Page 121 of 151 FirstFirst ... 2171111117118119120121122123124125131 ... LastLast
Results 2,401 to 2,420 of 3019
    May 2011
    #2401
    Did some experiments about the alarm a few days ago and discovered naka tap nga sa busina.
    I locked myself inside the car using the remote. A few beeps sounded and the red dot (near hazard switch) was blinking. Waited a few secs until the sound stopped.
    Opened the door and the horn alarm went on.
    Assumption: alarm will be triggered only on force entry/door opening. I guess the module winterpine is saying is the shock sensors?
    #2402
    Yup, force entry lang including force opening ng hood!
    #2403
    Alam ko breaking an entry lang ang ASX sa mga doors at hood.
    May 2011
    #2404
    Quote Originally Posted by Noel Salisipan View Post
    will verify soon what's that "module" (priced *6k) winterpine is saying (add on feature for alarm kuno) if its the shock sensors nga.
    anyway, created a group at facebook. Look for "Mitsu ASX Group", and feel free to join.
    thanks!
    #2405
    Quote Originally Posted by skybison View Post
    thanks!
    Ok Bro, I'll check the site.
    Tungkol sa alarm, generic yung inooffer ng Winterpine before sa akin. Mapapalitan ang remote key at yung electronic code. Hindi na rin ako pumayak dahil sa mga.changes.
    May 2011
    #2406
    Kaya module yun sinasabi nila - add on daw para ma retain ang key fob. Kasi sabi ko diko type 2 alarm bitbit mo. :D
    Made sense to me when reading at other mitsu forum on rvr/outlandersport alarm. Yun iba equipped with shock sensors others don't.
    #2407
    Kagaya ng backing sensor Bro, from CBU Japan ang ASX, hindi rin equip ang sensor, locally na lang ikinabit.
    Kung yung push start/stop ng engine kasama sa CBU Japan, question ang compatibility ng shock sensor na maiintegrate sa remote control key natin.
    Yung 2013 kaya na ASX paano ang alarm system?
    Nov 2003
    #2408
    guys.. just want to inquire size 17" ba ang stock ng asx? anong brand po yung rims? gusto ko kasing magpalit ng rims ng lancer ex ko at opting for 17" lang dahil sa byahe byahe sa probinsya pangasinan mostly, if yes magaan ba sya? at baka may nagbebenta dyan for a reasonable price...thank you more power
    #2409
    Quote Originally Posted by Optimusprime View Post
    Size 17" enkei, 22kg.
    Nov 2003
    #2410
    thank u sir noel..
    May 2011
    #2411
    to add up:
    Tires: Dunlop SP Sport 270 215/60/17
    Wheels: Enkei 17x6.5 5holes x 114pcd offset 46:
    #2412
    thank u sir noel..
    Ok Bro.
    Goodluck sa rim hunting mo.(smiley)
    Nov 2003
    #2413
    to add up:
    thank u sir sky..hmm mukhang makipot sya ng konti..pero baka it could fit..
    - - - Updated - - -
    to add up:
    May 2011
    #2414
    we can test fit if you want. Nasa sala lang yun oem wheels & tires ko (freshly detailed including the tires! haha) BUT no plans in selling yet. Approx 2,000kms+ lan tinakbo nun when i upgraded, amoy bago pa.
    PM na lan tayo in case. ;)
    #2415
    to add up:
    Sky, same ba naging conversion nung stock mong gulong dun sa bago specially dun sa height?
    Worry ko kasi sa gulong ko pag na-flat in the middle of my journey dahil hindi the same ang height ng 245/45/19 sa reserba na oem.
    Ikaw, paano set up mo pag na-flat?
    #2416
    bro, yung 19s mo and oems eh wala pang 7mm ang difference on each side, i dont think it will make "kabig" at all.
    #2417
    Quote Originally Posted by zix888 View Post
    So, ok lang bro kung sakaling ma-flat yung isa sa harap at palitan ko ng reserba. Meaning oem vs yung mag 19"?
    #2418
    of course, just make sure na yung oem spare mo eh at least 34psi para halos tumabla sa 19s mo. so dapat check mo palagi din yung reserba mo
    Aug 2012
    #2419
    Skybison, have you managed to change the settings? I managed to install and activate Lexia and PP2000, but I can't activate Diagbox, it always ends with an activation error. Also, I can't change any settings in Lexia because it can't be written/saved without a code (03114 doesn't work). Have you found a code that works?
    #2420
    I see, ganun na nga ang gagawin ko, sa tire pressure ko na lang babawiin.
    Thanks uli Zix.
2010 Mitsubishi ASX Crossover
