Results 231 to 240 of 2403
February 6th, 2014 09:09 PM #231
Mga sirs ano ang ginagawa niyo sa spare tire na hindi gamit? Or nagamit lang para umabot sa vulcanizing shop.
Let's say for replacement na 4 tires niyo?
5 tires din ba binibili niyo kapag bibili ng bago? Kasi syempre hindi terno kung sakaling kailangan magpalit. Or kunwari napakatagal na naka-stock nung spare.
Hindi ko alam saan tamang ipost ito. Ayoko naman gumawa ng new thread.
February 6th, 2014 09:25 PM #232
With a new car (when all 4 tires + 1 spare are all new at the same time), some people include the spare with the rotation of the 4 other tires so in the end it gets used up also.
If all 4 tires are worn, buy 2 sets only (4 pcs). Pick the best of the 5 old tires and retain as the spare. IMO, provided that the old tire you retained as spare is still useable, there is no sense to waste good money for a new tire to serve as spare.
February 6th, 2014 09:30 PM #233
February 6th, 2014 10:53 PM #234
Ah. Hindi kasi sinasama yung spare ko sa rotation nung mga last pms ko sa toyota. Unless it is by customer request.
Kung gamitin ko siguro yung almost new na spare as 4th tire and just buy 3 pcs., may mura kayang goodyear gt3 14s.
Salamat sa advice.
- Feb 2014
- 3
February 25th, 2014 08:18 AM #235Guys help please...thanks in advance...has anyone used Michelin Agilis on their 2nd Gen CRV? Can I use 215/70 R15? Will my ride be that much bumpier and the steering more stiff? Gusto ko ksi yung porma ng Agilis kaso 8 ply daw sya so pang light truck daw.
February 28th, 2014 02:28 PM #237
Ang ginagawa ko dyan, pag time to replace the 4 tires and the spare is not used, bibili muna ako ng isa para kapares ng spare. Ilalagay ko sila sa harapan. Select one of the best used tires for the spare.
Few months later, bibili ulit ako ng dalawa. Ilalagay ko na ulit sa harapan.
February 28th, 2014 02:36 PM #238
Since one of my upgrade options is to change rims and tires, the spare stays as it is. I just check on the inflation from time to time, and especially before road trips.
I commonly rotate every 10t kms such that all 4 tires have similar wear. Downside is almost forced ka to replace all 4 tires at the same time. Ang maganda lang is kung mag-upgrade to a different wheel and tire set, having 4 tires with even wear will be easier to sell than having 2 tires thinner than the others.
February 28th, 2014 02:38 PM #239
- Aug 2012
- 2,767
February 28th, 2014 05:22 PM #240how about if changed 4 tires from 195/65 R15 to 205/65 R15.. do i need to replace the spare tire also? 205/65 is just 0.5 inch taller than 195/65. the 195/65 spare tire still relatively new and remains unused.
Probably looks like a Coke sakto. Yes, where did you buy it?
Fire Extinguisher for Car: what brand and type...
