Sige sir salamat, will check it out pag napadaan ako Ace, Blade, Concorde, Handyman. Need parin pala siya isaksak sa 12v outlet kahit manual inflation.
Salamat sir baka same yan dun sa nilink kong elevo inflator in the first page of the thread.
Panong cordless sir? Yun ba ung hindi na need isaksak sa 12v outlet?
here are my current tire inflators:
- 2.5hp for inflating tires from zero, pero it's a big hassle to drag that red air hose all over the garage... so...
- workzone 18v cordless is ideal for topping up, like putting a couple of psi on 4 car tires isn't going to heat it up too much. but it's slow and heats up fast so you can't use it for off-road inflation duties so this is where this comes in...
- Total dual-cylinder. gets my stock Jimny tire from 14psi to 26psi in less than one and a half minutes.
steel cylinder sleeve. metal "head". metal piston and connecting rod. piston ring probably teflon. i think it'll do well if you don't overheat it
i timed the inflation again. 1 minute, 20 seconds to get the stock jimny tire from 14psi to 26psi. that's good enough for my casual off-roading needs
some time ago, i was singing praises to the tyre inflator i got.
well, that bright orange, coiled hose it came with, slowly rotted away, just like my shoes' rubber soles.
the rest of the unit still works, however.
i know it can be replaced with the fabric-covered variety, but i plumb don't have the drive right now.
sigh.
it's big. but i removed the handle and plastic cover to improve cooling and reduce size. also got rid of that stupid yellow coiled hose
if you got space go for it coz price diff isn't big compared to the mini. the mini is gonna get super hot if you try to inflate from zero psi
but the mini you can plug into cig port
PS:
there i managed to stuff it into a box
I've been using the portable and handy Mi tire inflator for two years already. Napansin ko lang parang ang bilis mag blink ng led from white to red indicating na low batt na habang nag i-inflate ako ng car tire. Pero so far kayang mag inflate up to 40psi kapag fully charged yung battery.
Madalas ko nang magamit itong Mi tire inflator mula nung bumalik ako sa condo living. I can easily do a maintenance tire inflation before going out.
Gamit ko din yan sa bicycle
same experience, red LED blinks after a relatively short while, and seems to struggle a bit when getting to the higher pressures - i have doubts if it can fully inflate 1 tire from zero with one charge. I still like it though because it's handy enough for topping up my tires and inflating bike tires. I like that it gives you a pressure reading and you can set a target pressure where it automatically turns off. I have a 70mai tire inflator in the trunk though - the one that you plug in the cigarette lighter -yhis one works much better - except for the hassle of having to plug it in.
Portable tire inflators generally have short lifespans and are not designed for frequent use. Only use them sparingly and as last-resort in the field.
Particularly, if you have your own garage and/or have several cars, get a small air compressor to do the heavy lifting instead.
I have my digital inflator yung kinakabit sa 12v socket. Still serving me well after 4 years. Got it for 1k sa shopee.
