Page 117 of 151 FirstFirst ... 1767107113114115116117118119120121127 ... LastLast
Results 2,321 to 2,340 of 3019
    #2321
    Quote Originally Posted by big_d_lou View Post
    Ecu customization success!
    All doors auto lock when the speed hits 20kph!
    Auto unlock of doors on impact.
    Auto unlock of doors when in park. Can be set to auto unlock when engine turned off.
    Set headlamp to HID (after market) so no more flickering.
    HID turns on when unlocked by the remote.
    Removed auto reset of trip computer when engine is turned off for 4 hours.
    Things to do next:
    Turn on beep horn on lock or unlock through remote.
    Activate drl
    Active rear fog by turning fog lamp switch twice.
    Change signal lights to Led and set voltage in ecu to remove false burnout bulb warning.
    I wish to do these also.
    (resurface ko lang for refference)
    Aug 2012
    #2322
    Haha. Pwede ba maginit na lang ng takeout sandwich. Ayan Skybison, di na 'ko bibili ng cable, pahiram na lang. Hehe.
    Sent from my GT-N7000 using Tapatalk 2
    Aug 2012
    #2323
    May nakapag-upgrade na ba sa mga GLS owners to HID headlights? Medyo nadidiliman kasi ako sa halogen, lalo pag sa national highway.
    I'm contemplating on getting mine retrofitted by a professional installer, where an appropriate projector-ballast-harness combination is used, not the cheap plug-n-play units from China.
    I've e-mailed the guy from Fort Bonifacio and his most expensive package (best one using Philips Germany OEM bulbs) costs P26,000. Is it worth it?
    May 2011
    #2324
    Your call bro, if you have the moohla to burn - makes you happy and complete, go.
    Ika nga, walang basagan ng trip. Hehehe.
    But for my case - kontento na ako, i'll wait for my OEM to get busted or wait for the warranty to lapse. ;)
    #2325
    Quote Originally Posted by Pipefish View Post
    Ang alam ko lang foglamp ang inup-grade sa HID, pero in-active na yung member.
    Kung kagaya ng SE yung kalalabasan ng ilaw tingin ko ok na rin yung upgrade, waranty na lang ang problema.
    Pero suggest ko kung madlim yung tint mo at hindi naman salubong sa araw ang usual na byahe, either na palitan na lang yung tint ng very light shade pero maganda ang heat rejection or I-clear out mo yung tint sa line of sight sa wind shield.
    Aug 2012
    #2326
    Quote Originally Posted by Noel Salisipan View Post
    Naka-3M BC 35 ako, 'yung lightest na available locally at di naman ako nadidiliman sa gabi. Iniisip ko lang kung ganun talaga kamahal magpa-retrofit kasi may nakita ako sa Ebay na second-hand ASX HID na buong headlight assembly (one piece lang) na kasama na 'yung lens, $400 lang.
    #2327
    Mahal nga talaga, lalo na malamang pag sa Casa.
    Anyway, kung convenient ka naman sa night driving na tumakbo ng 80kph sa provincial road tingin ko ok na rin ang ilaw ng GLS.
    Sa case ko, naitatakbo ko ng 110kph sa gabi dahil sa lawak at layo ng ilaw lalo na at kabisado ko ang daan. Pero pag kasama ko family ko, 90kph lang para safe.
    Pag madalas na long drive sa gabi, tiyak kakailanganin mo ang HID.
    #2328
    Kay garyq, mahal talaga. Pero tignan mo naman yung output.
    Ikaw na mag-decide kung ready ka to burn your 26k for a headlight upgrade.
    Of course, you can opt for cheaper headlight upgrades such as getting Osram NBs or higher wattage bulbs para halogen pa rin or even try out PNP HID kits then see if your projector provides a good cutoff for it and if it would already suffice.
    #2329
    malaki na din magiging improvement niyan sir kung mag palit ka lang ng HID kit. basta huwag ka lang kukuha ng ibang color temperature, just get 4300k. laki ng difference in price, 2k sa 26k, worry free ka pa sa warranty kasi bolt on lang naman siya sa oem headlamps mo
    Sep 2005
    #2330
    I wont spend 26k on retrofit,hindi kaya ng bulsa ko hehe mas gusto ko pa pang sound setup na lang FOCAL ,or i must say bago lang yun auto nahinayang ako, specially kung 4700km mileage palang yun auto,yun cheap hid china made is ok hindi naman masyado ganun ka glare since projector housing. Or try to upgrade philips extreme vision or piaa night tech both are halogen bulbs.
    Aug 2012
    #2331
    Quote Originally Posted by BRIAN View Post
    Sabi nila, nakakabulag/silaw daw pag di retrofitted. By the way, may alam ba kayo na third-party na ganito? Puro gasgas na 'yung loob ng rear door ko. Thanks.
    Luggage net from zeroism702 on Ebay:
    #2332
    I bought an elastic cargo net "set" from Handyman... also a number of "elastic cord with hooks" to help anchor down loose items in the cargo area. I just hook items (if it has a place to thread the cord or hook) and hook the ends to the anchor points or to the seat headrest posts.
    Aug 2012
    #2333
    Where do you attach it? Can you share a photo? Will make it easier for them to know what I'm looking for. Thanks.
    Aug 2012
    #2334
    Thanks for the tip. I got it at Handyman and it seems OK.
    Bad news: I think I busted my inverter, I accidentally reversed the polarity while DIY-ing the connector for my RC charger. I'm off to Winterpine tomorrow to have it checked. Hopefully it's just the fuse. Otherwise, ouch.
    Aug 2012
    #2335
    Tested the inverter and it's fine. Thankfully, it's just the fuse. Going to Winterpine to have it replaced. Good morning.
    P.S. I got the MacBook Air last Saturday and it's pretty. Unfortunately, it must go. >:->
    May 2011
    #2336
    can't you DIY the fuse replacement?
    Btw, how much was your apple give away? Parang andaya lan, i got 30k worth (8Gb itouch, speck case, extended warranty, car charger & JBL on air) while we have the same GLS model?
    oh well.... mukhang call ng SA lan talaga mam-braso sa management.
    #2337
    Hi guys, its been a while since i logged in...so happy to see our thread to be active..ako lang hindi naging active this few months...been busy sa work...congrats to those guys who just got their asx and sa mga nag EB..sayang di ako makasama...hirap pala kapag change status ka na..hehehe...2 nagiging boss...1 sa work isa sa bahay...di tulad dati I am my boss pagsa bahay..hehehe....
    Been reading the previous post, may nakapag enable na ba sa inyo, guys that has the comp box tools, ng DRL?I saw a fuse sa DRL sa fuse box ng asx natin..I asked the supervisor of casa one time and sabi nya di daw nya sure if enabled daw yun sa program...IMHO, our DRL is the same as the Lancer GTA's cornering light, which is the spot for our high beam, in case sa atin, single contact lang, sa lancer naman double contact (high beam and cornering light).. Na tetemp tuloy ako palitan yung high beam natin ng double contact but dahil nga sa sinabi nung supervisor, may doubt ako...
    Hope one of us here could help...Thanks...I think DRL kasi is necessity na ngayun...dapat standard na sya sa lahat ng kotse tulad ng mga motorcycle..
    Aug 2012
    #2338
    Quote Originally Posted by skybison View Post
    Andami kong kinakalikot sa loob pero di ako marunong magpalit ng fuse. Haha.
    Aug 2012
    #2339
    I think isa lang bulb ng fog light natin. 'Yung pwedeng gawing DRL yata may specific na bulb sa loob ng fog light lens.
    #2340
    Ah ok..may nakikita kasi ako sa youtube na sa headlight yung DRL...depende siguro sa configuration...nagpalit ako ng HID sa fogs ko...single contact lang nakita ko na tinanggal na bulb..hehehe...ang gulo...hehehehe
2010 Mitsubishi ASX Crossover
