Page 73 of 91 FirstFirst ... 236369707172737475767783 ... LastLast
Results 721 to 730 of 908
    Jan 2003
    #721
    Quote Originally Posted by Lew_Alcindor View Post
    Not to be rude, but you are asking a lot in one post. I suggest you google first, and ask here what you do not understand fro your own research.
    I am willing to answer some of your questions based on my own googling but first, how much is your budget?
    If I am correct, diesel gensets are more expensive than gasoline gensets. You can find diesel genset only from units with output of 3000watts up. Lower output gensets are gasoline fed.
    Inverter- more expensive but also more efficient than common gensets.
    6kva genset is more than enough for the specified appliances.
    kw vs kva? Yan ang ndi ko alam. Hahaha
    Sent from my GT-N5100 using Tapatalk 2
    Kw = Kilo watts
    KVA = Kilo Volt Amperes
    W= VA (VxA) or Power = Voltage x Current
    Therefore Kilowatt is the same as Kilo Volt Amprere.
    Jul 2013
    #722
    Quote Originally Posted by macsd View Post
    Kw = Kilo watts
    Yan din ang alam ko before pero mali pala.
    Parang may power factor sa equation. Pag power factor =1, KW=KVA. Pero bihira naman daw 1 ang power factor.
    #723
    VA (or volt-ampere) has a reactive load - either capacitive,- but almost all of the times, inductive
    W - is purely resistive load...
    For house consumption (all intents and purposes), they are practically the same. They are "interchangeable"
    Else,- I will have you to go through complex mathematical computations....
    26.1K _/_/_/_/_/:loopy:_/_/_/_/_/
    #724
    matutuloy ba talaga ang brownouts this summer? di pa ko nakakabili at baka kasi sayang lang.
    Feb 2009
    #725
    With so many stores and with maids, there should be no need to stock up on fish, meat and poultry. So the power outages only inconvenience would be illumination and air conditioning.
    Mar 2005
    #726
    I started this thread and bought a gen set. Up to now di ko pa nagagamit haha.
    I have about 5 hours on it to warm it up at least 2-3x a month.
    So is it worth it? No idea di ko pa nagagamit. But its there when i need it like a gun
    #727
    Quote Originally Posted by jasonub View Post
    I tell you dear bro.,- the first time you use it,- and your neighbors are lingering in the dark...
    It is worth every penny you paid for it!...
    Jul 2013
    #728
    I also started a gen set thread which I believe was merged into the current one. I am the fourth post which says says says BANNED! BANNED! BANNED! (O.T. Honestly, I do not know why my account was banned, tsk tsk tsk).
    So my post was like in 2006 but I bought my gen set . . . . . . last week!!!!
    So I decided to buy a small taiwan-made, copper winding (Japan technology whatever) gen set with a rated capacity of 1,000watts.
    Napag-isip isip ko din na kung saglit lang naman ang brownout (mga 4 hours), hindi ko na kailangan isaksak pa ang ref at titiisin ko na lang mag-electtric fan.
    Kung matagalang brownout naman tulad nung Glenda (3 weeks kami wala kuryente), mauubos naman pera ko kung mag-eercon at mag-reref pa kami.
    In short, maliit ng gen set lang kailangan ko. Just enough for the basics.
    BTW, I plan to enclose it in a baffle/quiet box. Can you recommend any sound deadening materials that I can easily get. Design is easy to get in the net.
    Jun 2006
    #729
    My 5 yr old 1.5kva china genset is still good and kicking. Nasa 50hrs pa lang siguro ang runtime ko dito. Pero thst includes a .5hp aircon.
    I store the genset fully fuelled with BLAZE, lasts up to a year in storage and just swap it out every summer.
    Pero ngayon stored unfuelled na sya, naka hybrid solar na ako.
    Jun 2011
    #730
    Pre.. Balita ko tuloy na tuloy daw brownout... At nakakahiya naman daw at humihingi pa ng emergency powers, Tapos wala naman palang brownout... Kaya sa April and May nalang nila schedule ang plant maintenance shutdown... He he...
Generator sets
