Results 741 to 750 of 808
December 6th, 2023 02:18 PM #741
Design professionals won't tell you nor admit this...the fitout sector has long been relieving them a lot of their creative & presentational chores. Most would even be more technically knowledgeble. Cabinet design is generally a built-in service as they'd have to do detailed shop drawings prior to execution anyway.
To skirt added design costs, determine your wants/needs & explore pro fitout/cabinet providers. Check & compare their quality, service, reviews & affordability. Loop your architect in to make sure all his design aspects & language are all tied in.
Sent from my SM-S901E using Tsikot Forums mobile app
- Nov 2017
- 289
December 6th, 2023 03:25 PM #742Agree that they wont tell you the cost, its only when you go thru with them that you will see all this cost. Good to see very detailed drawings from your concept, translate to 3D view, and actual site measurements (at least a few times to confirm based on owners concept).
Choices of materials adds to the cost. But sometimes its a wants and needs.
But all those major areas of the haus like kitchen (a good place to entertain too), bathroom fixtures and cabinets in the dining area, worth to get a professional or a good contractor.
About to finish and its on some final detailed works [emoji4]
January 1st, 2024 01:07 PM #743
Which is more expensive, glass partition or concrete? How much per square meter / foot is glass compared to insulated concrete wall / AAC blocks?
January 1st, 2024 06:43 PM #744
Cost will always be relative to specific types/brands of partitions.
Look into 3D panels such as EVG. Lighter, stronger, easier to install w/ way better insulation. You'll never wish for blocks ever again.
In choosing glass frame options, skip the common local generic extrusions the skip the rails w/ poor moisture & sound seals.
From 1st hand experience, if budget affords, Ķömmerling & Deceuninck sections have long been tested & trusted. The former has very good presence & support. Oz standard sections are pretty good, too.
January 2nd, 2024 11:18 AM #746
Even better for exterior app.
January 2nd, 2024 12:17 PM #747
EVG 3D panels are same as SRC? ... What about AAC blocks? ...
January 2nd, 2024 03:05 PM #748
I prefer 3D panels over lightweight aerated blocks where both are applicable.
https://evg.com/en/evg-3d/
- Feb 2014
- 2,694
March 18th, 2024 02:17 PM #749
better heat insulation yung SRC panel, right?
btw i'm going to build a small parking shed. what can you say about onduline roofing? no need to use foam/foil insulation like you would on a metal roof, right? it's just gonna be for the car and i just don't wanna feel the heat while working on the car
- 54,186
March 18th, 2024 02:47 PM #750... a corrugated roof with no kisame.
make it a double, with a few inches breathing space between the two layers, for heat insulation.
and if the outer layer leaks, the lower layer may be able to compensate.
very little maintenance needed.Last edited by dr. d; March 18th, 2024 at 02:57 PM.
I do not have technical knowledge on cars. Since I am scouting for a new ride (I already have an...
BYD Sealion 6 DM-i
