oh oh. did you do a compression test sq after you install the new head? ano sabi mechanic mo?
I always do BUT when the vehcile has been idle for a couple of minutes. This produces that weird stinky smell. It's caused by the special motor oil we put (BESCO) But after continuous acceleration from idle, it disappears.
This I also recommend IF the bluish white smoke does not disappear even after the vehicle has accelerated. As in tuloy-tuloy at di nawawala. lalo na kung nagpalit ka ng head. Did you have your Trooper undergo Tech 2 check after the engine fix?![]()
not yet niwds. first thing we do was to replace the injector O-rings with a new one. Dramatic effect felt.
Before kasi scandalous talaga. As in parang naka smoke dispenser na security accessory ng armored car.
I remember that during my BESCO days but now its kinda stange. Minsan malakas, minsan mahina at minsan contionous. Also the oil pressure drops sometimes to almost Zero. Parang nag fa-flactuate.
Nest move is to check valve clearance daw.
yeah check valve clearance(and stems *not sure with the term*). bluish smoke is a sign na sumusunog ng oil.
none. according to some experts pag 285/75 ang me slight rubbing. pero dami pa rin gamit ng ganung size.
Just want to share, my dad has an 03 model with 67K km on the odometer until now ok pa naman cya no erratic problems pero during the 50tkms check pinalitan ng casa ng injectors for free.
Mga sirs baka meron kayong alam saan ako makakabili ng chrome tail light cover ng trooper khit used sana bsta ok pa?
I had mine replaced with that JVC HU used as standard nung Crosswind 2007. (AVX1 with built-in 3" LCD). Point of change is that i received feedback too that the OEM JVC (silver finish face) tend to "conk out" in time.... such as reading failure, etc)
Partner, upgrade mo na yan!!!![]()
btw ano gamit nyo shocks? nagpalit ako kayaba gas a-just on all four. parang mas boaty pa sya kesa dati considering kyb naman yung oem ng trooper.
okay naman siguro. dapat pala eto na lang binile mo. http://tsikot.yehey.com/classifieds/.../product/99385
Stock parin. 5 years na ok pa naman. pero planning to change to OME or bilstien.
Bilstein HD (Comfort Settings) --- I had a set on my Trooper when I changed my rims to 22". Idea was to compensate the reduced rubber to dampen road bumpiness. each shock cost around 6-7k. Result: :party:
They look like this:
Ok kaya 275/70 sa stock 16x7jj rims? I doubt it they would not cause any rubbing specially on half turns on uneven roads. At 265/70, I'm sure it's a plug-and-play.
benz, ayan din ang recomended ng kaibigan ko. kaso madugo dito. medyo mura sa US. baka pabile na lang ako dun. care to provide the part number para to counter check dun sa offer sa sister ko. tia.
thanks bob.
last time i was quoted parang 36k ata set of 4. then change 2 coils at rear.
adjustable ba ang HD series?
My choices are michelin latitude HO or BFG all terrain. or 18" journey with 285/60. no rubbing kaya?
Nga pala, wala ng thermostat yung trooper ko. antagal uminit!!!!!!!![]()
