Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 57
    Feb 2009
    #41
    #42
    The torque specs are all in the manual. With all my different cars through the years, the manufacturers have always included the torque specs in the manual. All we have to do is read it. Admittedly, I have made the mistake of greasing the nuts before, since this was what was taught to me by my father. Now I know better.
    There were two memorable instances i recall involving tire mechanics. One was when I bought tires from Tire Center. They used a pneumatic wrench. When I got home, I wanted to loosen it so that I can torque. It was so tight that I had to get the help of our fat househelp to step on the wrench & jump on it. Imagine doing it on 16 lug nuts. The other was when I suffered a flat & had it fixed in your friendly sidewalk vulcaniziing shop. When he loosened it, he felt that the nuts were too loose. Sanay kasi gumamit ng extension bar to tighten the nuts.
    Feb 2014
    #43
    the listed torque specs are for dry unlubricated threads
    Meron ba nag lalagay ng lube🤭
    Feb 2014
    #45
    father daw ni bloowolf when you use lube the friction lessens. so if you use the same torque value the actual pulling force on the lug stud increases
    Jan 2008
    #46
    Me i dont use lube.. messy eh.. just make sure na malinis at walang oxidation yung studs.. pag may oxidation i put little oil and wipe it clean with cloth
    #47
    John Cadogan does
    Feb 2009
    Dec 2014
    #49
    Sabi sakin ng auto service shop na pinuntahan ko, kelangan ko daw i-pa wheel balancing after malipat yung dalwa sa unahan and vice versa?
    Need to verify here first. kelangan nga ba?
    #50
    i don't.
    but if they offer to do it, absolutely free... why not!
Tire rotation?
