Page 89 of 250 FirstFirst ... 397985868788899091929399139189 ... LastLast
Results 1,761 to 1,780 of 5000
    #1761
    Quote Originally Posted by ooba99 View Post
    ^ Ok si sir altec ah. Nai-compare ang orange sa apple ng maayos. Nice comparo, bro.
    +1 Agree din ako! nice one sir altec.
    Jan 2011
    #1762
    +1 Very objective camparison!
    Sep 2010
    #1763
    +1 din ako. Astig!
    Dec 2010
    #1764
    Quote Originally Posted by altec View Post
    Before the innova, I had a 1997 fuego. mahilig talaga ako sa pickup. The Strada ride vs the Innova is not that different. Sa tingin ko pa nga mas malambot pa ang ride ng Strada kaysa Innova. Plus I got my 2009 glx in the 1st quarter of 2010 for less than 900K, it was one of the last few units being sold, and I got it through Xave dito rin sa tsikot, so it was a very good deal, considering that the Innova was hitting 1M already then. Kinabitan ko lang ng canvass type carryboy cover (I posted a pic of my ride here at the strada thread long long ago). On a few occasions kasi, nagkakarga ako ng styrobox which if you install those accordion type, sasayad. In terms of engine power, ang layo ng difference. And believe it or not, mas nakakapagod magdrive sa innova kaysa sa strada. Change oil pms mas mahal ang strada, coz it needs more engine oil than the innova. In terms of fuel economy, pareho lang sila, 2.5 GLX 4x2 vs d4d innova E. Just in case you will need to change tires, mas mahal ang gulong ng strada, but that's obvious because of the sheer size difference. In terms of durability? Pareho lang sila na may claim ako under warranty. Other than that, typical toyota and mitsubishi, durable (huwag na natin pagusapan ang choking problem ng innova, because that is not that prevalent in the newer models).
    By the way, yung innova ko dati is 2005 model, yung 1st year na lumabas ang innova.
    Now, which one is for you? Depends. Kung kailangan mo talaga yung 3rd seat/row option, Strada is not for you. Kung 2 rows lang pwede na, you may want to consider the Strada over the Innova. Plus with all the flooding that is becoming notoriously common, every centimeter of extra ground clearance is golden.
    Thank you po sa detailed answer.mas maganda na mag decide ngayon dahil sa first hand information galing sa inyo.
    May 2011
    #1765
    Guys, ano po opinion ninyo with regards to security system for our units? Have you heard about "Retrivo ATD"? Meron bang gumagamit nito? Is is effective and worth it? I had this idea of an ideal security feature when I talked to a friend who is an Electronics Engineer and I discussed with him a system that would cut all the electrical of the car. I was browsing the other day and stumbled upon this company who has already created same features which I had in mind.
    Can somebody share their insights about this system?
    website: Reliable Car Security - Retrivo Anti-Theft & Immobiliser
    News: Business - New device won’t make it easy for crooks - INQUIRER.net
    Jul 2010
    #1766
    Sir, squeaking noise siya like those house doors na nagsqueak ang mga door hinges. I sometimes hear those noises on my previous ride, innova. They had to bring down the transmission to access the release bearing (sabi nila). Anyway, I called up the casa, ok na daw. I will pick up the car this 5pm. Walang bayad kasi under warranty. I will get more info kung ano talaga ang nakita nila.
    Sir altec, i also experienced this on my 2010 glx a few months ago before my 10,000 km check up. At first squeak when the clutch is released then eventually nag squeak na when the clutch pedal is pressed or released. Sounds like squeaking joint or hinge, rinig mo sound when the window is open and you can clearly hear the squeak if may wall sa tabi mo. Pina check ko during 10K PMS, they just oiled or greased sa ilalim sa may area ng clutch. Now its already 3months mukhang ok naman wala ng squeak, not sure lang how long it will last. BTW ilan months and kilometers na glx mo when you noticed this problem? did the casa replaced any parts sa may clutch area? saan casa ka nagpagawa? I have mine done at diamond in edsa ortigas
    Aug 2003
    #1767
    bro rss, when I went to get the ride, nawala yung squeaking noise. Pero after pumping it a lot of times, nagkaroon ng mahing squeak, but not the same as before. They just lubricated the rod (while I waited) (iba sa ginawa nila sa release bearing which took 2 days). Ok na. Lahat walang bayad, under warranty. 15K na ang mileage ko. I noticed that already on my 10K. But they just lubricated it, tapos nawawala. Napansin ko pag umuulan, nawawala ang squeaking. Pero pag hot and dry, lumalabas ang squeaking.
    Aug 2003
    #1768
    Bro Casey Jones,
    Although this may sound amusing, tama nga sabi nila about the pogi looks ng Strada. A while back here in this thread, I also mentioned about the Strada fun run we did here in the South. We've had several runs already. And each run, maraming mga tao who would give the Strada convoy a 2nd look, with comments pa nga. There was one time that we had an EB, nakita ko parating yung ride ni sir AV80r, may mga babae who happened to pass by and pointed at his ride, tapos narinig ko, ui, strada club! (ang laki kasi ng sticker ni sir Rally). Imagine if you do this with an Innova convoy. Meron bang fun run sa innova? If ever na may convoy, parang hindi yata papansinin ng mga tao, kasi baka akala lang nila may delivery ang toyota ng mga innova.
    #1769
    good day.
    would anybody know where i can have a nudge bar made for the strada? want to place additional foglight sa harap.
    thanks
    Dec 2010
    #1770
    Quote Originally Posted by mjlu View Post
    * S'Big_bonsai - Forgot to add this, Also try to check out the mobil 1 TDT 5w-40.
    Okay, check ko yan Sir... Thanks!
    Feb 2010
    #1771
    Sirs,
    Would anyone know where I can get soft top cover for strada ? Thanks
    Gino
    Jun 2007
    #1772
    Quote Originally Posted by dexlab View Post
    good day.
    thanks
    PM mo si bigblock. He can help you with your concern.
    #1773
    Quote Originally Posted by gtq90 View Post
    Sirs,
    Gino
    Clarify ko lang po kung ito yung para sa pickup bed natin, if it is try with the strada clubs partner shops, Miggy Boy in Caloocan and Carryboy in Banawe. Meron po yung brand na Aeroklas and Carryboy. Kayo na po bahala kung ano po ang masmaganda para sa inyo and yung tama po sa budget niyo. Main difference between the two snap on sa Aero and velcro with lock sa Carryboy. Hope this helps.
    Feb 2010
    #1774
    Yes for the pick up bed . Will check it out . Thanks !
    #1775
    thanks... tried sending a PM but his inbox if full. know how i can contact him?
    thanks
    Oct 2004
    #1776
    thanks
    OT:
    Sir, are you supafly's bro?
    #1777
    Question lang po, Kailan pa lalabad ang 2011 mitsubishi strada gls sport-v m/t?
    Quote Originally Posted by Rovin99 View Post
    late this year sabi sa akin ng casa dito pero I doubt it. Baka sa TOTL lang yan so mga AT variant. But who knows di ba?
    Jun 2007
    #1779
    malapit na.... yung 350nm magiging 400nm na....
    Jun 2007
    #1780
    I don't have his numbers right now, but you can try his emai: manolo_santos73*yahoo.com.ph. You can also browse our club thread for strada modifications, baka dun nai-post nya number nya. At the same time see the different modifications of our club members. Here's the link:
    TSCP Strada Mods [continued 2]
2010 Mitsubishi Strada [continued 2]
