patulong naman po..may contractor na po kami para sa papagawa naming house sagot din nila yung architect..gusto ko lang po i-confirm kung ok yung mga materials na nakalagay dito sa BOM na binigay nila. wala po kasi ako masyadong alam s mga materyales sa bahay.
kung may comment po kayo or suggestion it will help me a lot.
pasensya na kung mahaba..salamat in advance
EARTHWORKS
a. Excavation
b. Backfilling/Compaction
c. Gravel Bed
d. Anti-Termite (pre-construction)
FORMWORKS
a. Coco Lumber2"x3"x10'
b. Plywood 3/8" thk (10mm thk)
c. Metal Deck 0.80mm thk
d. Assorted CW Nails
DEFORMED REINFORCING BARS
a. DRB 16mm*φ x 6m
b. DRB 12mm*φ x 6m
c. DRB 10mm*φ x 6m
d. GI Wire # 16
e. Consummables
CONCRETE WORKS
a. Portland Cement
b. Washsand
c. Gravel 3/4
MASONRY WORKS
a. CHB 4" thk (Internal)
b. CHB 5" thk (External)
c. Portland Cement
d. Washsand
e. Def. Rebar 10mm φ
f. GI Wire # 16
PLASTERING WORKS
a. Portland Cement
b. Vibrosand
DOORS & WINDOWS
a. D-1* 0.90 x 2.10 Panel Door
b. D-2* 0.80 x 2.10 Panel Door
c. D-3* 0.80 x 2.10 Panel Door
d. D-4* 0.70 x 2.10 Panel Door
e. D-5* 2.80 x 2.10 Sliding Alum Door
f. D-6 1.40 x 2.10 Sliding Alum Door
g. Door Jambs 2" x 4"
h. W-1* 1.20 x 1.20m Alum powder coated
i. W-2* 0.60 x 1.20m Alum Powder coated
j. W-3* 1.20 x 0.90m Alum Powder coated
k. W-4* 1.20 x 0.90m Alum Powder coated
l. Inlet Screen
CEILING WORKS
a. Hardiflex 4.5mm thk
b. Metal Furring Double
c. Carrying Channel
d. Consummables
ROOF FRAMING & ROOFING
a. Angle Bar 3/16" thk x 2" x 2"
b. Cee Purlin 2" x 3" 1.2mm
c. Cee Purlin 2" x 4" 1.2mm
d. 12mm sag rod
e. Welding Rod 1/8
f. Marine Plywood 1/2" thk 4' x 8"
g. Asphalt Roof Shingles (requirement ng subdivision)
h. Consummables
FLOOR & WALL FINISHES
a. Ceramic Floor Tiles
b. CR Floor Tiles
c. CR Wall Tiles
d. Tile Adhesive 25kg/bag
e. Tile Grout 5kg/bag
f. Washsand
g. Cement
BUILT-IN CABINETS
a. 3/4" thk Plyboard
b. KD S4S 1/2 x 2 x 8
c. Granite Slab Kit Counter
d. Consummables
e. Wooden Baseboard
PLUMBING WORKS - ROUGH-INS SANITARY
a. HCG Watercloset
b. HCG Lavatory set
c. Shower Head and Valve Set
d. Faucet
e. Kitchen sink and Faucet
f. Floor Drain 4" x 4"
g. PVC Pipe 4" φ S1000 - Sanitary
h. PVC Pipe Fittings - Sanitary
i. HCG Bathtub
CONST OF SEPTIC TANK
a. Excavation
b. Hollow Blocks 4" thk
c. DRB 10mm φ x 6m
d. PVC Pipe Fittings - Sanitary
e. Portland Cement
f. Washsand
ELECTRICAL WORKS
a. Service Entrance
b. Panelboard
c. THWWire 5.5 mm2
d. THWWire 14 mm2
e. THWWire 3.5 mm2
f. PVC Pipe 20mm
g. Utility/Junction boxes
h. Receptacle 4" x 4"
i. Convenience Outlet
j. Switches
k. Consummables
STORM DRAINAGE SYSTEM
a. PVC Pipe 3" φ S1000 - Sanitary
b. Area Drain / Catch Basin
PAINTING WORKS
a. Semi Gloss Latex Finish
b. Elastomeric Paint - Exterior Wall
c. Flat Latex Paint Finish
d. Ducco Paint Finish
e. QDE Paint Finish
