Results 261 to 270 of 885
November 17th, 2013 09:35 PM #261
- Aug 2003
- 9,720
December 8th, 2013 09:38 PM #262mga sirs bump ko lang to...
ano po yung recommended brands? looking for a 3 - 5kVA unit, silent type. thanks
- Aug 2003
- 9,720
- Aug 2003
- 9,720
December 20th, 2013 10:48 AM #264bumping...
Looking for a generator with the ff specs:
- 5 - 6kVA range.
- prefer diesel, but gas is ok
- easy start + manual start available
- silent type(optional)
Ano pong magandang brand, one that is serviceable with plenty of parts?
Regarding the noise: is it possible to DIY an insulation enclosure for the generator?
Malaki ba price diff between normal and inverter-type engines?
thanks
December 20th, 2013 11:52 AM #266
Diy enclosures.. Pwede
But I don't recommend... Too many factors to consider...
Pag Mali ang pagkagawa.. It can start a fire, overheating problems, problems sa pag service sa unit.... Accessibility...
December 20th, 2013 01:29 PM #267
Sir manikis, pagka continuous ung genset mo more than 20k na ba un?
Sent from my iPad using Tsikot Car Forums
- Jun 2007
- 1,161
December 20th, 2013 01:57 PM #268sir glenn, is it true na possible i-convert ang car engine into a generator set?
sabi kasi ng pinsan ko, bili na lang daw kami ng diesel or gas engine tapos i-convert nya.
if possible, anong pros & cons non?
thanks in advance.
December 20th, 2013 02:06 PM #269
Hmmm.... magiging compatible kaya ang alternator sa car engine sir? wala pa akong nakitang nag convert.
- Aug 2003
- 9,720
December 20th, 2013 03:07 PM #270Sir maganda po ba yung kipor? a dealer once told me this is the #2 genset brand in China, class "A" naman daw. Di kaya problema sa piyesa?
Tried looking for Honda, they don't seem to have any (locally) beyond 3kVA.
Also tried looking at Kubota...parang wala naman less than 10kVA :p
Re car motor as generator: with enough engineering knowledge and machine shop skills, pwede siguro, but considering even a lowly 40hp engine, that's around 29kVA right? Unless you have that kind of load, parang sayang lang sa fuel.
Bigat paa :grin:
(2023) Ford Territory
