Page 30 of 71 FirstFirst ... 2026272829303132333440 ... LastLast
Results 581 to 600 of 1411
    #581
    Meron nga pala kami mga kakilala na carpenters sa province who build houses there. Issue namin kasi baka di nila alam rules dito as well as the drainage system etc..
    Posted via Tsikot Mobile App
    Sep 2008
    #582
    Quote Originally Posted by raycom10 View Post
    Plan ko kasi pagawa ng bungalow house 2 bedroom lng. Is 300k enough?
    probably pwede sir kung sa province pagagawa, mdyo mura labor, sand & gravel as compared sa urban areas.
    #583
    kaya yan. but your house would look like a temporary facility / bunkhouse - but with a creative architect, anything is possible. I actually love minimalistic (or industrial) themed dwelling. (example below - i dont own the picture)
    #584
    P5000 for materials and P4000 for labor to prepare and paint one wall in a 25 square meter long area? What is done ba sa paint preparation?
    Hindi ako makaintindi ng 2d layout
    #585
    length and height of wall? also, what kind of paint finish would you want (rough or as-is from plastering or very smooth)
    #586
    mahal ntalaga yung paint
    #587
    Quote Originally Posted by poorprince View Post
    Height probably 9 ft. Yung length is the length of a 25 sq meter area, one wall na pahaba. They will use 2 coats. Rough finishing.
    #588
    ano po ba ang pipinturahan? wood or concrete?
    basic steps:
    1 - cleaning
    2 - sanding
    3 - plastering
    4 - "lason" (neutralizer for concrete)
    5 - primer application (1st - nth coating)
    6 - finishing
    7 - cleaning (tapos na... yehey!!!)
    some of the steps are required to be repeated in order to achieve the desired "finish".
    for most "small" painting jobs, material cost = labor cost.
    kadalasan kasi, kahit sa owner na lahat ng gastos sa materials tapos
    bayaran niya na lang 'yung taong gagawa (arawan), halos pareho lang talaga. HTH
    #589
    5k for painting materials is just about right for a wall 9ft (3m) high covering a 25 sqm area. Assuming the 25sqm (5m x 5m) area is covered on ALL 4 SIDES by a 3m high wall. You might need minimum 2 Gallons flat latex for primer coat and minimum 4 Gal of semigloss latex (2 coats) for the final coat. Plus minimum 2 gallons of concrete neutralizer to prepare your surface since its only "roughed" finish, plus misc items. Labor cost, 4k? dont know, i can haggle for 2k siguro if rough finish. I'm no expert though. Hope this helps.
    #590
    Quote Originally Posted by joemarski View Post
    basic steps:
    1 - cleaning
    2 - sanding
    3 - plastering
    6 - finishing
    concrete
    It's just one long wall. 5 days gagawin. Nagulat lang ako sa cost ng pag paint ngayon Puro algae na kasi yung wall e
    #591
    concrete
    yep! paint isnt cheap, especially the branded ones. 5 days? hmm. might be a lot of cleaning and surface prep if thats the case.
    #592
    I need to have part of our perimeter cemented because I want to move my treadmill in that area. It's currently grass. To get there you need to pass the garden so I am afraid that it might flood if I don't get a good contractor. And since I only want a small part of the perimeter, there will be a grass area again. The left side of the wall has bamboo, yung right side wall na ng bahay namin. I don't know the width of our perimeter basta yung standard lang.
    Yung contractor ko kasi mahal sumingil pero pulido. He recommended paving blocks para makatipid. His estimate last year was Paving block P12 x 1000 = P12000 + labor P4800 + sand P1500 = P18300. Pwede na yun?
    Mar 2013
    #593
    Yep that's decent. At least you trust him to enter your house.
    Feb 2009
    #594
    If there is history of algae and mildew, add a corresponding amount of mildewcide to the paint prior to application
    #595
    Happy New Year ka Tsikots!!! Need help from here.
    Naghahanap po ako ng contractor for my House. A 100sqm 2 sty house. Location po is near Southwoods Exit. Please PM me for more details.
    Maraming salamat po.
    You can contact me also at : bong722*yahoo.com
    Jan 2016
    #596
    patulong naman po..may contractor na po kami para sa papagawa naming house sagot din nila yung architect..gusto ko lang po i-confirm kung ok yung mga materials na nakalagay dito sa BOM na binigay nila. wala po kasi ako masyadong alam s mga materyales sa bahay.
    kung may comment po kayo or suggestion it will help me a lot.
    pasensya na kung mahaba..salamat in advance
    EARTHWORKS
    a. Excavation
    b. Backfilling/Compaction
    c. Gravel Bed
    d. Anti-Termite (pre-construction)
    FORMWORKS
    a. Coco Lumber2"x3"x10'
    b. Plywood 3/8" thk (10mm thk)
    c. Metal Deck 0.80mm thk
    d. Assorted CW Nails
    DEFORMED REINFORCING BARS
    a. DRB 16mm*φ x 6m
    b. DRB 12mm*φ x 6m
    c. DRB 10mm*φ x 6m
    d. GI Wire # 16
    e. Consummables
    CONCRETE WORKS
    a. Portland Cement
    b. Washsand
    c. Gravel 3/4
    MASONRY WORKS
    a. CHB 4" thk (Internal)
    b. CHB 5" thk (External)
    c. Portland Cement
    d. Washsand
    e. Def. Rebar 10mm φ
    f. GI Wire # 16
    PLASTERING WORKS
    a. Portland Cement
    b. Vibrosand
    DOORS & WINDOWS
    a. D-1* 0.90 x 2.10 Panel Door
    b. D-2* 0.80 x 2.10 Panel Door
    c. D-3* 0.80 x 2.10 Panel Door
    d. D-4* 0.70 x 2.10 Panel Door
    e. D-5* 2.80 x 2.10 Sliding Alum Door
    f. D-6 1.40 x 2.10 Sliding Alum Door
    g. Door Jambs 2" x 4"
    h. W-1* 1.20 x 1.20m Alum powder coated
    i. W-2* 0.60 x 1.20m Alum Powder coated
    j. W-3* 1.20 x 0.90m Alum Powder coated
    k. W-4* 1.20 x 0.90m Alum Powder coated
    l. Inlet Screen
    CEILING WORKS
    a. Hardiflex 4.5mm thk
    b. Metal Furring Double
    c. Carrying Channel
    d. Consummables
    ROOF FRAMING & ROOFING
    a. Angle Bar 3/16" thk x 2" x 2"
    b. Cee Purlin 2" x 3" 1.2mm
    c. Cee Purlin 2" x 4" 1.2mm
    d. 12mm sag rod
    e. Welding Rod 1/8
    f. Marine Plywood 1/2" thk 4' x 8"
    g. Asphalt Roof Shingles (requirement ng subdivision)
    h. Consummables
    FLOOR & WALL FINISHES
    a. Ceramic Floor Tiles
    b. CR Floor Tiles
    c. CR Wall Tiles
    d. Tile Adhesive 25kg/bag
    e. Tile Grout 5kg/bag
    f. Washsand
    g. Cement
    BUILT-IN CABINETS
    a. 3/4" thk Plyboard
    b. KD S4S 1/2 x 2 x 8
    c. Granite Slab Kit Counter
    d. Consummables
    e. Wooden Baseboard
    PLUMBING WORKS - ROUGH-INS SANITARY
    a. HCG Watercloset
    b. HCG Lavatory set
    c. Shower Head and Valve Set
    d. Faucet
    e. Kitchen sink and Faucet
    f. Floor Drain 4" x 4"
    g. PVC Pipe 4" φ S1000 - Sanitary
    h. PVC Pipe Fittings - Sanitary
    i. HCG Bathtub
    CONST OF SEPTIC TANK
    a. Excavation
    b. Hollow Blocks 4" thk
    c. DRB 10mm φ x 6m
    d. PVC Pipe Fittings - Sanitary
    e. Portland Cement
    f. Washsand
    ELECTRICAL WORKS
    a. Service Entrance
    b. Panelboard
    c. THWWire 5.5 mm2
    d. THWWire 14 mm2
    e. THWWire 3.5 mm2
    f. PVC Pipe 20mm
    g. Utility/Junction boxes
    h. Receptacle 4" x 4"
    i. Convenience Outlet
    j. Switches
    k. Consummables
    STORM DRAINAGE SYSTEM
    a. PVC Pipe 3" φ S1000 - Sanitary
    b. Area Drain / Catch Basin
    PAINTING WORKS
    a. Semi Gloss Latex Finish
    b. Elastomeric Paint - Exterior Wall
    c. Flat Latex Paint Finish
    d. Ducco Paint Finish
    e. QDE Paint Finish
    Jan 2012
    #597
    Quote Originally Posted by alaejos1223 View Post
    EARTHWORKS
    a.Excavation
    b.Backfilling/Compaction
    c.Gravel Bed
    d.Anti-Termite (pre-construction)
    FORMWORKS
    a.Coco Lumber2"x3"x10'
    b.Plywood 3/8" thk (10mm thk)
    c.Metal Deck 0.80mm thk
    d.Assorted CW Nails
    a.DRB 16mm*φ x 6m
    b.DRB 12mm*φ x 6m
    c.DRB 10mm*φ x 6m
    d.GI Wire # 16
    e.Consummables
    CONCRETE WORKS
    a.Portland Cement
    b.Washsand
    c.Gravel 3/4
    MASONRY WORKS
    a.CHB 4" thk (Internal)
    b.CHB 5" thk (External)
    c.Portland Cement
    d.Washsand
    e.Def. Rebar 10mm φ
    f.GI Wire # 16
    PLASTERING WORKS
    a.Portland Cement
    b.Vibrosand
    DOORS & WINDOWS
    a.D-1* 0.90 x 2.10 Panel Door
    b.D-2* 0.80 x 2.10 Panel Door
    c.D-3* 0.80 x 2.10 Panel Door
    d.D-4* 0.70 x 2.10 Panel Door
    e.D-5* 2.80 x 2.10 Sliding Alum Door
    f.D-6 1.40 x 2.10 Sliding Alum Door
    g.Door Jambs 2" x 4"
    h.W-1* 1.20 x 1.20m Alum powder coated
    i.W-2* 0.60 x 1.20m Alum Powder coated
    j.W-3* 1.20 x 0.90m Alum Powder coated
    k.W-4* 1.20 x 0.90m Alum Powder coated
    l.Inlet Screen
    CEILING WORKS
    a.Hardiflex 4.5mm thk
    b.Metal Furring Double
    c.Carrying Channel
    d.Consummables
    a.Angle Bar 3/16" thk x 2" x 2"
    b.Cee Purlin 2" x 3" 1.2mm
    c.Cee Purlin 2" x 4" 1.2mm
    d.12mm sag rod
    e.Welding Rod 1/8
    f.Marine Plywood 1/2" thk 4' x 8"
    g.Asphalt Roof Shingles (requirement ng subdivision)
    h.Consummables
    a.Ceramic Floor Tiles
    b.CR Floor Tiles
    c.CR Wall Tiles
    d.Tile Adhesive 25kg/bag
    e.Tile Grout 5kg/bag
    f.Washsand
    g.Cement
    BUILT-IN CABINETS
    a.3/4" thk Plyboard
    b.KD S4S 1/2 x 2 x 8
    c.Granite Slab Kit Counter
    d.Consummables
    e.Wooden Baseboard
    a.HCG Watercloset
    b.HCG Lavatory set
    c.Shower Head and Valve Set
    d.Faucet
    e.Kitchen sink and Faucet
    f.Floor Drain 4" x 4"
    g.PVC Pipe 4" φ S1000 - Sanitary
    h.PVC Pipe Fittings - Sanitary
    i.HCG Bathtub
    a.Excavation
    b.Hollow Blocks 4" thk
    c.DRB 10mm φ x 6m
    d.PVC Pipe Fittings - Sanitary
    e.Portland Cement
    f.Washsand
    ELECTRICAL WORKS
    a.Service Entrance
    b.Panelboard
    c.THWWire 5.5 mm2
    d.THWWire 14 mm2
    e.THWWire 3.5 mm2
    f.PVC Pipe 20mm
    g.Utility/Junction boxes
    h.Receptacle 4" x 4"
    i.Convenience Outlet
    j.Switches
    k.Consummables
    a.PVC Pipe 3" φ S1000 - Sanitary
    b.Area Drain / Catch Basin
    PAINTING WORKS
    a.Semi Gloss Latex Finish
    b.Elastomeric Paint - Exterior Wall
    c.Flat Latex Paint Finish
    d.Ducco Paint Finish
    e.QDE Paint Finish
    Normal specs for an average house. Try to compare it with the architectural specs
    Mar 2015
    #598
    Bale ito yun mga materials na gagamitin po sa construction sir pero d naman po naka indicate yun quantity at description nang work po. General lang po ito. Dapat po araw araw nyo tignan yun ginagawa at kausapin nyo yun foreman sa site. Tignan nyo lang na d po tinipid sa materyales sir at sa halo nang cement. Baka po malabnaw.
    Dami po kasing detalye yan sir mahirap lahat isa isahin po. Mas maganda po lagi nyo puntahan para mabantayan nyo mabuti yun ginagawa po
    Apr 2015
    #599
    ^^^Ung quantity ng excavation ng septic tank, hindi pa ba kasama sa quantity ng excavation sa earthworks?
    Regarding tile works, saan gagamitin ang tile adhesive, kasi may cement pa, kung kailangan pang i level ang floor area gagamitin ang cement at sand, and ussually cement na rin ang gagamitin pang set ng tiles kasabay na ang trabaho nyan habang ni lelevel ang floor area, karaniwan ung adhessive ginagamit pag nasa level na ang floor or wall. at kadalasan kahit naka rough finish na ang wall pwede na ang cement pang setting ng tiles. mas mahal ata ang tile adhessive kesa sa cement?
    Apr 2015
    #600
    Sa sanitary line parang kailangan mo pa ng 2"dia na pipe para sa kitchen sink at lavatory pati na vent pipe. Napansin ko rin na walang nabanggit na materials para sa cold water line o drinking water line o baka naka lump sum na.
    Ung door jamb mo parang maliit, considering na 4" na ang chb mo sa interior plus plastering. At sa exterior wall mo 5" ang chb plus plastering. Hindi mag pa flush sa wall thickness ang door jamb size, opinyon ko lang pangit tingnan.
House Constuction [Merged]
