WDPN33 PGTW 011500MSGID/GENADMIN/NAVMARFCSTCEN PEARL HARBOR HI/JTWC//SUBJ/
PROGNOSTIC REASONING FOR SUPER TYPHOON 19W (PARMA)WARNING NR 16// RMKS/1. FOR METEOROLOGISTS. 2. 12 HOUR SUMMARY AND ANALYSIS.
A. TYPHOON (TY) 19W (PARMA) HAS WEAKENED OVER THE PAST 12 HOURS TO A TYPHOON. RELATIVELY DRIER AIR OVER THE CENTRAL PHILIPPINES (AS SEEN IN THE 011200Z SOUNDING FROM RPMT) IN THE MID LEVELS HAS CAUSED EROSION OF THE CENTRAL CONVECTION, LOWERING DVORAK INTENSITY ESTIMATES FROM PGTW AND KNES TO 5.5 WITH RJTD REMAINING AT 7.0. THE SYSTEM HAS ALSO ENCOUNTERED MODERATE TO HIGH VERTICAL WIND SHEAR (20 T0 30 KNOTS) ASSOCIATED WITH AN UPPER LEVEL ANTICYCLONE NORTH OF THE SYSTEM.
THESE TWO FACTORS CAUSED A LOSS OF DEEP CONVECTION AROUND THE CENTER. RECENT ANIMATED INFRARED AND WATER VAPOR SATELLITE IMAGERY INDICATES THAT THE SYSTEM IS BEGINNING TO RECOVER. THE SYSTEM HAS CONTINUED TRACKING ON THE SOUTHWESTERN PERIPHERY OF THE SUB-TROPICAL RIDGE TOWARDS NORTHEASTERN LUZON.3. FORECAST REASONING A. THE FORECAST REASONING HAS NOT CHANGED SIGNIFICANTLY SINCE THE LAST PROGNOSTIC REASONING BULLETIN.
B. TY 19W IS EXPECTED TO CONTINUE TRACKING TOWARDS THE NORTHEASTERN COAST OF LUZON, MAKING LANDFALL NEAR TAU 48 BEFORE CROSSING INTO THE LUZON STRAIT NEAR TAU 72.
THE SYSTEM WILL RECOVER INTENSITY, ALTHOUGH IT IS NOT EXPECTED TO RE-INTENSIFY TO SUPER TYPHOON STRENGTH. AVAILABLE NUMERICAL MODEL GUIDANCE IS IN FAIR AGREEMENT WITH THIS TRACK, WITH THE NOTABLE OUTLIERS OF THE GFDN, JGSM, AND GFS MODELS. GFDN TAKES A MORE WESTERLY COURSE INTO CENTRAL LUZON BEFORE CROSSING INTO THE SOUTH CHINA SEA NEAR TAU 48. GFS AND JGSM NEITHER MAKE LANDFALL, WITH JGSM TURNING NORTH-NORTHWESTERLY AFTER TAU 12 AND ASSUMING A MORE WESTERLY COURSE AFTER TAU 48. GFS TURNS NORTH-NORTHWESTERLY AFTER TAU 24, AND RECURVES AFTER TAU 72. THE REMAINING NUMERICAL MODELS (NOGAPS, TCLAPS, WBAR, EGRR AND ECMWF) MAKE LANDFALL NEAR TAU 48 BEFORE BIFURCATING. WBAR AND TCLAPS TURN NORTHWARD INTO THE LUZON STRAIT, WHILE NOGAPS, EGRR AND ECMWF TURN WESTWARD INTO THE SOUTH CHINA SEA.
C. AFTER TAU 72, TY PARMA WILL CONTINUE TO WEAKEN AS IT CONTINUES TO INTERACT WITH NORTHERN LUZON'S TOPOGRAPHY. ONCE IT CROSSES INTO LUZON STRAIT, IT WILL REMAIN AT STRONG TYPHOON INTENSITY.
DURING THIS PERIOD, TYPHOON PARMA WILL SLOW DOWN ITS FORWARD MOTION AS A BREAK IN THE STEERING RIDGE DEVELOPS AND
POSSIBLE INTERACTION WITH TYPHOON 20W (MELOR) COMMENCES. AVAILABLE NUMERIC TRACK GUIDANCE ARE IN FAIR AGREEMENT UP TO TAU 48 AS DISCUSSED ABOVE. AFTER TAU 72
THE TRACK SPEEDS REMAIN SLOW, WITH THIS FORECAST FAVORING THE NOGAPS, EGRR AND ECMWF SOLUTION OF A TURN INTO THE SOUTH CHINA SEA. THE EXTENDED FORECAST FOR TY 19W REMAINS COMPLICATED BY POSSIBLE INTERACTION WITH TY 20W TO THE EAST AND INTERACTION WITH A MIDLATITUDE TROUGH TO THE NORTH (THE SOURCE OF THE BREAK IN THE STEERING RIDGE).//NNNN
