Page 12 of 41 FirstFirst ... 2891011121314151622 ... LastLast
Results 221 to 240 of 809
    Jan 2009
    #221
    Quote Originally Posted by viper888 View Post
    Getting rid of trees is a complicated process with DENR permits and etc.
    In a new construction, we try to have the owner sort out the permits for trees to be moved or removed before the start of construction.
    Or just wait for a storm
    If there is a 2 meter high trunk left, it is not cutting, only trimming. No need permit.
    Jan 2016
    #222
    30% but it varies
    If you can monitor and manage them daily, daily could be cheaper
    Of course pakyaw will be more expensive but at least your cost is fixed.
    Even pakyaw needs to be managed, you have to know that yung weekly payroll nila will not exceed the accomplishment for that period, otherwise, ubos na ang contract price, hindi pa tapos ang project. Meron dito sa amin notorious sa ganyan, nadale nya ako, the saddest part is hindi sinabi sa akin ng neighbor ko na nadale din sya ng tao na ito. After gumawa sa kanya, sa akin Naman, and all he said was magaling, nung makwento ko sa kanya na over vale na, saka pa lang ny sinabi na ganun din ginawa sa kanya.
    Sent from my Mi A1 using Tsikot Forums mobile app
    Mar 2013
    #223
    Much progress in the house construction build and sell project but lots also still to be done. Creeping past the budget already. Just too many small things cropping up. But gotta stick to d plan.
    Sent from my SM-G998B using Tapatalk
    Jun 2009
    #224
    Please share before and after photos if you can
    May ka-fling ako bagong-lipat umupa matitirhan. Wala pa isang buwan gusto na umalis dahil sobra init wala kasi bintana dadaluyan hangin.
    And ang dami talaga cheapipay townhouse yung makikita mo ang sampayan nasa parking ng kisame nagimprovise. Tipid na tipid talaga gumawa basta makaraos pang laman-tiyan.
    Madami hindi nakakaintindi ng flow ng air. Litaw na litaw ngayon pandemic.
    Alfrescong walang puno.
    Sep 2010
    #226
    How much na panambak ngayon?
    And if me kasama ng bulldozer services - magkano?
    Price from provinces around NCR sana.
    pre-pandemic we got 1300 per single elf truckload.
    where is my man travahans na makalarry bird? Pero naligaw ng landas dahil nakilugaw
    I have a question what is the best roofing against odette level typhoon? Clay bricks?
    Sep 2008
    #228
    For me, Concrete Slab. Similar to Diego Garcia.
    Jan 2016
    #229
    Tulo ang counter with sink ko, I know I need to scrape the dugtungan before I put sealant, but what sealant kaya maganda and sure fix pangmatagalan? Any suggestions, other than this? Thanks.img_20211231_092726.jpgimg_20211231_092359.jpg
    Sent from my M2101K7BG using Tsikot Forums mobile app
    #230
    if the water is on the top surface, then the problem must be the tap itself or the connection at its base, and not other the underparts. find out which, and see if it can be serviced.
    there are usually gaskets involved.
    sometimes, it is a simple matter of tightening.
    find which one is leaking, then tighten if it seems loose, and/or replace or put on double gasket. (hey, i know, but it works for me.)
    does it leak only when you're using it?
    errr,
    how's the swiveling joint? how's the plunger lever?
    have you consulted the master plumbers, google or youtube? perhaps if you type and search your tap's brand/model...
    medyo iba kasi design ng gripo ninyo...
    Jan 2016
    #231
    Yes doc, naiipunan yang portion na yan ng tubig because the whenever you use the lever, the water from the hands drip on it. And I am also not ruling out that the drip might be from the base of the faucet, though it has a gasket and I have tightened it myself. Although If the leak was from the faucet, it would be easier for it to drip directly to the floor rather than crawl towards the wall as there is no incline to there. I will also google for some good sealants, I've seen a product which stops water even with pressure from the side where the water gushes out. Pansamantala, I am preventing water from pooling by using a chamois, till I am able have time next week. Meanwhile, antay muna baka may mga same experiences and fixes by our tsikoteers. Happy Friday the 31th! [emoji3060]
    #232
    oh!
    my bad!
    i thought, you had a leak in your gripo!
    yun pala,
    the collected water on top of your marmol, was seeping thru the joint and dripping down to the underbelly of your sink...
    my 98 centavos' worth, would be the usual sealants in the mall.
    the invisible ones (or clear grout) should leave very little telltale marks.
    they are easy to DIY, naman.
    Jan 2012
    #233
    Use a clear silicone sealant, something waterproof labelled for kitchen and bathroom use. Sanitary grade would be better.
    #234
    Joints are the reason why we only opt either Stainless or premium solid surface tops, sir. Stainless back-splashes are bent & joints, fully welded. Premium solid surface tops like DuPont's Corian would have all joints done monolithically in the same material, no sealants. Yes, lotsa copies around, but some warp w/ heat, stain w/ liquid spills & crack on corner joints. We get what we pay for.
    In your case, the faucet base may just need tightening + a bead of polyurethane seal seating won't hurt. I'd always discourage the temptation of getting pull-out kitchen faucet heads. A good Hans Grohe or Kohler Gooseneck will last you a long while. Sealant on your separated back-splash joint will be temporary fix. The practice prior to sticking non-monolithic vertical back-splash is to polyurethane seal the top-wall joint 1st. You might have to remove & redo that strip properly.
    Finally, sink modules are best done w/ waterproof boards, 18mm PVC or FiCem are ideal options that can stand water abuse.
    Always remember, any kitchen is just as good as its top & undermount sink. Once these trouble you, a proper redo is a must to keep it functioning properly.
    Hope you'll sort it out sooner than later, sir.
    A blessed '22, y'all! Stay grateful![emoji120]
    Sent from my SM-G970F using Tsikot Forums mobile app
    Sep 2020
    #235
    Try mo ABC silicon sealant available sa wilcon depot. Makapit.
    Jan 2016
    #236
    Welcome back Sir Travs! As always, valuable advise from an expert. I was simply going to put a bostik waterproof sealant underneath the faucet, but that sealant seat I did not think of. Yeah, I'm going to reseat it then. And thank you to those also who chimed in, I will find a good sealant. Happy 2022 later!
    #237
    Thanks, sir. With no power & weak sig, took a bit of luck to have replies successfully sent, I guess.[emoji4]
    Again, a blessed '22 to all!!![emoji120]
    Jan 2016
    #238
    Hoping for the quick recovery of typhoon ravaged areas [emoji120]
    #239
    Same prayer. Many had it worse. Picking up the pcs...counting blessings![emoji120]
    travahans,
    check this villa that survive odette. Meron parang rattan outer roofing and inner fiber glass?
    starts 2:20
    ganito mga gusto ko may sarili diskarte hindi sumabay sa agos.
House Construction
