Results 821 to 830 of 885
November 14th, 2020 02:18 PM #821
November 14th, 2020 02:23 PM #822
Pwede naman basta malayo yun genset saka sa open, kung totoo yun sabi ni baludoy, sobrangnl irresponsible naman doon nilagay sa ilalim ng A/C yun genset.
Meron code yan eh kung ilan meters dapat layo sa mga windows gayahin mo na lang yun code sa America.
November 14th, 2020 02:42 PM #823
November 14th, 2020 02:46 PM #824
November 14th, 2020 03:42 PM #825
^the generator should always be more than capable to provide the energy requirements of the load (home appliances)
Also the wire that will connect the generator to the load should be more than capable to handle the current required..otherwise, you could burn the household
Sent from my SM-G532G using Tapatalk
November 16th, 2020 08:28 PM #826
Meron na ba gumawa na sa g3nset 12v port nag jump start ng kotse? Pwede ba yun?
November 16th, 2020 09:33 PM #827
November 16th, 2020 10:14 PM #828
Its possible but theres a risk of an overload. Overload is the state when the load draws more current than what the generator can provide. The starter circuit of the vehicle can draw a lot of current to start an engine thats why jumper cables are thick
If your generator is not equipped with an overload protection circuit (fuse) then you could risk ruining the rectifier circuit (diode) of the generator
Considering not all generators have the same capacity. Its dangerous to assume that if it worked for others..it will also work with your generator..it all depends on the capacity of the generator
Sent from my SM-G532G using TapatalkLast edited by kisshmet; November 16th, 2020 at 10:21 PM.
- 52,731
November 16th, 2020 10:50 PM #830
we used to have a car battery charger with engine start capability. plugging it into our house wall socket, it would start our old skul cars with weak battery. there are local ads for such start-capable car battery chargers.
puede rin, i suppose, i-plug sa genset. but you have to have a genset that can safely supply the hi wattage, i.e., 1500-2000 watts or so.
but i am old skul.
my concern is the modern car's cpu.
can it function using interrupted direct current?
because if not, you will have to look for a circuit that offers continuous or smoother direct current.
Xiaomi E-Car
