Page 24 of 41 FirstFirst ... 1420212223242526272834 ... LastLast
Results 461 to 480 of 809
    #461
    Pwede ba directly i-swap ang water pump to an inverter pump? Need pa ba ng pressure tank if naka inverter na?
    You mean pump inverter, sir? Yes, you'll need a pressure tank.
    Read more here:
    What is a water pump inverter and other FAQs - 3P Technik UK Ltd
    Sent from my SM-S901E using Tsikot Forums mobile app
    #462
    Read more here:
    Just as I thought. Sabi kasi ng tubero ko no need for a pressure tank. Sabi ko e di pag nag brownout while naliligo ako, hindi ako makapag banlaw.
    So pwede ba direct swap ang water pump to an inverter type? Need ba palitan yung pressure switch?
    Signature
    #463
    Consult your supplier on specs of your choice. Some like Grunfos got models that come complete, others just separate the inverter/pressure components from the variable frequency motor.
    Grundfos CMBE Variable Speed Water Pump (inverter) - Best Price
    #464
    From the Grundfos site, wala ng pressure tank after the pump, direct to home pipings na.
    And available kaya yang Grundfos inverter dito?
    Signature
    #465
    See that gray thing on top? That's an 8L pressure tank on the Grundfos CMBE. The brand is distributed locally.screenshot_20220807-005707_chrome.jpg
    #466
    There is....
    #467
    There is....
    our folks used to have that type of xx liter tank.
    it irritated me, because everytime someone washed his hands, the electric pump would run. it wasn't obnoxiously noisy, but i could hear it, nontheless.
    and eveerytime there was poweer outage, thee entiree house had no water.
    i imagine, one reason folks would settle for this, is because they had no space for the much bigger pressure tank.
    i think, a local brand offers/used to offer something very similar.
    adjacent to the generic electric pump, was a small pressure tank 1 foot wide x 1 or 2 feet tall.
    with out current "full-size" pressure tank system, we still had running water even if there was brownout or the nawasa dried up... until the tank pressure equalized, that is.
    #468
    Stainless? Come replacement time, go Wellmate, doc. Pressure will be stable longer. No more periodic draining. No risks of bursting at the seams/welds.51mnne3syal.jpg
    #469
    yespo. stainless.
    the problem nga, is the gradual decrease in the air bubble.
    the air bubble gradually decreases, because air under pressure slowly dissolves into the water below it.
    so this wellmate has an air bladder instead of air in direct contact with the water?
    kinda like the airplane fuel tanks of WW2.
    i wonder... how much locally?
    addendum.
    i googled for price...
    yikes!!!
    stinless na lang!
    #470
    yespo. stainless.
    addendum.
    yikes!!!
    stinless na lang!
    So many variables to determine the proper Wellmate(or similar) size, doc. The pump output/size, runtime, cut in/out pressures set. Avoid relatively comparing your existing stainless tank capacity vs bladder tank's 1:1. With proper computation, you might not need 1 as big as what you have. The yikes might just turn yay.[emoji4]
    Below is a sample computation of figuring the ideal size.
    You may also just fill in the blanks here to get the tank size you need:
    https://www.aquascience.net/products...pressure-tanks
    Jan 2016
    #471
    Just discovered that wall in our room on the ground floor has paint coming off and moisture on some parts. I know the best way to address this is to find and seal all crevices outside which unfortunately is covered by the neighbors wall.
    Was planning to paint it with waterproofing paint. Is there a better way? Or is there a superior product you know of which I should use?
    So now we know why the room is always moldy.
    Jan 2016
    #472
    Jan 2016
    #473
    Jun 2008
    #474
    Check out Boysen aquaseal bro. Scrape off the affected part and then apply. Baka may seepage from neighbor's wall kaya nag ddamp yung wall mo. May problema din ako samin ng flaking wall sa loob pag nababasa yung exterior wall.
    #475
    if the water is seeping in from the other side of your wall,
    you will have to do something on the outside, to prevent the water from seeping into your concrete wall. painting it on the inside will only work for a short time.
    it is also possible, that your neighbor has the same problem with his wall.
    if so, you should join forces. install a cover between your two walls, to divert rain from both your wall exteriors so that rain water won't be able to fall in and seep thru both your walls.
    Jun 2008
    #476
    Agree with you Doc, probably they are firewall to firewall. They need to put a capping on top of the exterior wall to prevent water seepage.
    Jan 2016
    #477
    Quote Originally Posted by gongrhey View Post
    Thanks, na solve ba ng Aquaseal?
    Edit: pang bare substrate lang pala ito
    Jan 2016
    #478
    I saw this rain or shine hydrolock, unfortunately wala ata silang website kaya I cannot find any info on the preparation required. Don't even know if it can be painted over paint. Anyone familiar with this? img_20220815_084830.jpgimg_20220815_084850.jpg
    Jan 2012
    #479
    I'd check the flashing between the the two firewalls in the roof since that is the source of the leak. The rain or shine hydrolock should work since the leak is negative pressure.
    Instructions for paint are usually printed on the bucket. You will most likely have to peel off the existing paint
    Jan 2016
    #480
    Thanks, I watched 2 yt vids on this and they both recommend stripping the old paint. One was recommending his products (buildrite) while the other was just trying to share and says that any cementitious paint will do the trick.
    But they both agreed that this is a solution for situations like mine where houses are built side by side therefore difficult to address externally. And they mentioned ideal for basement, which means this is really effective if done correctly.
House Construction
