Results 31 to 40 of 57
September 5th, 2018 11:43 AM #31
I wonder how our weight can be used as a torque indicator. I always tighten my lugs with my weight by standing on the wrench, that's all, no jumping on it, just a 2 second stand on each lug. I am 65 kgs.
The tire boys most probably tighten it more as i have to jump around 1-3x before i get 1 loose, unless, it tightens over time with use?
September 5th, 2018 12:19 PM #32
September 5th, 2018 01:47 PM #33
Naalala ko tuloy si Botchie Santos ng Topgear magazine.
Yung proper way is to tighten it buy not ovetighten with your hands then use a torque wrench to check. But if you do not have that wrench, just tighten by hand. It won’t loosen if it tightened just right. You are not even supposed to grease the nuts. It has a tendency to loosen when greased.
September 5th, 2018 02:05 PM #34
How to Use a Torque Wrench - How to Tighten Lug Nuts
In this article, it tells you why you shouldn’t use an extension bar, a pneumatic wrench or jumping on the wrench to tighten it.Last edited by bloowolf; September 5th, 2018 at 02:07 PM.
September 5th, 2018 05:02 PM #35
Thank you guys, now I know that I was applying 145 lbs/ft or a little less maybe cause the stock wrench is about 10" only. I quick internet search say 80 lbs/ft only or around 40 kgs force in my case.
Now, now I have to reduce my weight by 25 kgs.
September 5th, 2018 05:38 PM #36
September 5th, 2018 06:01 PM #38
September 5th, 2018 06:11 PM #39
- Nov 2009
- 3,474
September 5th, 2018 06:44 PM #40I always have a 1/2 drive swivel 18 inch handle chrome vanadium breaker bar under the car seat and appropriate sized deep socket for the lug nut. Adds extra self defense, kesa tubo ang dalhin ko.
Passenger cars are usually 90-110 N.m, HD trucks around 150-200 N.m
Traffic!
