Page 123 of 151 FirstFirst ... 2373113119120121122123124125126127133 ... LastLast
Results 2,441 to 2,460 of 3019
    Aug 2012
    #2441
    Pakopya. Haha.
    Sent from my GT-N7000 using Tapatalk 2
    Aug 2012
    #2442
    Pakopya. Haha.
    //10 characters
    Sep 2011
    #2443
    ok din pala led sa asx. lalo pag black. parang ganito nakita ko sa youtube: [ame=http://www.youtube.com/watch?v=h28Zh7aCs40]Mitsubishi ASX - Led Strip - Mascara Negra - By MAGAOF - YouTube[/ame]
    Aug 2012
    #2444
    Pakopya. Haha.
    Dec 2011
    #2445
    Hi guys, Sorry kung mejo off topic. I tried reading the previous post pero parang wala ako nakita about sa carpet ng ASX natin. Hindi ko gusto yung carpet ko. Hindi sya sakto. May advise ba kayo sakin kung san makakabili ng maayos na carpet? Yung OEM sana if meron na dito sa pinas
    May isang issue din ako sa unit ko. Bilis maubos ng battery for Audio controls sa steering wheel. Bumili ako ng bago parang 2 months lang ubos na. Siguro 10-15 times ko lang nagamit yung car nun ubos na. San kayo nakakabili ng battery nyo? 700 kasi yung nabili ko sa Carworld Marilao. Pwede ba natin ito ipa wire derecho sa car battery para hindi na palit ng palit? sorry if noob questions. Im not a car pro. Newbie po Thanks in advance guys!
    BTW, sa mga hindi makapag decide between CX5, XV and ASX. Input ko lang dito is may advantage and ASX sa paddle shifters. Kahit sabihin natin mas mabilis mag accelerate ang CX5. Mas "fun" to drive padin ang may paddle shifter (If automatic). Share ko lang Though i really like the trunk size of the CX5 and the antenna, sa XV naman yung wheels. I'd still choose the paddle shifter. Just my opinion. It's for you to try nadin -> sa pagkakaalam ko kasi walang paddles and CX5 and XV, so if meron useless itong last paragraph ko. Good day guys! =p
    #2446
    Quote Originally Posted by sole_gemini View Post
    There should be something wrong with the remote. Mine is still using the same battery that came with the car and its nearly two years old na.
    #2447
    Mukhang may problema sa controls mo bro.
    Sa battery, 1.5yrs na yung sa akin e hindi pa ako nagpapalit at hanggang ngayon ok pa rin sya.
    Experience ko rin tungkol sa paghandle ng battery in relation to my digicam, pag naka-stay sa car yung digicam na hindi nagagamit ay mas mabilis maubos ang charge.
    Suggest ko, kung iiwanan mo yung car mo for a long period at lalo sa initan o mainit yung lugar, pull-out mo yung battery, ilagay sa plastic at sealed. Pag gagamitin saka mo na lang ikabit yung battery.
    Mahal pala ang battery, 700 meaning naka 10k ka na sa battery nyan?!
    Aug 2012
    #2448
    Quote Originally Posted by skybison View Post
    Naku, 'tay tayo nyan. Hehe
    Strange, the warning lamp disappeared before I could even deal with it. Hmmm...
    Aug 2012
    #2449
    Guys, I had my HID retrofit by Gary Quizon today, and it's their first ASX. It took them seven hours to do it. Now I can do out of towns and not dread going home at night on unfamiliar roads. And I don't have to blind others on the other side of the road. It's not cheap but I guess you really get what you pay for. Here are some photos.
    Front2 by landscapist, on Flickr
    HID light spread2 by landscapist, on Flickr
    HID light spread by landscapist, on Flickr
    Xenon Cutoff by landscapist, on Flickr
    Front1 by landscapist, on Flickr
    May 2011
    #2450
    Textmate, do you have a picture(side by side) of the oem projectors against gary's?
    I assume they replaced your oem (7hrs?!). Where did they securely attached the ballasts?
    Also, hi and lo ba pinagawa mo?
    Dec 2011
    #2451
    Brad. San kaya maganda mag patingin? Yung last time na nagpa check kasi ako ang sabi battery lang daw. Tapos after mga 2 - 3 months wala na naman. Sa marilao carlword ako nag pa check. Halos 1 beses isang linggo ko nalang nga yun nagagamit eh naubos agad =.=
    Dec 2011
    #2452
    Quote Originally Posted by Noel Salisipan View Post
    Thanks sa advise bro. Hindi naman. Hindi ko na naasikaso after nung unang palit ehh. Hindi nalang akk nag reremote. Saklap. Pero ayun nga your point makes sense. Halos 1s a week ko nalang yun nagagamit eh nagka ganun. Nung pinalitan naman nila yung battery. Gumana agad. I doubt kasi na sasabihin nila na may problem sa unit kapag gumagana na kapag pinalitan battery =.= or would you suggest a good casa? Walang kwenta kasi sa carworld marilao eh.under warranty pa naman asx ko till next month.
    Aug 2012
    #2453
    Koya, I have no idea how they set it up. Basta may narinig akong matagal na grinding, pukpok, etc. sa loob ng room. Hehe. They gave me back my halogen projectors.
    This is a Stage 3 bi-xenon, which uses a solenoid for the high beam. It has Philips Germany 85122+ D2S bulbs, plus free amber LED park light. They also retained my original high-beam bulb in the reflector. OA na ang quad. At namumulubi na 'ko.
    Gary calls it "Stage 3 OEM HID Projector Retrofit" and says it's not a "boxed kit." He also says "only the best parts are used" and claims it will match or surpass the setup on the SE.
    P.S. All the photos are low-beam lighting, no fog lights.
    #2454
    sir check mo muna yung battery itself, kung may tester ka, yan kasi ang problem ng frequency based audio remote, kung yung usual na route/area mo eh nakakaapekto sa frequency nung audio remote mo, you need to reset it once in a while. sakin kasi tested ko may isang location na every time na nandun ako, ayaw talaga gumana yung audio remote. kung may cruise control yung unit mo sir pwede lagyan ng connection yan, but if wala, negative. but kahit connected na directly to battery, if the frequency interference, hindi rin gagana yan
    Sep 2012
    #2455
    *bonclem
    May i request for a picture sa gabi with your led lights on?
    How much damage mo at ano specs? Watts/lumens, etc. Mukhang sa loob ba nilagay hindi sa labas (sorry malabo mata ko), if sa loob - hindi ba nahirapan yun installer lutuin yun headlights (adhesive)?
    Yes sir sa loob po yun installation na ginawa. mga 3 hours ginawa, dun natagalan sa opening ng headlights ginamitan nila ng blower para lumambot at maghiwalay then madali na paglagay nun Led strip. 2300 lahat gastos me charge yun pagopen ng headlights pero yun LED strips mura lang naman
    Here's some pictures kapag madilim na:
    lights 019 by bonclem, on Flickr
    lights 020 by bonclem, on Flickr
    lights 021 by bonclem, on Flickr
    May 2011
    #2456
    Thanks. I have complete tools naman and used to open plastic hls. Either tinatamad or ayaw ko pa paglaruan headlights ko. Hehe
  17. #2457
    the stock halogen projectors are with pipefish. yes it was replaced with a bixenon HID projector. the ballasts were attached oem style, i.e rigidly mounted under the headlights. yes LO and HI or bixenon yung projectors na kinabit. The headlight levelling is still functional. Yes a proper retrofit will take this long, and we have done more than 150 cars already. Pag gawa at pag latag nung wiring harness will take 2 hours already.
    Dec 2011
    #2458
    Quote Originally Posted by zix888 View Post
    Hi sir, chineck ko na using voltmeter. ubos talaga yung battery. 3 volts dapat sya. 0.1 nalang yung karga. simot na simot. GLS 4x2 ASX ko pre.
    May 2011
    #2459
    Pa check mo sa winterpine-main(aurora). Ganyan montero ko dati, a few months lang simot ang battery sa steering wheel. Me pinalitan sila na mga wires ata, ayun since then buhay pa remote ko.
    Sep 2012
    #2460
    just sharing
2010 Mitsubishi ASX Crossover
