third is the rear cup holder near the rear a/c vent. remove this then inserted some foam tape on the sides then re attach.
    malaking nawala sa mga minor rattles... merom pang konti which i think come from the front sidings.
    hth
    Sep 2010
    #3679
    *rafronty: thanks for sharing these tips. Will check them. I also have a 2010 Monty. And ang dami na ring rattles talaga. It gets frustrating
    Sometimes pero hinahayaan ko na lang.
    Jun 2007
    #3680
    Quote Originally Posted by rpfronty View Post
    share ko lang,
    hth
    *rpfronty: Where did you buy the foam tape? What brand and how much? Seems to be a handy tool.
2011 Mitsubishi Montero Sport [continued]
