Quote Originally Posted by alaejos1223 View Post
patulong naman po..may contractor na po kami para sa papagawa naming house sagot din nila yung architect..gusto ko lang po i-confirm kung ok yung mga materials na nakalagay dito sa BOM na binigay nila. wala po kasi ako masyadong alam s mga materyales sa bahay.
kung may comment po kayo or suggestion it will help me a lot.
pasensya na kung mahaba..salamat in advance
EARTHWORKS
a.Excavation
b.Backfilling/Compaction
c.Gravel Bed
d.Anti-Termite (pre-construction)
FORMWORKS
a.Coco Lumber2"x3"x10'
b.Plywood 3/8" thk (10mm thk)
c.Metal Deck 0.80mm thk
d.Assorted CW Nails
DEFORMED REINFORCING BARS
a.DRB 16mm*φ x 6m
b.DRB 12mm*φ x 6m
c.DRB 10mm*φ x 6m
d.GI Wire # 16
e.Consummables
CONCRETE WORKS
a.Portland Cement
b.Washsand
c.Gravel 3/4
MASONRY WORKS
a.CHB 4" thk (Internal)
b.CHB 5" thk (External)
c.Portland Cement
d.Washsand
e.Def. Rebar 10mm φ
f.GI Wire # 16
PLASTERING WORKS
a.Portland Cement
b.Vibrosand
DOORS & WINDOWS
a.D-1* 0.90 x 2.10 Panel Door
b.D-2* 0.80 x 2.10 Panel Door
c.D-3* 0.80 x 2.10 Panel Door
d.D-4* 0.70 x 2.10 Panel Door
e.D-5* 2.80 x 2.10 Sliding Alum Door
f.D-6 1.40 x 2.10 Sliding Alum Door
g.Door Jambs 2" x 4"
h.W-1* 1.20 x 1.20m Alum powder coated
i.W-2* 0.60 x 1.20m Alum Powder coated
j.W-3* 1.20 x 0.90m Alum Powder coated
k.W-4* 1.20 x 0.90m Alum Powder coated
l.Inlet Screen
CEILING WORKS
a.Hardiflex 4.5mm thk
b.Metal Furring Double
c.Carrying Channel
d.Consummables
ROOF FRAMING & ROOFING
a.Angle Bar 3/16" thk x 2" x 2"
b.Cee Purlin 2" x 3" 1.2mm
c.Cee Purlin 2" x 4" 1.2mm
d.12mm sag rod
e.Welding Rod 1/8
f.Marine Plywood 1/2" thk 4' x 8"
g.Asphalt Roof Shingles (requirement ng subdivision)
h.Consummables
FLOOR & WALL FINISHES
a.Ceramic Floor Tiles
b.CR Floor Tiles
c.CR Wall Tiles
d.Tile Adhesive 25kg/bag
e.Tile Grout 5kg/bag
f.Washsand
g.Cement
BUILT-IN CABINETS
a.3/4" thk Plyboard
b.KD S4S 1/2 x 2 x 8
c.Granite Slab Kit Counter
d.Consummables
e.Wooden Baseboard
PLUMBING WORKS - ROUGH-INS SANITARY
a.HCG Watercloset
b.HCG Lavatory set
c.Shower Head and Valve Set
d.Faucet
e.Kitchen sink and Faucet
f.Floor Drain 4" x 4"
g.PVC Pipe 4" φ S1000 - Sanitary
h.PVC Pipe Fittings - Sanitary
i.HCG Bathtub
CONST OF SEPTIC TANK
a.Excavation
b.Hollow Blocks 4" thk
c.DRB 10mm φ x 6m
d.PVC Pipe Fittings - Sanitary
e.Portland Cement
f.Washsand
ELECTRICAL WORKS
a.Service Entrance
b.Panelboard
c.THWWire 5.5 mm2
d.THWWire 14 mm2
e.THWWire 3.5 mm2
f.PVC Pipe 20mm
g.Utility/Junction boxes
h.Receptacle 4" x 4"
i.Convenience Outlet
j.Switches
k.Consummables
STORM DRAINAGE SYSTEM
a.PVC Pipe 3" φ S1000 - Sanitary
b.Area Drain / Catch Basin
PAINTING WORKS
a.Semi Gloss Latex Finish
b.Elastomeric Paint - Exterior Wall
c.Flat Latex Paint Finish
d.Ducco Paint Finish
e.QDE Paint Finish
Normal specs for an average house. Try to compare it with the architectural specs
