Results 1 to 20 of 809
Threaded View
    Tulo ang counter with sink ko, I know I need to scrape the dugtungan before I put sealant, but what sealant kaya maganda and sure fix pangmatagalan? Any suggestions, other than this? Thanks.img_20211231_092726.jpgimg_20211231_092359.jpg
    Sent from my M2101K7BG using Tsikot Forums mobile app
    if the water is on the top surface, then the problem must be the tap itself or the connection at its base, and not other the underparts. find out which, and see if it can be serviced.
    there are usually gaskets involved.
    sometimes, it is a simple matter of tightening.
    find which one is leaking, then tighten if it seems loose, and/or replace or put on double gasket. (hey, i know, but it works for me.)
    does it leak only when you're using it?
    errr,
    how's the swiveling joint? how's the plunger lever?
    have you consulted the master plumbers, google or youtube? perhaps if you type and search your tap's brand/model...
    medyo iba kasi design ng gripo ninyo...
House Construction
