Results 221 to 230 of 795
- Jan 2009
- 121
July 19th, 2021 02:03 PM #221
July 19th, 2021 02:37 PM #222
Even pakyaw needs to be managed, you have to know that yung weekly payroll nila will not exceed the accomplishment for that period, otherwise, ubos na ang contract price, hindi pa tapos ang project. Meron dito sa amin notorious sa ganyan, nadale nya ako, the saddest part is hindi sinabi sa akin ng neighbor ko na nadale din sya ng tao na ito. After gumawa sa kanya, sa akin Naman, and all he said was magaling, nung makwento ko sa kanya na over vale na, saka pa lang ny sinabi na ganun din ginawa sa kanya.
Sent from my Mi A1 using Tsikot Forums mobile app
- Mar 2013
- 6,160
July 25th, 2021 08:49 PM #223Much progress in the house construction build and sell project but lots also still to be done. Creeping past the budget already. Just too many small things cropping up. But gotta stick to d plan.
Sent from my SM-G998B using Tapatalk
- Jun 2009
- 837
July 27th, 2021 12:25 AM #224
BANNED BANNED BANNED
- Sep 2015
- 13,919
September 29th, 2021 02:56 PM #225May ka-fling ako bagong-lipat umupa matitirhan. Wala pa isang buwan gusto na umalis dahil sobra init wala kasi bintana dadaluyan hangin.
And ang dami talaga cheapipay townhouse yung makikita mo ang sampayan nasa parking ng kisame nagimprovise. Tipid na tipid talaga gumawa basta makaraos pang laman-tiyan.
Madami hindi nakakaintindi ng flow ng air. Litaw na litaw ngayon pandemic.
Alfrescong walang puno.
November 6th, 2021 11:14 AM #226
How much na panambak ngayon?
And if me kasama ng bulldozer services - magkano?
Price from provinces around NCR sana.
pre-pandemic we got 1300 per single elf truckload.
- Sep 2015
- 13,919
December 20th, 2021 09:51 PM #227where is my man travahans na makalarry bird? Pero naligaw ng landas dahil nakilugaw
I have a question what is the best roofing against odette level typhoon? Clay bricks?
- Sep 2008
- 631
December 31st, 2021 03:01 PM #229
Tulo ang counter with sink ko, I know I need to scrape the dugtungan before I put sealant, but what sealant kaya maganda and sure fix pangmatagalan? Any suggestions, other than this? Thanks.
Sent from my M2101K7BG using Tsikot Forums mobile app
- 52,731
December 31st, 2021 03:25 PM #230if the water is on the top surface, then the problem must be the tap itself or the connection at its base, and not other the underparts. find out which, and see if it can be serviced.
there are usually gaskets involved.
sometimes, it is a simple matter of tightening.
find which one is leaking, then tighten if it seems loose, and/or replace or put on double gasket. (hey, i know, but it works for me.)
does it leak only when you're using it?
errr,
how's the swiveling joint? how's the plunger lever?
have you consulted the master plumbers, google or youtube? perhaps if you type and search your tap's brand/model...
medyo iba kasi design ng gripo ninyo...Last edited by dr. d; December 31st, 2021 at 03:49 PM.
