Page 67 of 121 FirstFirst ... 175763646566676869707177117 ... LastLast
Results 1,321 to 1,340 of 2415
    #1321
    Quote Originally Posted by sir_jayson View Post
    Between the choices below, which would you recommend and okay na offered price nila?
    1. Achilles 2233 - 10K
    2. Yokohama DB - 14K
    3. Nexen - 11K
    4. Kumho - incoming stock next week
    Will be replacing 4 tires next week. 185 60 R15. Thanks!
    Sulit yung Achilles, go for it. Marami na satisfied users yung Achilles 2233.
    Mar 2016
    #1322
    Thanks sa response. Okay naman sidewall ng Achilles 2233? Have narrowed my choice between this and yung Kumho Ecowing which is priced at 13k. Have tried na ung Kumho Portran sa CRV ko and 2 yrs ok pa din. Mas tahimik and ok and grip.
    Ok ang Achilles 2233 according to those tsikoteers who've bought them before. Reliable basta for ordinary driving at hindi for track use
    2nd choice ko sa list mo yokohamas kasi decent performers na sila, locally made pa.
    Pwede mo din gawin option ang neuton nt 5000 uhp tires. Better than the stock bridgestone turanza tires i had before. [emoji4]
    Sep 2014
    #1324
    3. Nexen - 11K
    Try to look for Toyo or Falken 15k yung 185/65R15. Sure kapa sa kalidad.
    if gusto mo mag tipid then go with the recommended Achilles. I, however, do not recommend it.
    Sent from my ASUS_X00DDA using Tapatalk
    Mar 2016
    #1325
    Yes, good ang feedback dito kaya I'm considering din. In other countries naman, sa wet road daw hindi maganda and can be seen din dun sa ratings nila. Plus ung sidewall kaya namention ko din.
    I liked ung Kumho Ecowing kasi maganda ung review and ranking vs. other mid priced tires.
    NT5000 good reviews din kaso walang available dun sa kukuhanan ko sa Evangelista or dito sa area namin.
    Mar 2016
    #1326
    Quote Originally Posted by b_9904 View Post
    Sang shop ito sir? Okay din yan kasi halos kaprice lng ng stock ko. Pag nahirapan ako sa kakapili, I'll just go with the stock Yokohama!
    go with the tire with the best wet grip+wet braking.
    #1328
    Surprisingly good performance for the price. Good grip, comfort and treadwear. Just remember that these are directional tires so rotation is forwards and backwards only, di pwede cross. So be conscious to keep your tires properly balanced and aligned to maximize their lifetime. This tire has a fairly thick rim guard to protect against curb rash - a bonus to this is that it makes the tire look lower profile than it really is. A minor complaint is a slight increase in road noise after using it for a while. I used a set for 50K kms until I sold it with my car. It probably still had another 10k kms in it.
    Apr 2014
    #1329
    Benn using toyo drb for the last 3 years and i have no complaints about it. Ilang beses na ako na gutter and di lumulobo yung gulong. Matibay sidewall.
    Plus the thread wear is 340 so di mabilis maupod.
    Sep 2014
    #1330
    15K is 5 tires already nga pala.
    Sep 2014
    #1331
    Yung Toyo sa Mindanao. Yung sikat na store doon pero ang susungit ng staff. Forgot the name e.
    Yung Falken sa Drive+, Panay ave, q.c
    Sep 2014
    #1332
    3. Nexen - 11K
    Check mo din Hankook po if consider mo yung Kumho.
    #1333
    ok din yun toyo na nakuha ko sa banawe 185/55/15 less 10k yun 4 pcs
    recommended ni bro jut, so far OK sya
    #1334
    Jut used the Achilles 2233 for the track and ok naman.
    Another good Indonesian tire brand is Accelera. I use the Alpha model on my Fiesta and it is better than the stock Hankook Optimo.
    Mar 2016
    #1335
    May nakita na kong toyo dealer sa area namin. Offered me Toyo Neo 3. 5k each pero they have 3+1 promo. So, 15k din na kapresyo lang ng Yokohama DB. Parehas namang entry level, which would I pick? Will be getting by Tuesday na.
    Mar 2016
    #1336
    Between Toyo NEO 3 and Yokohama DB?
    Mar 2016
    #1337
    Toyo DRB or Neo 3? Kumusta sa wet road?
    #1338
    Drb bro pero old stock nga pala, almost 2 year old sila when i got it
    Sent from my SM-C900F using Tapatalk
    #1339
    DRB over Nanoenergy 3. The DRB is the higher end tire of the two while the NEO3 is more of an entry-level eco-tire.
    Mar 2016
    #1340
    Between Toyo NEO 3 and Yokohama DB? Same na entry level and halos same sa price.
Low budget yet good quality tires
