Page 39 of 71 FirstFirst ... 2935363738394041424349 ... LastLast
Results 761 to 780 of 1411
    Nov 2017
    #761
    Guys quick question. Is there really a surety bond to be paid to DPWH for altering the top of their drainage into a ramp?
    They're asking for what seems like 20-30% of the cost of the drainage section as a surety bond. Non refundable daw. 1st time I've heard of a bond that's non refundable.
    Did this drainage in front of your house? So why you need ramp?
    #762
    Quote Originally Posted by maxpedition View Post
    It's for a commercial property along the highway bro. Ok na. Talked to the right person already. Seems someone just wanted to make a quick buck. Thanks
    Nov 2017
    #763
    You can submit a written letter of request address to the DE in your place. Alam mo naman DPWH kailangan in papers lahat. Nice to hear naayos mo na. [emoji106]
    meron pang percentage na nalalaman lol. glad you got it sorted fast
    #765
    Thanks guys. I read the DO and it checked out naman. Kinda bummed that cash bonds aren't accepted anymore but at least the final quote for the bond was a lot lower.
    First quote was a multiple of the amount indicated in the DO though. Hmmmmm
    Anyway am glad that's over and done with.
    Jan 2016
    #766
    Hi again masters, inabutan ko yung workers doing the beam with rebars placed at the middle of both sides, pinaalis ko Ang had it placed at the top and bottom as the plan calls for 3 16mm for top and bottom. I just want to know if may silbi ba talaga ung nilagay nila na side bars, I searched the internet and all beams call for top and bottom rebars only. The foreman I got kasi doesn't know how to read plans and if I don't guide them, they will do things the way they were accustomed to
    Sent from my Mi A1 using Tapatalk
    #767
    Yes, in conventional applications, top & bottom beam bars handle the tensile stresses transmitted from vertical loads. Concrete alone can't handle tension. If a beam were designed to resist horizontal flexural or torsional stresses, then you'll need em where your crew initially placed em.
    Jan 2016
    #768
    Sir Travs, I guess it was not a consideration, as the plan calls for just top and bottom bars, with extra bars for some beams. Thank you.
    #769
    You exercised good judgement by following the plans, papi sir![emoji106]
    Jan 2016
    #770
    Question again Sirs, we decided to use drywall as room divisions, are these sturdy enough? Sabi kasi ng foreman, I need to use wood instead of metal for frames para daw di uuga. I was thinking if this is true or di lang sya marunong mag latag Ng metal frame
    #771
    Metal is fine. You won't be bothered w/ wood borers. You can budget-insulate w/ fire-rated polystyrene of the stud thickness stuffed between wall panels. Just prep areas where you might wanna hang or attach heavy items. If you need to randomly hang light frames, check for the proper drywall anchors like those in pic for your desired application. You could space your vertical studs 16"oc instead of 24", should you want sturdy, sir.
    Jan 2016
    #772
    Thanks Sir Travs, is 16" already the perfect balance in terms of economy and strength?
    #773
    Yeah...drywalls are commonly 48" wide. 16" would give you studs at 3rd of width....way sturdier than half w/c 24"oc gives.
    You may keep the horizontals 8' apart(board height) or half that. Sample a panel to get the feel of stability you're ok with.
    #774
    Jan 2016
    #775
    Sir Travs, do you have better alternatives in mind? I also saw at Philconstruct, a lightweight board made of mixed polystyrene and cement and another, a polystyrene board with welded wire mesh at both sides for plaster, any comment on these two? Thanks [emoji4]
    #776
    Yeah, alternative boards & 3D panels(EVG is the popular brand) have their advantages. The latter is locally licensed by Eastern Wire Mfg, Inc. It's pretty simple & doable. Great if you've shotcrete. It'll be lighter but harder to break than your traditional CHB. Compare costs & manpower load/skill requirements. Discussions on these will be lengthy & boring.[emoji4]
    Read up on the system instead? Call will be yours.
    EVG – Hersteller fur Schweissanlagen, Drahtrichtmaschinen, Kaltwalzanlagen, Betonstahl-/ Betonfertigteile-Anlagen
    Jan 2016
    #777
    Nice! I'll try to explore this 3D panel, thanks Sir Travs!
    #778
    Anytime, sir.
    Nov 2017
    #779
    Wall Plastering 1 - YouTube
    Jan 2016
    #780
    Maganda nga yan Sir Max if one has the equipment, sakin mano mano lang, division lang naman ng rooms sa 2F
House Constuction [Merged]
