Results 301 to 310 of 908
- Aug 2003
- 9,720
May 6th, 2014 10:39 AM #301sorry for semi-hijacking the discussion...
Anyone here own Kipor diesel gensets? Mukhang marami na ring dealers dito. They've also made some inroads in the US and Australia. Japan-made gensets are just way outside my price range.
- Aug 2003
- 9,720
May 9th, 2014 10:11 AM #303
*Glen
It's for home use. Can you PM your daughter's contact number? Does she have 10-20 KVA units? Thank you.
- Dec 2010
- 336
May 9th, 2014 02:00 PM #304There is a Genset now that is FUELLESS, 25KW by DAZO. Check it out, may kamahalan lang pero it frees you from
electric bills and brown-outs.
July 17th, 2014 07:47 PM #305
Ano ba ok. Need ko max 3kva. Isang 2hp Aircon=1.5 kva + electric fan x3= 0.120 kva. Lights .160kva.
Total mga 1.6 kva.
As ok ba deisel?
What brands should I consider?
Pano pag tumagal ng 1 year ang diesel sa tank any problem?
Also Mas maganda ba ang di hila? Since we may use it 2-5x a year pag nag brown out.
Thanks
Posted via Tsikot Mobile App
July 17th, 2014 08:26 PM #306
You'll need to consider the starting power needed for the 2 HP aircon. Normally it's 3 times the running power. You need at least 5 KVA to run those, 7 KVA would be best.
- Aug 2003
- 9,720
July 17th, 2014 09:26 PM #307main selling points of diesel for me is:
- more efficient than gasoline
- longer shelf life. Oftentimes you'll forget to stock on "new" fuel; some say you can keep diesel for 7-10 years, yung gasolina 1-2 years lang.
- diesel is stable at room temperature; gasoline turns into gas
- diesel is a lot less volatile/flammable than gasoline. Look it up on youtube.
Although if you do have gasoline-fed cars, that could act as your fuel reserve. Just siphon off what you need when disaster strikes.
Personally i'd go for the ones with electric starters(kahit matanda pwede istart), but the de hila startup is a nice backup in case your battery drains out in storage.Last edited by badkuk; July 17th, 2014 at 09:29 PM.
July 17th, 2014 09:31 PM #308
How much are these generators
plano kong palitan yung sa house
13 yrs na kasi
BANNED BANNED BANNED
- Feb 2011
- 101
July 17th, 2014 10:41 PM #3094k nga, dun kyo sa Manila bumili dami dun
July 17th, 2014 10:51 PM #310
It may be variable speed I think. It's slowly being used on cars that either don't have an ICE, or...
A/c
