Page 131 of 251 FirstFirst ... 3181121127128129130131132133134135141181231 ... LastLast
Results 2,601 to 2,620 of 5006
    Feb 2007
    #2601
    Quote Originally Posted by 111prez
    sige will try to take a snap
    unless maunahan ako ni zix, hehehehe
    Unahan nyo na si sir zix!..
    Sep 2011
    #2602
    stage 2 na nga yan. 22k kasama na installation diba? as per dvldoc's suggestion, mas maganda if away from heat yung pump. yun daw nakakasira ng pump e. and nasa tabi na ng turbo mo yung pump.
    Considered that prior to installation, pati yng reservoir (mageevaporate daw yng methanol). If Iam not mistaken the pump is rated at 200 or 400 Celsius ata (paconfirm pare, not sure kng tama tanda ko). I assume that the engine bay should not reach that temp, malamang masusunog yng mga electrical tape na malapit sa turbo. As for the reservoir, I filled it up disengage the WA injection, drive it for a couple days, and the reservoir is still full. Planning to use distiller water only kng mageevaporate nga since yng cleaning effects naman habol ko, d naman nagbago. Anyway my replacement warranty naman sya for 1 year (already changed the controller) and sila naman naginstall so worry free ako at least for a year ;)
    Yup 22K, included na installation and 1 year warranty.
    Jul 2004
    #2603
    nakow, hindi ko kayang unahan ang souped up monty ni zix
    herherherher
    #2604
    herherherher
    Buti na lang busy ako, if not baka nga naunahan ko kayo sir prez and prince777, hehe
    Just finished a simple side mirror security feature, para naman kung may titira pa eh hindi na niya maibenta sa iba. May makabili man, eh ikaw na din, hehe
    Sep 2010
    #2605
    *sir zix888: can u post a link on how to properly remove the MID Cover? I just had my 3rd RV Meter change the other day and today its making a rattling noise. I guess the antenna wasnt properly placed back. The Installer only had a 1 day duty in our province. Thanks Sir!
    More Power to your DIY.
    Jul 2004
    #2606
    Quote Originally Posted by pogy_uy View Post
    ........I just had my 3rd RV Meter change the other day....
    wooohooo!
    tabla na tayo dito
    #2607
    Here bro,
    http://www.youtube.com/watch?v=GKgdGP2Mfus
    Jul 2004
    #2608
    could also be some wires also, assuming that the panel is secured properly
    watch out for the wire for the bluetooth mic. it is long and you have to wind it up properly so that it will not rattle around
    Jul 2004
    #2609
    *deleted - double post*
    Jul 2004
    #2610
    Quote Originally Posted by zix888 View Post
    IMHO, ito mas practical kaysa yung mga side mirrors where the lamps are located at the front
    Nov 2011
    #2611
    Here bro,
    master zix kayo din po ba si gtv2011ph?hehe
    Feb 2007
    #2612
    Sir Zix ikaw rin nag DIY nung LED lights sa side mirror?
    Paano po yung ginawa nyo sa "label" na SSS?
    Thanks
    Jul 2006
    #2613
    Hi Guys,
    I need some advice on my 10K PMS.
    According to the Citimotors Makati service department.
    I'll need a oil change, replace fuel and oil filter.
    I would like to bring my own Fuel and Oil Filter and Motor Oil.
    Would like recommendations and where to buy the Fuel and Oil Filter.
    For the Motor Oil I would prefer to buy Shell - would you guys recommend the Shell Helix HX7 Diesel?
    I've shopped around and found 6 Liter container of HX7 for PHP 1,800.00 and 1 Liter - PHP 320.00
    I live in Q.C. if that is helpful.
    #2614
    Thanks
    Yup sir ako na din gumawa nung arrow led. Yung led nabili ko sa ebay. You have to remove and trim the plastic holder nung mirror kung saan imount yung strip, gamit ka ng heat gun. Actually madali lang, mas mahirap pa para sakin yung paglilinya kasi lahat ng wirings ko puro nakasama sa oem wirings, hirap magpadaan ng linya sa tubings, masakit sa kamay. Yung plate no. Printed sa mirror, glass etching chemical ginamit ko, nagpagawa ako sticker sa mall, ayun 15 mins lang okay na.
    Feb 2007
    #2615
    I think i can do the glass etching but not the LED turn lights. Any recommended etching cream sir;)?
    #2616
    zix, ok yan ah. san ka nakabili ng LED arrow? ebay.ph?
    #2617
    Ebay u.s. Seller, dun ko pinaship kay erpat, tapos balikbayan box kasabay nung sprintbooster and other stuff na padala ni erpat
    #2618
    Nahingi ko lang bro yung cream from a friend. but i can ask him where niya nakuha or nabili. Update kita
    Oct 2011
    #2619
    Heard it over the radio may bagong carnapping case na naman sa qc. Mainit sa mata ang Monty. Ingat lang mga parekoy.
    #2620
    Here bro how it looks nung binigay na etching cream sakin plus yung sticker na pinagawa ko sa stickerworks(inverted, ang cut out is yung letters/numbers)
2011 Mitsubishi Montero Sport [continued]
