Results 761 to 770 of 885
- 52,698
April 23rd, 2017 11:15 PM #761if you don't mind the aesthetics.
put old tires against all sides. then get another tire, put it on the ground, then get some wood with dimensions big enough such that it will fit in between all those side tires and not slosh around. then clamp the generator on that wood.
April 23rd, 2017 11:18 PM #762
during my acoustics class.. we ventured into egg trays/cartons... but i wasnt interested...i was more into robotics then 😁 before drone era was good but now im not as savvy..
- Aug 2003
- 9,720
April 24th, 2017 07:13 AM #763^ i was thinking more along the lines of acoustic, non-flammable foam sir, pero solve ko muna yung vibration.
Hindi naman po namin isasara yung doors while the genset is on for better ventilation
April 25th, 2017 09:31 PM #764
- Aug 2003
- 9,720
April 25th, 2017 09:35 PM #765Would putting an industrial fan inside help? Yung exhaust pipe extended naman palabas, and hindi nakafix sa genset, tinutok lang dun yung tambutso.
April 25th, 2017 10:13 PM #766
mas maganda sana yung naka anchor bolt ang gen-set mo without the wheels on a solid flat floor (must be same level on all 4-corners).
to lessen the vibration meron din nabibiling hard rubber para ilagay on top of the solid flat floor bago higpitan ang anchor bolt.
agree din ako sa extension ng exhaust pipe para iwas overheating... ideal kung meron insulation material na pwedeng ibalot sa exhaust piping/muffler (ewan ko lang kung meron kay bro gm ito).
- Jul 2013
- 2,450
April 26th, 2017 10:03 AM #767
- Aug 2003
- 9,720
April 26th, 2017 10:06 AM #768Thanks for the comments sirs, i'll see if i can get something done over the weekend
July 31st, 2017 12:02 PM #769
Meron bang nabibiling less than 10KVA na GENSET na:
- diesel
- 1800 rpm
- liquid cooled
- brushless alternator
- OK lang kahit CHINA engine (or clone)
TIA
August 26th, 2017 08:24 AM #770
Suzuki JIMNY [merged threads]
