Page 72 of 81 FirstFirst ... 2262686970717273747576 ... LastLast
Results 711 to 720 of 808
    Jan 2016
    #711
    Do you mean a fence as high as a firewall? For me palitada is enough. Painting it with a quality brand would be better for aesthetis. Pwede rin pahiran mo waterproofing like boysen plexibond konting dagdag gastos na lang naman yan.
    Mas mabuti na ito ang gawin mo kaysa move away a bit kasi ending nyan mas lalong exposed ang wall mo to rain at mas lalong mamamasa sa loob.
    But the question is kung yard naman pala sa side mo why waterproof pa? Dahil uulanin din naman ang side mo.
    #712
    There is this video I've watched na nag suggest wag isagad ang firewall sa property line for waterproofing maintenance in the future. Although yung 3 sides ng paggawa namin bahay walang mga katabi pa, maybe years or even decades pa siguro bago magka katabi, we have to set it back 600mm daw suggested. I'm just worried that Kung mag leave kami 600mm from property line baka yung future katabi eh mag encroach.
    Kailangan ba may waterproof ang firewall kahit yard naman ang loob ng firewall?
    ask the authorities or the homeowners' association, if there are laws regarding "sagaran nang bahay sa property line".
    should you decide for the 600 mm setback, you can erect a fence, to mark your property line.
    if the other side of the firewall is not weather-sensitive naman, there would be no need to water proof it.
    happy building.
    #713
    Don't do that....This is what we have done for those who've had it w/ firewall troubles. Note the wall is windowless to pass easement restrictions; the roof is gutterless & the rain just hits the trench. Will never leak, no maintenance...& you'll have access to trench-cleaning. Build & forget.[emoji16]20230728_122900.jpg
    Sent from my SM-S901E using Tsikot Forums mobile app
    #714
    I personally never wish to do periodic maintenance call-backs. I will never do gutters w/in firewalls, nor firewalls w/o longspan cladding.
    Waterproofing mentioned will need a lot of luck, would almost always fail & require periodic reapplication. I'd rather humbly decline such work.
    #715
    reminds me of our firewall.
    nothing paint-able or spray-able worked for long.
    we finally tacked in flat GI sheets. wala pang longspan cladding, back then.
    after over 40 years, it still hasn't re-leaked.
    #716
    Cure is fine, prevention best. Right, doc?[emoji4]
    Jan 2016
    #717
    Pagnanalo ako sa lotto, papagawa ako ng bahay na walang firewall [emoji4]
    #718
    Hehe...& should you plan roofdecks(worse than firewalls), roof em. [emoji4]
    #719
    this is so true!
    we tried all sorts of waterproofing on our veranda (deck), but they all failed over time. after we installed a roof, there were no more traces of water streaks at the bottom (this deck also served as roof for our dirty kitchen).
    #720
    this is so true!
    Gotta respect nature. Fighting it is bad gambling. The house always wins.[emoji38]
House Construction
