Results 41 to 50 of 54
December 15th, 2022 01:57 PM #41
Mas ok ba yan compared sa TOTAL TTAC1406 Auto Air Compressor 140 PSI?
TOTAL TTAC14 6 Auto Air Compressor 14 PSI | Lazada PH
- Feb 2014
- 2,696
December 15th, 2022 02:09 PM #42
malaki size difference. take note pareho lang ingco and total, just different branding
the small one is just fine for doing 1 tire but if you want the pump to last you might wanna give it a rest to cool down halfway through the inflation (if inflating from zero psi)
the big one runs cooler so it's a viable alternative to those even bigger expensive "off road" inflators
for topping up i still recommend those pistol grip units for cordless convenience
- Sep 2016
- 2,348
December 15th, 2022 03:35 PM #43This one po.
https://shopee.ph/12V-Portable-Tire-...7-b83544e5a9a0
Minor lang naging issue ko sa kanya like yung tube nagkaroon na ng singaw dun sa portion na laging nakabend (banda dun sa malapit na sa kinakabit sa valve). Naremedyohan naman at working fine na ulit.
- Nov 2009
- 3,507
December 16th, 2022 01:22 AM #44
Still using onboard 10+yr old Elevo for the pickups/PPV and 4YO Coido for the small vehicles. Saved me many times from running flat due to slow-leaking punctures.
I'd stay away from those digital and cordless, once the lcd/bat break the whole pump goes to dumpster.
- 54,217
December 16th, 2022 09:58 AM #45
- Nov 2019
- 1,412
December 16th, 2022 11:12 AM #46
- Jun 2007
- 12
February 17th, 2023 12:21 PM #47
- 54,217
- Jul 2009
- 2,618
February 17th, 2023 03:27 PM #49
- Sep 2021
- 901
February 17th, 2023 04:04 PM #50^^^
Baka kasi naluluto din pag na-paparada sa araw yung sasakyan. Over time, nakakabilis din sa paglutong yun.
Baka mas matibay yung mga may nylon woven over the hose, kesa yung purong goma lang, pero di ko rin masabi.
The Yokohama BluEarths notoriously break down as you use them. I guess something in their...
Finding the Best Tire for You
